Stations that should have their platforms renumbered
16 Oct 2018
Prickwillow
Annoying and unimaginative. Even platform Y or A is better than 0. Something imaginative like platform 42 or platform 89 (a nice nod to the preservation movement whose mainline-ready locomotives are now numbered in Class 89, as well as the electrification prototype) would have been even better.
When labelling something to help people find it, unimaginative is kind of the point.
ashkeba
13 May 2019
Signs do that, same as they do now, including the very frequent "PLATFORM O IS LOCATED TO THE RIGHT OF PLATFORM 1" on the Customer Notice sign by the departure boards. https://goo.gl/maps/L82iDHKyZkebpzbb9
Almost no-one expects platforms numbered lower than 1 anyway. I've overheard plenty of people refer to it as "platform O".
reddragon
24 Mar 2016
Churn (closed)
None of you have matched Stratford yet!
Denis103
22 Mar 2018
I don’t understand what’s ‘annoying and unimaginative ‘ about 100s of thousands of £ or more cost to renumbering everything.
There was a a precedent in changing to Platform ‘0’ from elsewhere so that’s why it was followed.
ashkeba
13 May 2019
Why would it have cost more or required renumbering everything to use a different number or letter than O?
Was there? From where? And wouldn't slavishly following precedent mean we never learn from past mistakes?
16 Oct 2018
Prickwillow
How is 0 a mistake? If someone reads it as zero, then they think, 'other side of Platform 1 to Platform 2', and there they find it. If they read oh, that is not different to reading Y or 89 or 42, which is 'where the hell would I find that', and they have to look for signs. Then once they find it, they realize, 'zero, not oh', and next time everything is fine.
Obviously, 1 upwards is better, hence why Meridian Water has left 1 out because they plan on adding a platform later, and it will be neater, but 0 is better than spending a bomb on renumbering, and the closest to obvious they can get.
ashkeba
13 May 2019
How is 0 a mistake?
It's easily mistaken for a letter. Plus, if you realise it's a zero, it can look like something has failed to set a value, or a platform permanently out of use (which is how platform zero is used in some countries).
0 may be better than spending lots renumbering, but it's worse than using high numbers like in Germany: https://goo.gl/maps/Rr5gz8C8h1HQjD6g7
16 Oct 2018
Prickwillow
I have to admit that I never considered the idea of 0 being a null value, which considering I'm a computer programmer is odd, but even so, the not assigned value on a departure board is always '-'. The sentences you cropped from my quote was the response to the idea that it might read as a letter, which is, that gives the same information as any other name you might give it, like 89, which is very little. I can see why St Pancras used A and B for the Thameslink Platforms, that gives the information that they are two platforms together, in a location not necessarily related to the main platforms, but in Kings Cross, it is right there, next to platform 1, so it makes perfect sense to use 0, especially, as when it was opened, there were already at least 4 official platform 0's in the UK, and it had been used at other times.
https://www.solipsys.co.uk/new/PlatformZero.html
High numbers might be how other countries have dealt with this problem, but it appears we have decided to go with letters in many cases, but 0 when it is located next to platform 1, so that the sequence makes sense to people.
I wonder if anyone has missed the train because it was 0, rather than 89, or A, or Y?
I imagine the Kings Cross re-modelling will also re-number the platforms to start from 1, which has the invaluable benefit of putting 9 3/4 in the corect place between 9 and 10!
Coming up to six years after the Nottingham platform re-numbering, I still have to think twice about where 5 and 6 now are.
R G NOW.
25 Jan 2019
gloucester
Bristol. Temple. Meads. Numbered to 15, but it’s only got 9 platforms even if you count the unused platform 2. Not to mention the disappearing number 14. I’m sure the numbering system is only there to make GWR think it’s bigger than it is :p
Bristol temple meads platform numbers were not done by the GWR TOC, but were renumbered in 1970 when the Bristol PSB was commissioned. Platform 15 was I think added sometime in 1978 was the old plat 2. The original 14 was in the train shed.
The platforms are numbered odd towards London and even towards Penzance, as platform 13 and 15 were all one, the even number 14 was dropped. odd numbered obviously being nearer to London.
Lastly, if NR bring into use the train shed, then the platforms would have to be numbered plat 1 and plat 1a as it points towards London.
Steve Harris
11 Dec 2016
ECML
But we are in the uk, why do we have to adopt the way other countries do things?
0 as pointed out earlier is logical. And most people have the mental aptitude to figure out its a 0 rather than a O.
Nthep
17 Feb 2016
Isn't Leeds to due to acquire a platform 0 soon, previously having had a platform W prior to the 2000 remodel?
40129
23 May 2014
Surprised nobodys mentioned Shrewsbury. Platforms in use are numbered 3-7. Platforms 1 has no track and iirc platform 2 has been demolished. If I were in charge I would re-number them from 1-5 with the current platform 7 becoming platform 1 and 3 becoming 5. This would make sense as the main platforms (now 5-7, would be 4-1) are on one island accessed via the main ticket barriers and passageway whilst the other platform ( now 3 would be 5) is accessed by exiting the main building turning left and then re-entering
leytongabriel
27 Jan 2013
Tottenham Hale is currently sporting platforms 2,3 and 4 with no 1 in sight anywhere.
2 is the new side for the Meridian Water service starting in June, 3 is southbound and 4 is northbound.
Kneedown
29 Dec 2007
Nottinghamshire
The usual problem is that the platform numbers are hard-wired into the local signalling system, eg the theatre box indicators on signal posts, and all the obvious controls in the signal centre.
This is true. In Sheffield's case the route indication into 2c is a "D" for dock so no problem there, but you would have to alter the existing indications for all platforms from 3 to 8. I don't personally see how 2c is confusing as it's right next to 2, just as long as signage is adequate.
Yes, and it’s amazing how often this suggestion to “re-number for neatness” comes up, and every time it gets explained after a few posts that it isn’t normally done for sound engineering reasons, and there’d be a significant cost involved. Four pages later people still seem to think it’s a case of slapping on a few quids worth of vinyls...
mrcheek
11 Sep 2007
Weston-super-Mare used to cause some confusion in the past. The main platform is numbered 2, with the other platform numbered 1. Usage is pretty even between the two now, but years ago, nearly all trains used 2. Plus, there was very little signage. So when people saw a train announced as being from platform 2, they often assumed they had to cross to the other side.
vlad
13 May 2018
I was at Navigation Road yesterday and trains were announced by the robot as leaving from platform 2. Does that mean that platform 1 is the Metrolink platform?
DaveTM
25 Mar 2014
I've not spotted any mention of Pompey in this thread yet, and it has two candidates for renumbering...
Portsmouth and Southsea station's platforms are numbered 2-1-3-4 from East to West.
And Portsmouth Harbour's platforms are numbered 1-3-4-5 from West to East.
Greybeard33
18 Feb 2012
Greater Manchester
The station plan on NRE describes the two Navigation Road platforms as "Platform 1" and "Metrolink Platform", so a bit of a conflict there! Do the automated announcements say Platform 2 for trains in either direction?
The latter is probably a reasonable state to leave it in, because there’s always that very slight chance of reinstatement...
ashkeba
13 May 2019
Aren't most of the stations from Bristol to Taunton like that, with the Bristol/London-bound trains usually departing from Platform 2 on the side nearest the centre of the town/village the station is named after, where any buildings are located? Nailsea, Worle, WsM, Highbridge, Bridgwater are all like it. Yatton's platforms are the same way round but the village centre and station cafe are at least on the Platform 1 side.
vlad
13 May 2018
I only heard the announcement for the Chester train I'm afraid. For some reason the Manchester train wasn't announced at all!
kevjs
4 Sep 2013
Preston
From West to East
RES*, 0*, 1, 2, 3, 3c, 4c, 4, 5, 6, 7*
* = Not in regular USE
RES and 0 haven't been used since Engineering work well over a decade ago, and & 7 is mainly for cycle parking nowadays.
