Stockport - London
tamesidedepot
3 Jun 2012
Hi all,
I have looked at the routing guide and am pretty sure that the following are permitted routes from Stockport to London.
Stockport - Euston direct (no problem there)
Stockport - Birmingham - Marylebone
Stockport - Sheffield - St Pancras
I have also once been advised that Stockport - Reading - Paddington is also a valid route, although this was about 3 years ago when the WCML was closed at weekends.
It would be helpful to know if these are indeed all valid, as I am quite often working around London, and being able to travel back from Marylebone or Paddington on an open return would be preferable at times than getting back to Euston.
cheers
Simon
hairyhandedfool
14 Apr 2008
Yes, aswell as being the direct route it is also on map MA.
Yes, this is on map CS and map combination CM+GC.
Yes, this is on map combination PS+MM.
This is valid on map CS.
tamesidedepot
3 Jun 2012
Thanks,
I had checked but as I only ever do SPT-EUS I was a little unsure of travelling the other routes, so thought I would double check
calc7
8 Aug 2011
I am curious to know from tamesidedepot how a tube to Euston and a very frequent 1h55 service to Stockport would ever be less convenient than one of the other routes suggested.
calc7
8 Aug 2011
He might not like the tube and/or have a fair bit of luggage to carry around.
But surely then having to change at Paddington/Birmingham (perhaps Moor St to New St) or the fact that St Pancras and Euston are on the same road; coupled with the extended journey times, means this argument doesn't hold much water?
scrapy
15 Dec 2008
The OP never mentioned convienience. They simply said preferable, might just want a change of scenery.
Phil6219
15 Jul 2011
Manchester, UK
That's why if I'm not in a hurry I travel from Manchester Piccadilly to London via Sheffield, sure I have to squeeze into a 185 for the Transpennine portion but it's worth it for a HST on the MML.
Never had any problems going via Sheffield from Manchester to St Pancras...
Now would Manchester - Cardiff - Paddington be a valid route to London :lol:
Phil 8-)
calc7
8 Aug 2011
I took "travelling from Marylebone or Paddington might be preferable to getting back to Euston" being an indication that travelling to Euston is somewhat inconvenient.
That's by the by, anyway - my main point is that cheaper fares exist for routes such as via Chesterfield so I find it a bit of a waste of an overpriced "open return", so to speak.
tamesidedepot
3 Jun 2012
sometimes I have meetings which are a couple of minutes walk from Paddington or Marylebone so rather than spending the time getting to Euston and joining the cattle market to get on the train I have considered the alternatives, which would also I presume allow me the option of breaking my journey for a pint on the return.
My usual journey pattern is SPT-EUS then tube, but as some of my journeys will be during the Olympic period, I am trying to look for alternatives which get me closer to my final destination in London if that makes sense - plus the change of scenery will be nice!
34D
9 Feb 2011
Absolutely - and there is no need to feel you have to justify yourself.
It may be that you have a meeting in Slough or St Albans, in which case these alternative routeings come into their own.
And yes, fine to break your journey for a pint.
