indeed!
And he said the more modern, shiney, ticket stock might as well be a wipe clean white board!
I bet those new ITSO cards are a bugger to stamp
indeed!
I have several Anytime Returns which have not been marked and of which the returns are valid for a month and if I so wished I could probably use some of these several times over without a Northern guard even marking anything.
Here's a suggestion for such a low-tech "Self-validation" system. The only physical requirement is that the return coupon (or an additional mandatory "Ticket Use" coupon) should carry a grid with empty Date/From/To columns.
This system is not easy for fraudsters to get round, because it does not rely exclusively on on-train ticket checks. But it still allows you to have BOJs, even ones you suddenly decide on while en-route.
Process
- Before going through the barriers at the station where you are starting from, or where you are resuming after a BOJ : You fill in the next Date and From boxes. These will be requied by gate staff and train staff.
- Before exiting the Destination, or BOJ, station barriers : (There's no need to do this if changing trains and staying within the barrier) You fill in the To box. All three boxes will be required by gate staff.
- If you manage to fill all the grid rows you can surrender the coupon for a new one (the first Date, and the last Date and To would be copied over).
