It only worked with the HST remote controlling the 91 as a push-pull, it could never provide diesel traction power, nor be controlled from the 91's cab.
This suggests different......
http://www.traintesting.com/ic225_2.htm
Initially the DVT's power unit was only used to supply ETS for the Mk3 coaches, as they differed from the Mk4's, and hence the engines were only running at approx 1000 rpm, just above idling. However, prolonged use of the power cars in this way lead to an excessive build up of un-burnt fuel in the silencers and this eventually lead to fires. One occurred at Hornsey, just outside Ferme Park, and this brought the OHLE down too. After a repeat performance it was decided that the PC engines should be powered up as normal and this then meant that the test trains had a combined available power of over 7000 HP. A modification to the TDM control arrangements allowed the engine to be controlled from the class 91 and an increase in speed up to the maximum of 125 mile/h was accomplished with ease!
