When people get a new heating system to they replace all the piping?Yes. A new heating system and a re-wire are very common jobs when refurbishing a house that's getting on somewhat.
The propulsion system is a much higher proportion of the cost of a multiple unit than the heating system is of a house. Particularly when you include the bogies. I am no expert, but an electric motor bogie (331) is clearly radically different to a cardan shaft drive (195).
How different are the bogies on a 195 vs 331? Is it possible to change the 195 bogies from cardan shaft to bogie mounted motors?
Probably.Even if the 195 bogies weren't capable of being converted, it should be possible to just completely swap the bogies out for new ones with bogie mounted motors
Batteries have surely got to be the way to achieve this. On a different thread @Bald Rick suggested that it would only be a few years before battery powered trains could comfortably bridge 50 mile gaps in electrification, and that if the generator unit on the battery trial GWR 802 that is replaced with a battery weighing the same as the GU, then it would have a 30 min range at full power, which to my mind means that a nationwide intermittent electrification programme based on wiring up busy areas, but leaving battery gaps seems very sensible. For my mind this would mean ... [snipped]
Not any more it doesn't. Alstom on the other hand...Bombardier offers an Aventra with diesel, though I think it was unveiled after Northern's contracts were signed
Except that you have then used up some of the underfloor space between the bogies that you need for the batteries, traction converter, etc....Clearly so, but if you can design an electric motor and gearbox to drive the cardan shaft then you've potentially got an EMU.
Anyone got the breakdown in costs for a km of OHLE on plain line? ( including supply ). I wonder if we could start packaging ( conceptually ) planning & installs of say 10km or 20km ( or whatever distance 5 mins at line speed covers ) sections of knitting on the easiest stretches of line we can find, to keep topping up dual-mode battery EMUs ( or even freight locomotives ).
Might technology come to the rescue here, in the form of small static frequency converters that can feed an "island" from the local DNO network? Combined with sufficient reserve battery capacity that trains can cope with one failed island, so you don't need redundant feeder stations?Battery trains will be part of the answer, to enable intermittent electrification over some fairly big gaps. But there is a difficulty there - you don’t really want electrification ‘islands’ to be too small. For security of supply you need 2 feeder stations for any such island, and feeders are expensive; once you have bigger stretches an FS will typically provide back up for 2 others (one either side), and sometimes more.
Clearly there’s a lot of progress to be made on this yet, but my guess is that gaps in the OLE will either be relatively small (eg a mile or two to cover particularly difficult areas, with an along track feeder bridging the gap), or longer but relatively few in number.
I wonder what the whole-life carbon impact of carting a tri-mode capability around is?As more diesel-only units become life expired, their replacements would come in the form of bi or tri-modes, and allow electrification to be prioritised on the busiest routes.
You do not, presumably, have to make that 80km of contiguous OLE though - so you can skip tunnels, stations, awkward bridges, expensive stuff? and just parts you don't feel are necessary. I take it 40km or so is about as far from a feeder as you want to go? although you could have battery reservoirs at the ends & use them to feed further sections etc.£3m per single track km all in. About half of that is civils, stations, signalling etc., so in very simple areas with few bridges / stations etc you might get away with £2m. But you will want 50-80km stretches of route to justify 2 feeders, or some thick extension leads.
I see that - somewhere improvements in tech might help ( plenty of robot arms do many cycles per hour & hybrid tech is going to have to make switching power source reliable ) given they're generally designed to go up & stay up right noe. At least you could have dead sections of wire through places that'd otherwise be expensive due to clearance issues, so you only have to worry about mechanical clearances.You don’t have to, but there’s all sorts of reasons why you don’t want pantographs being raised and lowered regularly, not least that it increases the chance of a failure.
Only if you connect it via independent feeder cables ( aka long extension leads)Can one feeder station power two sections isolated from each other?
I guess that the risks of raising/lowering pantographs are smaller when at a station than in motion: less risk of the changeover location being wrong, dynamic forces less a problem, less risk of bringing knitting down when stationary, and in case of failure then at least it's a failure in a station. So, for instance, for the Chiltern mainline, pantographs would go up at Marylebone to charge from a short length of OLE. Then run out of London on battery and change back to the OLE at a Beaconsfield or High Wycombe stop, once clear of 4th rail, multiple bridges, and junctions. Assuming 25 - 30 miles on battery isn't stretching it.You don’t have to, but there’s all sorts of reasons why you don’t want pantographs being raised and lowered regularly, not least that it increases the chance of a failure.
Or go from feeder -> OLE -> cable >- OLE? in future you could replace cable sections with more knitting.Strictly speaking, many feeders usually do power two sections, occasionally three, isolated from each other; it’s just they are isolated by a neutral section about a metre long.
I suspect you meant can one feeder station power two sections isolated from each other by another section - in which case you need a long extension lead!
GWR ( and presumably other 80x bimode operators ) switch on the move - it really is not a great problem to solve moving an arm up & down on the move and switching input ( with batteries not even the latter and that iis a hybrid problem in general ), it's just a *new* one. One of the ideas of partial electrification is not to wire complicated stations.I guess that the risks of raising/lowering pantographs are smaller when at a station than in motion: less risk of the changeover location being wrong, dynamic forces less a problem, less risk of bringing knitting down when stationary, and in case of failure then at least it's a failure in a station. So, for instance, for the Chiltern mainline, pantographs would go up at Marylebone to charge from a short length of OLE. Then run out of London on battery and change back to the OLE at a Beaconsfield or High Wycombe stop, once clear of 4th rail, multiple bridges, and junctions. Assuming 25 - 30 miles on battery isn't stretching it.
As ever - automatic systems work brilliantly - except when they don’t. In this case you will have drivers doing something they are trained for, but rarely do, which can lead to errors. The incident at Neville Hill was triggered, in part, by a driver manually overriding the auto pan drop system.
It's not doing it that's the problem, it's doing it safely, without failure, and without time penalty several hundred times a day (across all units).if the rail industry can't solve automated power changeovers then it needs to have a good look at itself... )
also and I hate to say it, but in a world where self-driving cars are looking practical without any changes to the road network, if the rail industry can't solve automated power changeovers then it needs to have a good look at itself...
