However when the wires reach Swansea it will logical that all the services on the south wales mainline are electric powered so the current Manchester-Marches-Cardiff-Swansea - West Wales hourly DMU service will become two groups Manchester-Cardiff and Swansea - West Wales. However political pressure form Pembrokeshire and Carmarthanshire will want to see through trains to Cardiff continue - the SDL could be a way for a limited service to run.
That's pretty much as I think it should be, Manchesters terminating at Cardiff or Swansea and seperate local services from Swansea to Carmarthen/PEMBS/HOWL. Hopefully this would also mean Manchesters can be formed of longer trains since there would no longer be the issue of lighter loadings west of Swansea.
The number of through trains between Llanelli and Cardiff is now slightly more than hourly (with some HOWL trains extended to Cardiff etc. plus the evening Fishguard). Would a 2-hourly PEMBS-Cardiff class 158 over the SDL be enough of a through Cardiff service or is continuation of an hourly Cardiff service required?
With the current infrastructure improvements on the railway between Swansea and Llanelli, mainly the redoubling and works on the Loughor bridge, will this have an adverse effect on the Swansea District Line?. I know there was talks of "rationalizing" - by that I assume singling the route or stretches of it but also there was/is aspirations to see a passenger service restored.
Network Rail mentioned rationalisation of the SDL west of Llandarcy in one of their documents, but that was published some time ago and I haven't found any updates on the suituation. It wasn't clear what for 'rationalisation' would take though, it could be cutting down signaling, linespeeds etc. rather than reducing double-track to single-track. I have seen no 'official' asperations for using the SDL for passenger trains.
The SDL does seem a bit neglected but Swansea seems to have cared little about its rail infrastructure in the past even to the extent of promoting an Act of Parliament to abandon the Mumbles Railway. It is astonishing for a place with a population of about a quarter of a million has no meaningful suburban services. The whole place is drowning under road traffic.
Stations at Morriston and Llandarcy should be well used. As for the Maesteg service, from what I've heard, it is likely to be combined with Ebbw Vale. It seems that both lines will be wired as part of the South Wales Main Line.
The SDL is not really part of Swansea's rail infrustructure. It bypasses Swansea, just as roads bypass some settlements along their routes. In terms of local Swansea connectivity it does not appear very useful. However, because of this it provides a route which, if used, would leave rail at much less of a geographical disadvantage against the M4 + dual-carriageway to Carmarthen.
Perhaps the report you're thinking of is:
http://www.chartist.demon.co.uk/rdsw/sdl.pdf
Published by railfuture in, I think, 2005. Interesting reading.
I've been sent a draft of the new railfuture developement plan for Wales, it contains a suggestion for an hourly Intercity service from London Paddington to Carmarthen!
Network rail have suggested cutting back the swanline so that it only runs between Swansea & Port Talbot Parkway when the Maesteg service goes half hourly. This would be a major mistake in my opinion since a lot of passengers want to go to Cardiff.
Of course now that the wires are going to reach Swansea perhaps emu's will be easier to path
I think the Swanlines only running to Port Talbot idea was in the SWWITCH rail strategy study. However, I no longer have a copy of that sadly and SWWITCH don't either. They would like an updated study done but have no funds available for that purpose. Anyone here good at business cases etc.?
But thats another story. An extra train a day would be good and in an ideal world rebuilding a section of line from the SDL to Gowerton and then on to the West Wales main line to get HOWL trains into Swansea would be a superb scenario!
The only reason for not rebuilding the line you are talking about in my opinion is the loss of trains to serve Bynea and Llangennech. A tram network for Swansea, using low-floor dual-voltage tram-trains (all stops would be new for the trams, but sections of heavy rail would be used and electrified at 25kv AC so they don't block future heavy rail electrification.) could use street running to serve Bynea and Llangennech, and link Llanelli bus station and Parc-Y-Scarlets to Llanelli heavy rail station.
A 2 hourly service would be good on the heart of wales line with a hourly service during the peaks between Llandovery & Swansea & Llandrindod - Shrewsbury.
I have seen how terrible traffic is around Swansea with being stuck on buses which are running late because of congestion.
After electrification west wales services should run to Swansea where they will terminate with Manchester services being cut back to Cardiff Central.
That said there should be an hourly/2 hourly Milford Haven - Cardiff - Gloucester service which would use the Swansea district line perhaps using some 2 carriage class 175's if ATW get additionaal dmu's or use displaced class 150's from the Cardiff Valleys. A station near Llandarcy and Morriston would help relieve some of the congestion on the local roads and the M4 as well as on services running out of Swansea High Street station
I think Cardiff - Gloucester/Cheltenham is more of an outer-suburban route, so class 170s or 172s, maybe even 150s, would be appropriate, whereas Cardiff - Llanelli - Carmarthen - PEMBS via the SDL would be a regional express service and must use either 158s or 175s.
Nice as it would be a 2 hourly service realistically just ain't gonna happen nor an hourly from Llandovery.....at least not for a LONG time. The best that could be hoped for in the shortish term is an extra through train plus/or a short working into Swansea.
In my opinion, the current four trains a day is plenty for most of the stations on the HOWL, and there should be no more all-stops services. However, I think a few of the busier stations should have at least a 2-hourly service, if each station call costs 2 minutes then the additional services with reduced calling pattern would have a similar journey time to Shrewsbury as via Cardiff. If anyone knows just how fast you could time a limited-stop service, please let me know. Because of the vast difference in timings, you couldn't make it clockface 2-hourly, in fact you might end up with some 1-hour and some 3-hour gaps, but the nearer to 2-hourly the better.
What about some kind of MGR service - Swansea - Llanelli - Bynea - Llangennech - SDL New Stations - Port Talbot - Baglan - Briton Ferry - Neath - Sgiwen - Llansamlet - Swansea?
The only local Swansea connectivity use I could think of for the SDL was Swansea/Llanelli - Bynea - Morriston (new station) - Swansea Docks (new station) and Ammanford - Morriston (new station) - Swansea Docks (new station) services, using both the SDL and the freight only line that comes off it. However, when I've suggested this in the past, conerns have been raised that it would not be attractive as it is too curciutous a route (like HOWL - Swansea via Llanelli) and doesn't get you to the central Swansea (High Street) station. I think the Swansea Docks station would be just east of Fabian Way park and ride.
If we had 3-car class 377 EMUs for the electrified ValleyLines (or any EMU with usable through-corridor connections between units in multiple) if you could save paths by running:
- Hourly Swansea/Maesteg - Ebbw Vale all stations service, join/split at Bridgend
- Hourly Swansea/Maesteg - Bristol Temple Meads service, running non-stop between Bridgend and Cardiff and calling at Neath, Port Talbot and Pyle only west of Bridgend on the Swansea portion, join/split at Bridgend
That does mean the stops between Bridgend and Cardiff only have an hourly service, but hopefully leaves plenty of room for non-stop Llanelli - Port Talbot services from Carmarthen/PEMBS, plus services from Morriston/Llandovery to Cardiff and the PAD - SWA services (would be nice if a second semi-fast (not calling at Pyle) could be retained between Swansea and Cardiff also)
