Four trains per hour out of a theoretical capcity of 15tph and you still don't think it will all fit?
It is not so simple, I'm afraid. While there is a theoretical capcity of xx trains per hour over a given route or section of route, you also have to take into account:
1. A slow, stopping service will take up more than one path compared to a limited stop or express service
2. Freight companies are guaranteed a certain amount of paths, even if they are not used every day.
3. Junctions and conflicting movements impact on the ability to timetable trains as efficiently as would be the case if the line was direct from a to b with no trains joining or leaving the main line.
4. Timetables will have to allow for things going wrong in order to be robust. This will further reduce the number of paths available compared to the theoritical limit.
5. Sections of single track in West Wales will also constrain the times that trains can use that line, which will also impact on the efficiency of timetabling on other sections.
6. Platform capacity at key stations will also come into the equation.
It's not just about headways and signalling!
As far as the evidence above is concerned, that statement applies to north Pembrokeshire. However, I surmise that the same would be true of other Pembrokeshire branches, since I suspect all three are largely beyond commuting distance of Swansea.
I would suspect the same. Which means that Cardiff is well beyond the commuting distance. Realistically, how many people, that are not currently using rail anyway, are going to be attracted to a quicker train from Haverfordwest on a Tuesday lunchtime at 1300? How big is this market in total anyway? Road and rail combined?
The real benefits of the rail link to these areas are the ability to reach other parts of the UK. If someone is travelling from Darlington to Manorbier, as someone I recently spoke to on a train out of Swansea was, a 15 minute journey saving is not going to have much effect on their overall journey time.
I
n which case maybe that goes to show that Arriva felt the links between Carmarthen and Cardiff were lacking, whereas links to Swansea were not.
I can accept that links between Cardiff and Aberystwyth were lacking. It is a tortuous journey by rail via Shrewsbury, and the journey via Swansea is little better. There is also an advantage in that the bus from Carmarthen to Aberystwyth can serve relatively isolated communities inaccessible by train. Similar to the car driver, once someone has a direct bus service from down the road, that goes to a big city, there is little incentive for them to get off the bus and then change to a train.
The journey profiles, markets and economics of running a bus service once or twice a day between Aberystwyth and Cardiff are completely different to running an hourly train service as you propose.
I would be cautious in concluding that the diversion away from Swansea supports a similar diversion in rail services away from what is a large city by Welsh standards. If you include Neath as well you are talking about an even bigger population than Swansea and Gower.
Sounds unlikely maybe, but if modal shift from cars to public transport is the aim it is something that needs to be solved. There are pepole who drive to Port Talbot Parkway to cut their journey time, can't we get them to drive a shorter distance (or, better yet, get a bus) to Whitland or Carmarthen? Examples here, here (a comment near the bottom) and maybe even a former MP for East Carmarthen and Dinefwr (though I don't know where he drove to Port Talbot from).
I am not against increasing public transport usage at all, but surely the current bus services are not really adequate to entice anyone out of their cars? Especially in the Carmarthen and Whitland areas?
If someone is driving to Port Talbot at the moment, that is probably as much to do with the easy access of the station there to the M4 as it is about anything else. I can see why it would be advantageous to drive to there compared to Bridgend or Swansea, which requires a horrible drive through roads snarled up with traffic to reach the railway station.
Even with a journey time reduction of 15 minutes, I doubt it would convince anyone who currently does this to drive to somewhere else, far less use road public transport, which many people consider dirty, smelly, late and overcrowded, regardless of the actual facts.
I am aware of people who drive from Llandeilo and Llandovery to Neath and Port Talbot as this is a good way for them to connect into the rial network, given the sparse service at their local stations and the geography of the HoW line. It is a sensible thign to do which will not be remotely affected by diverting traisn to the SDL.
Getting a seat as actually another important factor here. While you probably wouldn't fill more than two or three coaches west of Swansea, a train of that length is not enough between Cardiff and Swansea. Having nearly all through trains from S.W. Wales to Cardiff avoid Swansea means passengers for S.W.Wales have a better chance of getting a seat on the train out of Cardiff, rather than finding it full of passengers for Bridgend, Neath and Swansea (it'd still have Port Talbot passengers on it though, as it'd need to call at Port Talbot to pick up passengers from Bridgend wanting to go to S.W.Wales).
I agree with this. It can be a problem getting a seat on the current through trains between Cardiff and the west, and dropping Bridgend, Neath and Swansea calls would probably help to relieve some of the overcrowding.
However, the facts seem to indicate that the volume of passengers using direct services, at least at off peak times, through from Carmarthen and points West to Cardiff, are not sufficient to warrant such a service without the calls that you want to omit. When the trains ran via the SDL during the line closure for the Gowerton redoubling, far more passengers alighted from SW Wales trains for the bus connections at Llanelli to Swansea, than stayed on the train to Cardiff. There were some passengers who remained on board, but barely enough to fill one third of a class 150 on average over the two weeks of traisn that I saw and used.
To be a bit more positive, I think that direct services over the SDL will come about one day, but it will not be until there is a radical rethink about public transport, and when the cost of motoring has risen further to a level where people are actively seeking out a viable alternative to their cars.
As Gareth Marston has said, the demise of cut price air travel can be seen on the horizon, and this will help to restore Fishguard's status as a busy entry point to the Emerald Isle as in times past. But I feel we are at least ten years away from that point.
