Juniper Driver
Yeah, I get that, but it seems to be a waste to get rid of 529 and 530.It's 8 units. All of 458529-536 go off lease.
Why? When the fleet was specified it was based on a specific requirement for the Pompey direct, as 12-car formations. Presumably the intent was 8 x 12-car formations with four maintenance units on top. Taking an extra two units is no help - if you need four maintenance sets for 24 in traffic, then you can't run 27 in traffic from 30.Yeah, I get that, but it seems to be a waste to get rid of 529 and 530.
Likely when they run out of milesDoes anyone know when 529-536 go off lease?
Are they planning to use them on the Pompey direct now?Why? When the fleet was specified it was based on a specific requirement for the Pompey direct, as 12-car formations. Presumably the intent was 8 x 12-car formations with four maintenance units on top. Taking an extra two units is no help - if you need four maintenance sets for 24 in traffic, then you can't run 27 in traffic from 30.
The waste would be to spend money on leasing and refurbishing trains that you don't have a use for... although you might say that applies to the entire 458/4 fleet now!
It does seem that a lot of money has been spent making the /4s less suitable for their current role than they were as /5s. Though I still have a faint hope that they might eventually displace 450s from the Direct.The waste would be to spend money on leasing and refurbishing trains that you don't have a use for... although you might say that applies to the entire 458/4 fleet now!
At least they're being used for something, which looked unlikely at one stage.Are they planning to use them on the Pompey direct now?
Just seems a waste while they are so short of trains.
They do change their minds all the time, so it seems, and they are using them on the Windsor side now, as we all know.
They ran to Reading as 458/0s back in the day. Presumably the changes to allow the higher speeds aren't as simple as undoing whatever was done during the 458/5 project then?I am sure that I read in this thread that the 458/4s are not permitted to operate between Bracknell and Reading as they are out of gauge because of the stiffer suspension installed during the refurbishment to support the proposed faster running on the Portsmouth Direct services.
8531/4 have already.Does anyone know when 529-536 go off lease please?
I would imagine it's a paperwork issue, or it's a new sub class so needs clearing again. I don't see why they couldn't run, as they had the yaw dampers from new.They ran to Reading as 458/0s back in the day. Presumably the changes to allow the higher speeds aren't as simple as undoing whatever was done during the 458/5 project then?
Although the 458/0 had yaw dampers, the 458/5 had a different coupling beam and gangway with more weight on the front eg the leading bogie under the cab has former motor axles (without gearboxes) because of the extra weight. Now take the five car and make it 458/4 and add yaw dampers and it's a different configuration again, plus any other changes to ride heights that there may be.I would imagine it's a paperwork issue, or it's a new sub class so needs clearing again. I don't see why they couldn't run, as they had the yaw dampers from new.
The 442s were going to be 8 pairs/2 spares for maintenance, so exactly as you say the 8 throuples to replace the 8 pairs and four in maintenance.Why? When the fleet was specified it was based on a specific requirement for the Pompey direct, as 12-car formations. Presumably the intent was 8 x 12-car formations with four maintenance units on top. Taking an extra two units is no help - if you need four maintenance sets for 24 in traffic, then you can't run 27 in traffic from 30.
I think it is 458402, 458403, 458404, 458407, 458417 and 458419 - is this correct?
Thanks458403 is in service, but 458414 has not yet re-entered service yet. I have the current 458 fleet status as
458/5 In service (5)
458529,530,533,535,536
458/5 Off-lease, out of miles (3)
458531 25.06.24 (Long Marston)
458532 02.09.24 (Wimbledon Park)
458534 25.05.24 (Long Marston)
458/4 Completed and delivered to SWR, but yet to enter service (6)
458402,404,407,414,417,419
458/4 In service (21)
458401,405,406,408-410,412,413,415,416,418,420-428
458/4 Out of service (1)
458411 17.12.24 (failed Waterloo prior to 2V51)
Please share! Pre-456 & 707 withdrawal, 12-car 450s on the PDL were very common. Now it's mostly 8-car.Hi all, thought I should just ask before I make a new post without any prior context, has the discussion about the lack of PDL and 12 car working come up in the thread before? Is it a topic worth discussing? I may have some valuable information!
The end coaches on 458s are 21m rather than 20m. This would make a 12-car formation up to 6m longer than the equivalent 450 formation. A pretty fundamental thing to have missed, if that was the case.Yes but you’d have to dig back a good few pages.
Essentially 12 car 458/4s are longer than 12 car 450s, and so I would imagine there is insufficient signal sighting at a number of terminus platforms.
This was indeed one of the first issues, however it was discussed for the international platforms at waterloo to be extended.Essentially 12 car 458/4s are longer than 12 car 450s, and so I would imagine there is insufficient signal sighting at a number of terminus platforms.
The problem there is that the main lines cannot be accessed from P20-24. Even the Down Windsor Slow can't be accessed. So that wouldn't have worked.This was indeed one of the first issues, however it was discussed for the international platforms at waterloo to be extended.
Sounds like a pretty conclusive show-stopper to me.Interestingly the main reason 458/4s are only 8 or 4 car units is due to the power outage of the units. As /5s with an extra trailer car they had significant changes in performance. Early Last year a 458/4 12 car was indeed tested on the PDL but due to the sheer power pickup for the motors it actually tripped the electrics for the whole Havant Region.
The Traction control electronics for the Class 458/4 reverted to the original 4-car Class 458 current draw limits, as agreed with Network Rail's power supply engineers. The Class 458/4 type test programme in October/November 2023 demonstrated that the trains performed in accordance with this specification. Following initial testing in 8-car formation there were multiple test runs on the Portsmouth main line in 12-car formation.This was indeed one of the first issues, however it was discussed for the international platforms at waterloo to be extended.
Unless they were planning to use the ladder at Queenstown Road which would facilitate this.The problem there is that the main lines cannot be accessed from P20-24. Even the Down Windsor Slow can't be accessed. So that wouldn't have worked.
Imagine the disruption that would cause! But then again it's crazy enough to be an SWR idea!Unless they were planning to use the ladder at Queenstown Road which would facilitate this.
I apologise to the Mods and others if I am seen to be veering OT, but am just following on from comments read:Imagine the disruption that would cause! But then again it's crazy enough to be an SWR idea!
From what I'm told they are indeed looking to test them up that way soon.Can we expect to see Class 458/4's on Reading services? I'm getting fed up with seeing Class 455's still being used
I'm even more fed up with travelling on the things!Can we expect to see Class 458/4's on Reading services? I'm getting fed up with seeing Class 455's still being used
Good!From what I'm told they are indeed looking to test them up that way soon.
Testing is one thing, actually getting approved to run (and then diagrams being put in) is another! I'll believe 458/4s going to Reading in passenger service if I see it happen with my own eyes!Good!
