jnjkerbin
Appears to be a fairly significant fire on some sort of OTM, just south of Dunton Green station. At least 5 or 6 fire trucks in attendance + police.
Looks like an MPV to me. It'll be a write-off for sure.
It’s definitely a Balfour Beatty Matisa one of the B-66uc’s I thinkCab looks a bit like one to me, but I stand corrected. Thanks, @DarloRich
now its a O-ffuc’dIt’s definitely a Balfour Beatty Matisa one of the B-66uc’s I think
Apparently this was started initially by leaking hydraulic fluid. This has leaked onto platforms as well at the station.
Why's that?Highly unlikely to be started by a hydraulic leak.
But if it is spraying over very hot components ( engine/ running gear/brake pads, or all sorts of gubbings on a tamper it can lead to a fire.) Reports of fluid all over the platform could show some kind of high pressure leak.hydraulic fluid has a very high ignition temperature, that's not to say it wont help once the fire is hot enough.
As far as can be seen by evidence above the vehicle was out of the platforms at the time of the incident.
If it is a Mattisa you might have to ask them to ring Switzerland and send new one over.I'm sure our friends at West Ealing can supply a replacement if required.
West Ealing is Plasser isnt it?
There were no engineering works on this section of line last night, and the time of the first call (as reported by Kent Fire & Rescue here) would suggest that this was the train involved, which seems to have been returning from a worksite near Lower Sydenham.The components on that machine that would get hot enough to potentially create a fire risk are all enclosed in a fireproof 'room', separate to the majority of the hydraulics, hydraulic tank, fuel tank etc etc. The brakes would generate very little heat especially when the machine was working (although we don't know if it was working or not). The traction is hydrostatic so a lot of the hydraulic system is working under high pressure whenever the machine is moving. For a component to run dry for long enough to overheat to the point of catching fire would be pretty much impossible without the crew noticing and/or being notified by an onboard alarm. Any leak seen could be a coincidence, it could have been a fuel leak, it could have been leaking from a component already damaged by the fire in the moments before the crew realised etc etc. It's not impossible that a hydraulic leak has caused the fire but it is highly unlikely.
All correct
Not when it's in aerosol form from a pin hole in a high pressure system.hydraulic fluid has a very high ignition temperature, that's not to say it wont help once the fire is hot enough.
Was the damage to the track minimal then? I see service resumed around lunchtime.I attended this on behalf of NWRs route control to check the condition of any surrounding structures that may have been affected.
Obviously I can't say too much as it's under investigation but it's been towed to a yard for a joint investigation by Kent Fire/RAIB/BTP.
By the look of things it's a write off, but lucky in the respect that it didn't happen in Sevenoaks Tunnel.
The response by all involved was exemplary, and I managed to bump into my old fire crew which was a bonus.
The same effect can happen from a leak on the fuel injection system of a diesel. In both cases the very fine droplets absorb heat very quickly and ready vaporise to ignite easily compared to the small amount of vapour from even an ordinary spill of these liquids.Not when it's in aerosol form from a pin hole in a high pressure system.
