markymark2000
Just some background on integrated travel in Manchester. Integrated travel is made harder by councils and TFGM (or whomever is developing Metrolink extensions) and when easy opportunities are available, they screw them up.
Central Park has the bus termini but you can't access it from one direction meaning buses would have to spend 5 mins extra looping around roundabouts just to serve the station. Alternatively, a 2-3 minute walk to the bus stops for the 114.
Hollinwood had the 151 which wasted it's time going into the station despite bus stops 1-2 minutes walk away on the A62 and also on the side road Tweedale Way. The 151 has been rerouted recently to remove this integration (clearly it wasn't used).
Stretford, since the Trafford Centre shuttle went (hang on, integrated bus.... It failed and rarely had any more than a few people on. Most of whom ended up using the Mall bus stops, not the tram stop), no buses go into the station.
Trafford Centre and Oldham have got new tram lines, why aren't these linked to the bus stations?
If integration is so good, why does Manchester City Council want to push buses out of the city centre, the main area where people connect between buses and trams?
I could go on. Integration is generally nothing more than just a car drivers excuse for not using public transport and politician easy policy to get more people on public transport. Buses and trams serve generally different markets and even where duplication exists, people make their choice because buses have more stops so can stop closer to home but trams can be quicker. It depends on your journey.
It's hard to point to an integration success in the UK because there isn't really many of them. It's just an easy political game to play to benefit a few select people while those who make regular journey's end up suffering from longer journey times and a possible change of mode.
The 2 best examples of buses Vs trams on the same corridor is Blackpool on route 1 and Manchester 219.
135 is a good example but does have some exclusive areas and different routings.
Oxford Road is an easy target for trams but you quite clearly are ignoring the fact Metrolink charges a lot more for its fares than Magicbus and for all the other buses, they branch off into separate areas. Just because they share the same road out of the city, doesn't mean they are all serving the same purpose. Adding to that, Trams don't run 24/7 (as the buses do on Oxford Road) and since trams run on tracks, you will have fun at nights when parking on Oxford Road becomes a free for all.
