On the Trafford Centre Shuttle, there was a combined ticket. It was rarely purchased, hence the bus ceased. People preferred to get the 250/X50 direct from Piccadilly Gardens rather than faff at Stretford (or other direct buses from wherever they start their journey)
I think you're making a big assumption as to the reason it wasn't popular.
You've got a number of possibilities:
- Was it well promoted enough?
- It cost more than Stagecoach
- A lot of people had a Stagecoach weekly pass anyway and so their bus was free
- Faff about changing (your point)
If all else was equal, then I'm not sure it would necessarily have been quite as poorly used.
'Almost all'..... Hmmm... May want to check that. A large number of buses don't stop at Mumps. Those which do tend to be First buses (because of the depot there) or buses to the east. A lot of buses don't go there though.
In any case, Oldham bus station was opened, according to Wikilies, in 2001. That's something like 15 years before Metrolink got there. It isn't feasible to run the tram via the bus station, so the bus station is going to have to move. That'll take time to sort out, and quite possibly it might happen as a "planning gain" type matter if there is a major shopping redevelopment at any point soon.
216, you're right. Sorry. The Ashton line has the 216 running follow the whole line minus 2 stops on Lord Sheldon Way. If the 216 can run every 10 minutes and the Metrolink every 6 minutes and both make money side by side, why shouldn't they remain running together.
If that's a genuine full duplication, then yes, like Blackpool's 1 it should be withdrawn. There is no sense in having such duplication. With integrated fares (so there's no price incentive to use the bus) people would just use the tram. Yes, you might need to add tram capacity, but that's more efficient than using buses, as rail is good at moving large numbers of people.
Bolton to Manchester buses don't solely fulfil the role of getting people from Bolton to Manchester. Each route runs a different way linking people to different places. Whether it be Farnworth to Salford, Walkden to Bolton or Manchester to Swinton. People aren't all using buses for the end to end. The buses have a lot of different purposes and uses. Should we split the Bolton to Manchester routes into 3 smaller services (Bolton - Swindon, Farnworth - Salford, Walkden - Manchester) and ban anyone from connecting between buses to force them onto trains? Might as well do based off some of the ideology going on here.
I've said what I'd do with regard to west Manchester. If you look at Manchester to Bolton (very different from the line out to Hazel Grove, say), it's very much "beads on a string" - small and medium towns that have grown up around the railway stations - same as the Atherton line. Therefore, what makes sense isn't linear bus services, but rather dealing with things more locally in each "bead" - so town circulars timed to meet the train and integrated with the fare so those nice big 6-car EMUs can be used to shift lots of people, like they're good at.
Using your logic, why does London have any buses within the congestion charge zone? London is well equipped with the tube and trains to get people around. Reality is, people prefer choice.
One issue with the Tube is that it has somewhat of a capacity problem, so buses are needed to beef that up. The only viable way to solve that capacity problem is to build more rail - which is what Crossrail is about - but that takes time. In the meantime, some of central London's bus network provides that "beefing up" of capacity. When Crossrail (eventually) opens, I suspect serious consideration will be given to pedestrianising Oxford Street and Regent Street, because there will be the capacity on rail to take all those bus passengers (and more), for instance.
There are also parts of central London (which is the size of a medium town in its own right) that don't have a Tube station nearby, so there are those "super local" routes too.
Apart from that, quite a lot of London buses
do terminate at Tube and railway stations for interchange. You'll note that there isn't a "London central bus station", but rather a large number of smaller ones spread around the place for interchange.
Infact, looking at how often GoNorthWest are accepting Metrolink tickets, it's a good job that buses follow the tram lines since if no buses were available, people would be stuck on the outskirts of the city most of the time.
Hyperbole that does not help the discussion. If Metrolink wasn't running more often than it was then lots of questions would be being asked.
Yes, one advantage of duplicating rail with bus is that it provides resilience, but if your rail service is that bad then you really need to fix it. Unplanned RRBs on Merseyrail happens about never. OK, Metrolink's street running makes it a little more vulnerable, but there needs to be (and is) a plan for that, e.g. turning round at Vic, Picc etc.
There is certainly already a highly developed BRT route along the A580/A6 so some routes via Swinton and Pendlebury could easily be truncated at a convenient location for connections onto it.
The guided busway is a bit of an outlier, but I think for these purposes we can consider it to de-facto be a (rubber tyred) light railway, albeit one with a special property - those connecting buses don't need to connect at a station but can just run onto it.
I'd like and hope to see it converted to Metrolink at some point in the future, but it's probably low priority. However for now it does have that useful feature. That said, electrifying it (by way of battery buses) has to be an urgent consideration.
