TfW Class 170's
krus_aragon
10 Jun 2009
North Wales
I wonder, could the sluggish performance of the 170s make TfW reconsider whether they want to keep them in the long term (and perhaps keep hold of some 175s instead)?
Envoy
29 Aug 2014
Perhaps they should actually try a 170 on The Marches & The Heart of Wales to see how it copes with the gradients? (The 175’s unlike the 158’s could be used on the Heart of Wales).
DannyMich2018
19 Dec 2018
Class 170s were never meant to operate short distance largely stop-start services they running now on, they were designed for longer distance high speed routes where the slower acceleration is not so much a problem.
Anonymous10
19 Dec 2019
wales
Exactly why they should be regeared
craigybagel
25 Oct 2012
I can't help but wonder why if regearing is such a simple cure all for 170s, why has no TOC attempted it yet?
krus_aragon
10 Jun 2009
North Wales
The same might be said of the 175s, but they kept better time on the Maesteg route, according to @Mrs. Fortescue . Hence my speculation.
Bikeman78
26 Apr 2018
The 175s accelerate rapidly at low speed, the 170s do not. You have more chance of keeping time with a Pacer than a 170 on the Maesteg or Ebbw Vale lines.
krus_aragon
10 Jun 2009
North Wales
And in the longer term (post-2022), which would be better for West Wales and the Heart of Wales route? I'm suspecting the former.
craigybagel
25 Oct 2012
I suspect that what may be part of the issue behind 170 Vs 175 is that the number of ex Anglia 170s available (4 x 2 car, 8 x 3 car) matches more closely to what the TfW franchise required then with the existing 175 fleet. If TfW kept the same number of 175s as 170s they're taking and returned the rest to the leasing company, the latter would be left with an awkwardly small subfleet that it might be very difficult to find another customer for. By taking the 170s, they probably got a better deal by taking the entire Anglia fleet, and there's a larger amount of 175s available which may be more attractive to other TOCs.
I could be entirely wrong of course, but it's just a theory.
krus_aragon
10 Jun 2009
North Wales
It's quite plausible, and I felt it made good sense at the awarding of the franchise. But since then, 170s have become very sought after (see EMT and XC scrambling for all available carriages), and there's been no public expressions of interest in the 175s. We had some indications of TfW considering some additional services too, based on the open access applications we briefly saw last year, which might warrant a slightly larger fleet. Perhaps seeing the performance of the 170s in the flesh might give them even more food for thought.
(Or perhaps I've got a soft spot for the 175s, and would be happy if events conspired to mean they stuck around in Wales for longer.)
anamyd
17 Aug 2018
Has 170271 entered service yet...? And has any progress been made with the state of 170206...?
Mrs. Fortescue
1 Aug 2019
175s keep to time just fine, even the 150s did when there was the odd 150 on the trip from Holyhead (that the 1723 used to form part of prior to timetable change).
The 170s generally get to the first stop 2-3 mins late, getting to Bridgend 5 mins late - that’s when they leave on time. I leave the train then, but it seems they get even later towards Maesteg.
craigybagel
25 Oct 2012
Very fair points, and I don't think anyone at TfW would be surprised or disappointed if the decision was made to keep 175s rather then 170s. As I've pointed out before, TfW have been a lot better at being flexible and trying to find alternatives then their predecessors ever were.
I'm not surprised by the 150s - up to about 60 they'll out accelerate a 175, and that's even before you take into account the reduced dwell times with the different door layout.
A potential solution is already being worked on - a diesel-battery hybrid engine which can be retro-fitted and should presumably improve acceleration at low speeds.
https://www.porterbrook.co.uk/innov...rterbrook-launch-first-uk-hybrid-rail-project
A great idea on paper, but given Porterbrooks past record on converting trains (see the 769 thread) it's hard not to remain skeptical. It's also worth pointing out that the Wales & Borders franchise already has experience with a unit with an alternative transmission, 158834 and it's 4 speed DIVA. A unit noteworthy for the fact that 4 years on its still the only one in the entire fleet that has had the mod, which is hardly a vote of confidence....
craigybagel
25 Oct 2012
271 was in service for a few hours this evening. 206 is buried deep inside the shed at Canton and dorsn't look like it will be out any time soon.
FLIRTfan18
11 Mar 2020
Wolverhampton
It strikes me that the 170s have been brought in for the sake of being able to claim that the whole fleet is being replaced - which would have been a significant factor in winning the franchise. So perhaps what we're seeing is the 175s leaving not because they're any worse than the 170s (I would actually suggest they are better in every way excluding the door positioning), but because they were there at the start of the franchise and promises must be kept (even if they don't actually yield any improvement whatsoever, but that's the franchising system for you).
PHILIPE
14 Nov 2011
Caerphilly
The 170s were brought in to replace the Pacers (via Cascades and deployment) and any stock that was available had to be transferred to TFW
krus_aragon
10 Jun 2009
North Wales
The 170s would still have been needed to cover the gap between (eventual) Pacer withdrawal and the arrival of the new-build stock in 2022.
Once those arrive, it's just a case of choosing whether to keep the 170s or 175s: that's where the soundbite of "total fleet withdrawal" can come into play.
FLIRTfan18
11 Mar 2020
Wolverhampton
Yes that is what I was referring to as opposed to them replacing the Pacers. My interpretation is that the (perhaps arguably) better units are the 175s but the 170s will be favoured because of the whole "total fleet withdrawal" pledge.
PHILIPE
14 Nov 2011
Caerphilly
There is work planned for the 170s once new trains are in service and the 175 work will by and large be covered by the new CAFs and rendering them redundant. Mind you, things can change.
Mrs. Fortescue
1 Aug 2019
Interestingly - the 1723 service was run by a 143 last night and it got to Bridgend quicker than the 170 did the day before.
Hell of a lot bumpier, mind!
BBob123
13 Dec 2019
Bristol
Only half the fleet of 170s seems to be being used at the moment. I spotted about five passing Canton the other day. :?:
Murray J
10 Aug 2019
East Grinstead
They don't seem to be very fast on stopping services either. If they're cleared for the route, refurbished 158s would be better temporarily.
