Thameslink collapse
bengley
18 May 2008
All trains between Bedford and Farringdon are at a stand - I suspect that is a lot of trains trapped.
All Line Rover
17 Feb 2011
Well it's certainly been a lovely evening on the railway today. I can't remember the last time so much disruption was listed on NRE - particularly for June.
  • NRE.pdf
Kite159
27 Jan 2014
West of Andover
Last couple Nottingham to St Pancras services were cancelled, I suspect local taxis will be in demand tonight.
Tomorrow morning will be interesting with stock out of place
Rich McLean
6 Feb 2012
That's if things get moving at all until around mid morning
tsr
15 Nov 2011
Between the parallel lines
Looks like some signalling has been restored now. Unsure as to the extent of resolution at the moment. Some trains seem to be moving on my signalling map.
MrCub
23 May 2009
SE England
Is there an obligation, in the event of a service collapse, for a TOC to get you to your destination, or can they leave you 'stranded'?
Antman
3 May 2013
It's a DISASTER. How on Earth do people get home?
By road transport arriving home sometime in the early hours looks like the best that they can hope for, this must be one of the worst days ever for rail disruption in the south east?
howittpie
11 May 2012
Notice at least one St Pancras to Derby service was started at Kettering this evening. There was few at Loughborough awaiting the 21.24 to St Pancras unaware of the problems further south as the boards were showing delayed and the announcement being due to electrical supply problems so no clue to the problems further south.
Either get you home or provide overnight accommodation as per National Rail Conditions of Carriage.
greaterwest
23 Nov 2014
I'd imagine so, I haven't seen two code blacks declared at the same time (Victoria - Croydon and Waterloo - Surbiton) and I think the last bad incident was the displacement of the third rail at Clapham Junction a year or so ago which resulted in the shoes being ripped off several units, and many trains being de-trained.
GadgetMan
9 Jan 2012
Ouch - https://twitter.com/TLRailUK/status/746085309197225985
We are sending staff to trapped trains as a priority. ⚠️ Services between Bedford & Blackfriars have been suspended for the rest of the day due to a complete loss of signalling
All the DOO lovers/TOCs keep trotting out the MOM (NR Mobile Ops Manager)/BTP/Father Xmas would all be at the location within 20-30mins after an incident. Glad to see they're all correct. :roll:
Antman
3 May 2013
Reported on twitter that trains are now running again between Blackfriars and Bedford
bb21
Emeritus Moderator
4 Feb 2010
The last Code Black was the Vauxhall fire.
LowLevel
26 Oct 2013
It's a grading.
Green - Yellow - Red - Black - Blue
Green is minor delays
Yellow is moderate delays
Red is major delays
Black is effectively service suspension, job stopped
Blue is a serious incident generally involving the intervention of the emergency services with a train service following a collision or similar.
greaterwest
23 Nov 2014
It's a grading.
Red is major delays
What was the last Code Blue to be declared in recent years?
tsr
15 Nov 2011
I'm not sure my employer even has a Code Blue! Last time I looked at the classification of incidents, which wasn't too long ago, certain types of rail accident lead directly to a Code Black, but I'm pretty sure we don't do Blue at all. I don't decide what leads to a declaration of any given colour code, but I'm aware of the rough classification and I do work with them on a pretty much daily basis.
For us, from memory, our PIDD (Passenger Information During Disruption) colour codes are:
Green - no/slight delays but a known fault which may affect multiple trains (an example of disruption with "no delays" could be, for example, SSOs issued due to some trains not to call at a station due to equipment issues) - one or two isolated delays up to 15mins
Yellow - full closure of stations in certain categories, line problems leading to congestion and delay which can often be accommodated by normal service resilience - pattern of repeated delays up to 15mins
Red - line problem caused by station closure (eg. evacuation of a major interchange leading to crew changeover and passenger movement problems), partial mainline or full branch closure - delays in the region of 15-30mins
Black - full mainline route closure, derailment of higher speed services, loss of signalling at a critical location, phased shutdown/delayed start due to severe weather - multiple trains stranded/trapped - delays 30mins+
CSL2 (Customer Service Level 2) is usually declared at Red and beyond, invoking ticket acceptance per pre-set plans, highlighted website information and recorded announcements detailing journey options, and so on. In addition, for each type of line capacity issue, numbered plans are used to define the service which can reasonably be run, though in fact this is often quite vague because of train and crew displacement and so on.
Alfie1014
27 Jun 2012
Essex
*Three
St Pancras is also code black this evening
Four, GE pretty much shut for much of day too, and not much better today with a limited service of only two main line trains per hour and do not travel advice until after 14:00 in place. TfL rail not much better limited to 2 tph too, plus there have been difficulties getting stock out of Ilford as the loss of signalling area covers Manor Park to Seven Kings.
