There is a lot of waffle on this thread about eliminating drivers, the chances that this will happen in the near or far future are less than zero.
I have mentioned this before but it is worth reiterating. ATO on Thameslink and Crossrail core IS NOT about getting rid of the driver, it is all about consistent and therefore predictable inter station run times, required in order to reliably maintain the specified 24 trains per hour.
Let’s also look at the practical issues with adding ATO onto a train, something that is relatively easy to do if a new train is designed to include it, but I will start by looking at ATP/ETCS interfaces on the train.
Space is required for the electronics, and as on the Cambrian Coast 158’s this is not small but size will or even may have come down, it depends on the supplier. Speed and distance measuring devices, axle end tachogenerators, Doppler radar and Balise reader need space and wiring back to the electronics as does the driver interface.
How does the ATP interface to the train to do its job of stopping the train if an unsafe condition occur, well that’s quite simple. The ATP/ETCS operates an Emergency Stop Relay (ESR), contacts of which are cut into the trains emergency brake circuit. If the ESR deenergises for whatever reason the emergency brakes are applied and traction power cut off. Another relay, the Zero Velocity Relay will energise when the train is at a stand permitting doors to open etc.
There is more to this than I have described but you get the gist, however the ATO interface is rather more complex. This requires direct control of the traction and braking systems, the shear variety of such systems on the U.K. rail network presents a significant challenge. There is really no case for eliminating the driver is therefore unlikely to happen soon if at all. But read on.
Unattended operation, that is with no staff on board, is great for the mass transit market where public access to the track can be made secure, requiring Platform Screen Doors at stations and robust fencing on above ground sections. If this is not possible or prohibitively expensive there is no advantage in removing the driver, and except from high density service areas there is little to be gained with adding ATO.
