4-SUB 4732
- Joined
- 7 Jan 2018
- Messages
- 2,150
How do you deal with the thousands of people who will then need to change at Herne Hill ? The station isn't big enough and wouldn't be able to cope. It is bad enough already.
Not sure Orpington needs to grow. There is a Southeasten and GTR depot located there. The GTR depot already signs Sevenoaks via the loop and main as well as signing diversionaries into Vic. The Southeastern Drivers at Orpington also sign the route. Are you suggesting they merge the SE and GTR depot ?
Possibly the only important bit tbh. The trains to Blackfriars from Tulse Hill are rammed in the peaks and well used off peak. The Orpy Vics are already at capacity and services up from Orpington/Bromley are an essential commuter route into London. You also need to consider those who access Elephant and Brixton for the Tube. Any change to services will cause a massive shift in passenger flows.
If you are going to cause a significant shift in passenger flow, doing it at a station where you can undertake cross-platform interchanges is probably the place to do it.
The unacceptable 8-car 700s (I still maintain this was a stupid idea ordering them and using only 8-car capable routes) plying the route from Sutton, Wimbledon (etc) to the Thameslink Core is the problem. If you want to cause a shift, the use of 10 car units is most sensible. People can still get to London Bridge (in theory you could operate 8tph up to London Bridge from Tulse Hill), and it’s ripe for expansion to provide that connectivity at a station much better suited to higher passengers loads as well as encouraging further modal shift onto Overground at Peckham. People will find a way to work and as people are using the railway that bit less now seems the time to consider it.
Orpington I would suggest should be a Thameslink only crew depot as you’d have all trains staffed by crew there going up to Blackfriars (via Beckenham or via Catford), as well as all the siding space given over (along with Bellingham and Sevenoaks). Legacy Beckenham Junction services could be operated by Southeastern resourced out of Victoria or Grove Park; and the ‘daytime’ stuff from Victoria to Sutton etc via Herne Hill would be a Southern problem.
Grove Park drivers (along with Charing Cross, Slade Green and Dartford) would therefore be responsible for stuff between Sevenoaks / Orpington and London (Cannon or Charing Cross). The trains mostly stable there anyway or could do - it’s a logical step towards better consolidation of crew and higher yield of productivity.
