Does anyone know if the ABC Rail Guide is still available, or if not, when it was last published?
I seem to recall seeing a copy of it about ten years ago, although I think by that time it was published by a company that was independent of Network Rail or the Association of Train Operating Companies. Presumably it was published under licence from NR and/or ATOC, though. Obviously in BR days it was published by BR itself.
Did you prefer to use the ABC or the all-line timetable (nowadays referred to as the National Rail Timetable) to look up train times? I suppose if you lived in or near to London and mainly made journeys to and from London, you might have found the ABC easier to understand, as it had all the stations listed alphabetically. For each station it told you which London terminus to go from and had the train times and fares to and from London. There were also full timetables for most lines in London and the neighbouring counties at the back.
Also, does anyone know when the ABC was first published? Were there separate editions for each railway company before nationalisation in 1948 or was it published jointly by all the different railway companies?
I believe that there were also separate editions of the ABC based on travel from the other major cities such as Birmingham, Manchester, Liverpool and Glasgow.
