I guess it depends on what you consider an extreme measure. Personally, I would be in favour of a frequent flyer tax that taxes as soon as a person is doing more than a single return pair of flights a year tax increases rapidly with increasing numbers of flights. (I accept there are serious challenges in implementing such a policy)
I'd also be in favour of banning private jets, as their emissions are absurd when compared to commercial aviation (looking at a per-passenger-km emissions)
Another potentially useful policy would be to define an emissions cap for the aviation industry as a whole globally, that reduces absolute emissions year-on-year (probably starting with a 2019 baseline), as that provides strong motivation to actually implement efficiency improvements quickly, and where efficiency improvements fall short, flight numbers will need to be decreased. Of course, this does have the challenge of making global policy.
I don't think that something has challenges means it shouldn't be pursued though.
I'm also flexible with the actual policy instrument used to achieve it, and am very open to suggestions for this, as long as aviation (and all other sectors for that matter), does its share of reducing emissions.
Don't think I can argue with any of that, all seems to be sensible stuff. In particular the idea of an emissions cap for the aviation industry, set no higher than current levels and reducing year-on-year (or, at most, every 5 years), is a good one. An important provisio from me however is that this cap
must include emissions of non-CO2 greenhouse gases and biofuels etc. (remembering the stupidity of Drax...)
another way would be to apply a carbon budget to airlines as a whole, which decreases year-on-year to meet climate change needs, and let airlines work out whether they meet it through increased efficiency, reducing flights, or some combination of measures
As noted above, I like this idea (though perhaps not as much as a ban). However, it does leave cause for concern (which I have put in bold), what do we do if airlines fail to meet the required level of cuts?
More needs to be done to reduce net carbon emissions through carbon capture, using both technology and natural means such as reforestation, and cleaning up energy production. These are areas in which governments around the world have completely failed for decades, and emissions from everyday activities such as flying (or driving) are a convenient distraction from their failings in my opinion. (Again, that's not to say that nothing at all should be done in these areas).
I would argue that emissions from flying and driving can be added to the list of government failings, along with reforestation. Government has been telling us that we need to use our cars less and switch to public transport for years - from what I can see they have failed to acheive this (or at least failed to act in a way which encourages this).
I can't argue with the your maths(!), and I agree that in your example the "penalty" for taking two or three return flights probably wouldn't be prohibitive. That raises the obvious question though of what's the point in implementing it this way? I think it's more than likely that most people will simply "pay to pollute". To have any worthwhile effect it would need to be far more punitive in my opinion, which I can't say I'd be comfortable with.
Whilst pay to pollute isn't ideal, nor is having a hard limit and causing people to (for example) miss a loved ones last minutes (something for which people will pay a lot to try and do if they are able to) is arguably worse.
There could be ways to tax the airlines, for example they pay a tax if they don't have a minimum value of zero carbon fuel/energy use/reduced fuel use (which would likely increase as times goes on to encourage the use of technology).
A clear dilemma with most forms of 'pollution tax' is whether to design the system to minimise pollution (in which case a hard limit (or total ban) should also be considered) or to try and maximise revenue from the tax (which the state would, one hopes, spend on cleaning up the pollution). In the latter case, 'pay to pollute' would seem to be the way to go - let frequent-flying trillonaires pay to electrify the whole GB rail network, for example.
As for missing a loved one's last minutes, a suggestion I've heard is to have a voucher system where your limited quota of flights is transferable. Say, at the start of the scheme, every person is given 5 vouchers each valid for a given number of 'flight credits' (not sure how these should be set, given the different impacts of shorter and longer flights). You get an additional voucher every 5 years (or, if you want to phase it in, you could start by giving out one voucher a year and gradually decrease that until you only get one voucher every 15 years or more). Any flying beyond the vouchers you hold would either be outlawed or taxed at a level only trillonaires could afford. However, if you aren't intending to take any flights, you could also sell your vouchers to somebody who has used theirs, thus making this system more progressive than most alternatives.
I feel the biggest problem these forums have is that so many expect everything to be solved by rules and regulations. Taxing passengers for flying more than others won't stop them doing it.
So if taxes won't stop them flying, and we should be avoiding rules and regulations (such as a ban) what will stop people flying?
Targeting aviation is one of the fairer ways of tackling climate change because, as a rule the better off you are, the more flights you will take. So higher aviation taxes will predominantly impact the better off. In particular you have to be quite well off to afford business class flights and private jet flights. An extremely large tax on private jet flights therefore would be seen as a tax on the very wealthy.
Whereas banning ICE cars and new gas boilers tends to hit the less well off the most due to the current higher cost of electric cars and heat pumps. Hence why there has been so much controversy with these measures.
A good point well made. I'll just add that a ban on new oil boilers (not sure about gas) has certainly been (at least) strongly considered by the UK Government. Admittedly air travel is a global issue, whereas banning oil boilers can be done unilaterally - but has the UK Government been raising curbing air travel as a serious issue at the COPs (climate conferences)? If not, then how is it that leaving people unable to afford to heat their homes is considered to be worth talking about (or might even be Government policy for 2035 or something) while substatially reducing aviation is off-limits?
folk here wonder why environmentalists are finding it harder and harder to gain public traction. If you want to make a difference find a way to implement changes without mucking many people's lives out.
If I understand correctly, you are highlighting an important point here. It all fundamentally comes down to the need to
REDUCE greenhouse gases in the atmosphere, and to a degree we have done the easy stuff (such as switching to more-efficient lightbulbs). This was not enough to solve the problem and are left with a need to reduce air travel, switch from cars to public transport and active travel etc. - stuff that impacts people's lives. That's clearly going to be a harder sell, both emotionally (for indivduals) and financially (for governments and maybe economies), and I'm not sure how we can do that.
The French might riot. British people wouldn't, it's just not in our culture.
I'm not sure about that. Having seen how some climate protestors have been angrily man-handled out of roads, and the reports of Mark Drakeford MS and Lee Waters MS having recieved threats over the implementation of a default 20mph speed limit in built-up areas of Wales, I wouldn't say riots are an impossibility. I really admire the protestors who just sat back and took it - all it would have taken is for one of them to start fighting back and a peaceful protest could have developed into a big fist-fight.
Aviation is 2% of global emissions IIRC. That's more than some tiny islands.
I think those 'tiny islands' include the UK - our 'domestic' emissions being about 1% of global emissions currently I think.
Cycling is ideal for journeys between about 1 and 4 miles for most people (under a mile and getting the bike out and locking it up takes longer than walking). Ten miles is for the superfit and time-blessed.
I think Dolgellau-Barmouth is about 10 miles; yes it wouldn't be something that (m)any would consider to be a
journey as such but as a lesiure activity in itself I would argue that you don't have to superfit. Of course, as a lesiure activity the return trip would be by some other mode, so for something like a commute (where you have to cycle back again) the equivalent would be about 5 miles (each way).
For rural residents, park and ride at urban fringes is probably the best plan where a decent* bus service isn't viable.
* Hourly 0700-2300 ish is probably the limits of a genuinely useful rural/interurban service - below that and it becomes a distress purchase for most.
Park & ride yes, not necessarily to 'urban fringes' though - you could just park at the nearest point on an hourly bus route (and I was quite surprised by how small a settlement has to be to recieve an hourly service in some Swiss cantons (possibly all of them, I don't know) - I think it was on Tim Dunn's railway architecture programme that they even built a funicular railway to reach a place that couldn't be served by bus).
It’s not stupid at all - stupidity is getting sucked in by it all and in the process impoverishing this country and millions of lives here and abroad.
What about seeing that humanity's demand for ecological resources and services in a given year exceeds what Earth can regenerate in that year - and not being worried about that or doing anything substantial about it; is that stupidity?
My industry has changed already. Gone are the days of building high speed roads between two places which didn't have them before or the building of bypasses. Gone are the days of drawing boards. Gone are the old school engineers who could calculate bridges on the back of an envelope and create a design which was a few percent over designed.
The drawing boards may have gone, but at least in the UK the building of high-speed roads and bypasses continues. Even here in Wales, where much of the road building programme was paused to allow a review, several bypass and 'high-speed road' projects remain under construction, contracts already having been 'signed' before the review was announced. The review was announced on 22th June 2021, the contract for at least one high speed road scheme (complete with bypass) was "formally executed under seal on behalf of the Welsh Ministers" on 17th June 2021. That's less than a week before the review, that high speed road + bypass is now being built. The UK Government meanwhile may have stopped boasting of 'the biggest road building programme since the Romans' (or they may still be doing it, I'm not sure), but if they have it's only because (like HS2) they're not sure they can find the money to pay for them.
The recommendations of the Welsh road review should also be applied in England and Scotland - the building for more space for more cars must be stopped.
Unsurprisingly no-one is prepared to actually answer my question, and it is an important one. This is quite typical of the environmental debate in the 21st century, everyone wants to be seen to be doing the right thing, but nobody wants the responsibility of any effects changes might cause.
I wish all of you understood just what damage you are actually inadvertently causing to the climate debate. It isn't that people don't want change, but the lack of answers to everyday people from the environmental activists on simple everyday questions that make people cynical. Its exactly the reason why the climate policies are being dialled back in this country, and will be the reason that it will be in others.
Assuming you are talking about tourisim jobs, if I had the answers I'd probably give them to you. The fact is I don't know what to say other than we need to find those people other jobs - if we are to properly make the effort to tackle climate change there will be loads of vacacies that need filling (for example in the UK we already seem to have a shortage of bus drivers and many more will be needed to deliver the much-enhanced bus network needed to reduce car use). If that's not enough of an answer for you then I'm sorry; however I don't have a better answer than that for the people who are already losing their jobs due to climate change - my mother has recently returned from a trip around France (and possibly some brief forrays into neighbouring countries) - while in the Alps she noted a ski resort that has shut up shop because the snow season is now so short they were making a loss. (In case you're wondering she did
not travel by air). Unless there is a drastic turnaround, we could be heading for a future where ski tourism (at least in the Alps) becomes a thing of the past.
The “frequent flyer tax” thing that keeps coming up just seems like an idea to offload the taxes onto people other than those proposing it (it is insane that most proposals involve a tax cut for those taking a small number of flights!).
It's also insane that cargo aircraft (presumably) go untaxed, but that's an even harder one to solve. At least my suggestion of globally banning all in-flight emissions by civilan aircraft is a simple concept and impacts rich and poor alike. In terms of unilateral UK action, in the absense of the global action I feel is necessary, I'd probably support a 'frequent flyer levy' whether it gave you one tax-free flight at the start of the scheme or not. The tax-cut for the first flight wouldn't benefit me personally, since I don't intend to fly anyway, but might win some votes for a parlimentary candidate - making them more likely to actually get elected to implement the tax. That aside, keeping the tax on the first fight at the current APD level would be the better option.
And let's be honest here its generally not even about us. I remember the climate change protester on a motorway gantry declaring that "they are taking away my future". My, not ours. Said it all really. Anyone who really cares about reducing our impact on the environment also cares about what happens to people whose lives might be impacted by any changes we make. Sadly these people are few and far between, as this thread demonstrates.
None of you really care about the world, just yourselves.
Not sure about other environmental activists, but what I care most about (as far as my activism is concerned) is the
natural world and conserving biodiversity. I guess you could still argue that I'm doing it for myself, because ultimately if the food chain collapses me, my family and everyone else goes with it.
