I've kind of made myself clear on this issue way back earlier. But to clarify, I am against any kind of restriction on travel. That's it.
And let me flip it around, would you accept being limited to (for example) no more than 8 long distance (say 50+ mile) rail or car journeys a year? Because this is exactly the kind of thing forcefully limiting travel risks.
But in not saying to have a hard limit in the number of trips, you'd just find it would get more and more expensive the more trips you took after a given point.
However, (other than just because I've used 8 for flights before costs start rising) what's your justification for 8 trips of more than 50 miles?
Bearing in mind that I've taken the total number of flights in the UK, doubled that and then applied then equally across the population (even though a lot will be by people who aren't resident in the UK). As such the numbers taking 8 flights would be fairly low.
Looking at the data, in 2022 an average of 5 trips were made per person of over 100 miles (2 as a driver, 2 as a passenger and 1 by train), with a further 10 trips of between 50 miles and 100 miles (5 as a driver, 3 as a passenger, 1 by rail and 1 other), using the same "double the average" I've applied that would mean limiting to 30 trips.
However, even at the half the average (which would mean to be comparable flying would only allow 2 flights) for over 50 miles trips, it would be an annoyance but we'd manage.
Arguably, as a family (given those are per person values) as my children are unable to currently drive we'd have a few extra trips (but that's being pedantic and not in the nature of the debate).
However, the APD increasing by 50% proposal isn't a hard limit, so if my for fuel for each trip cost and extra 50% we'd reduce our trips but we'd still do more than 8.
For instance a round trip with a cost of £100 (so first 4 return trips would cost £400 on total) next return trip would be £150 (+£50) the following being £225 (+£125). If we normally did 8 (total cost of £800) and reduced it to 6 (total cost £775) we'd be no worse off, even at 7 trips we'd pay £338 (+£238) so compared to our normal 8 trips we'd have paid an extra £313, which would probably still be justifiable.
That would probably mean fewer trips, as it would be hard to justify the extra cost. However, that's on the total fuel costs. As a comparison APD for a family:
- of 4 would be £52,
- of 5 would be £65,
- of 6 would be £78,
- of 7 would be £91,
Therefore not only have you set the maximum number at half the rate I've used total fuel costs which would be higher than APD on a similar basis (unless I've got a family of 8!!!), even then we'd still do broadly the same as we currently do (and we do a fair amount of high mileage trips compared to the average as they would be >200 miles and not just >50 miles - although our total annual mileage isn't that high as we almost always walk for my work or getting the children to school).
Having answered your question (applying the same rules as I'm suggesting to aviation, as someone who does a lot of long distance travel by car the answer is that we'd probably manage with just 8 single legs before the costs ramped up and we'd probably still do 14 single legs before it stopped us), at what level do you think is reasonable?
I've even given suggested numbers to pick from, but shall we try again 12, 24, 50, 100, 225, 365 or 1,000?
(The numbers being every other month as well as three times the average number of fights per resident, every month, once a week, once a working day, ever day or over 3 times a day).
At what level do you think is reasonable?
