While that's a decent summary, it does seem to be taken from the maps produced at the time of the franchise award and some things changed by the time the Franchise Agreement was signed, as detailed in the Train Service Requirements. And no doubt things will continue to change. Here's a few updates on Calder Valley services.
Bradford and the Calder Valley
An extra train per hour will run from Bradford Interchange to Manchester. This will likely operate via Todmorden as services through Huddersfield (except the hourly service to Manchester Victoria) will be run by TPE.
A new hourly service will run between Leeds and Chester. We do know that this service will run through Hebden Bridge, but whether it serves Bradford or Dewsbury is currently unclear.
Similarly, a new hourly service will be provided between Southport and Leeds and/or Bradford.
It seems likely that at least one of these will serve Bradford to fill the quota of 3tph between Bradford and Manchester. If this is the case, two of the services will be extensions of existing ones. It is difficult to predict which way round the Chester and Southport services will be, but given the wording of the franchisement map, it seems more likely at present that Southport will be given a service to Bradford, while the Chester service will run to Leeds via Dewsbury.[
Indeed, there will be three Northern Connect services into Manchester with new rolling stock, extending to Chester, Liverpool and Manchester Airport and a 4th non-Connect service extended to Southport (operated by 170s). The franchise TSRs raise the possibility that the additional service will run fast from Hebden Bridge to Victoria, making full use of the 90mph upgrade to this section of the line.
Talking to Northern, I get the impression that the idea of the Chester service running limited stop via Brighouse in rush hours is now very unlikely, mainly because it would require an extra arrival at Leeds station (more of which later). So all three Northern Connect services will run via/to Bradford, with the Southport service running through Brighouse and skip-stop to Leeds.
If ever agreement is reached with Network Rail, the TSRs allow rush hour Chester services to run fast from Brighouse, with the rush-hour Victoria-Huddersfield stoppers extended to Leeds to cover the missed out stops and the Southport service switched to run via Bradford.
We know that Halifax, Hebden Bridge and Todmorden will benefit from new services. This means that Rochdale, Littleborough and the other stations between Todmorden and Manchester (and also Mytholmroyd and Sowerby Bridge) will retain their current frequency...with one exception.
Moston will see its 2tph frequency restored, meaning that it matches the other stations between Todmorden and Manchester. This is listed as part of the Liverpool/Manchester Airport services, so one of these will call here in all likelihood. It makes sense that services to Moston would also stop at Rochdale and Littleborough among others.
Therefore, it looks likely that Rochdale (and the other stops) will be skipped by one of the other services.
According to the TSRs, Rochdale will get an extra tph, presumably running from the west to the new bay platform. Todmorden gets no change in current service. Hebden Bridge, Halifax and Bradford see the new Northern Connect service. Sowerby Bridge gets extra rush hour services.
Bradford will have an hourly service to Hull and an hourly service to Nottingham via Wakefield Westgate. There will also be an hourly service from Halifax to Leeds, and the service from York to Blackpool North will remain.
The Bradford to Hull service was only mentioned only in the Transport Secretary's Introduction to the Franchise Award, but has not been seen since. Certainly not in the contract, although Northern are to investigate an extra Leeds-Selby service, which I suppose could become Bradford-Hull.
I think you mean an extra Halifax to Leeds service, not a single service! The CP5 plan originally provided for 2 extra Calder Valley trains into Leeds running through to a Mickfield turnback, but the turnback has now gone from CP5 and the only extra train in the Franchise Agreement is Bradford to Nottingham.
thats the bad news, the good news is that increased capacity into Leeds will now be provided by platform extensions/train lengthening to 6*23m.
Also making its first appearance in the Franchise Agreement, is the news that Arriva are to investigate running the Blackburn-Todmorden-Victoria service over the Ordsall Chord to Manchester Airport, in addition to the Bradford service.
