Esker-pades
Ipswich
Please do not edit posts. What did your post originally read?Wetheral
Points are deducted from the leg if a deadlock is reached before the penultimate move of a leg - if no-one posts this move within 3 hours then 20 points are deducted, and a further 20 are taken 3 hours after that. (This rule will not be enforced in the early morning from midnight to 9am, and a leg will never score negative points.)
Invalid moves and legibility
The game depends heavily on the order of moves being correct. Occasionally invalid posts are made, for instance when lots of posts are made in quick succession. To avoid problems arising from this:
- You may never edit a move, other than to strike it out using [s][/s] tags if it is invalid.
- If you then need to make a new move, do so by posting again and not by editing.
