Probably for the last time as it closes on 5th July.We next board the 1625 Stagecoach South East service 10 to Folkestone (Bus Station), arriving there at 1738 on Wednesday.
Metrolink Engineering Works 2025.
We are a four minute walk away from Anchorage tram stop. Now under regular operations, with Anchorage being on the Eccles Line, services traditionally operate from Eccles to Ashton via the city centre. However, until 10th August, there is major engineering works taking place, with no services between Piccadilly Gardens and Piccadilly whilst new tracks are laid along Aytoun Street. As a result, the Eccles Line is diverting to Victoria via Market Street instead, and services to Ashton are starting/terminating at Piccadilly. The issue is that journey planners, on both the Bee Network site and Bus Times, are now showing the amended timetable/operations, but on a permanent basis beyond 10th August.
Due to the complex timetabling, and respecting our elderly but nonetheless respectable members on here (Paul!), would anyone be in agreement to allow us to use the 'new' (but in reality temporary) timetables, to avoid having to make complex journeys? Under normal circumstances, it would not usually be possible to make a direct journey between Eccles and Victoria without changing at Cornbrook. Otherwise, I'd have to make a journey towards St Peter's Square and beyond towards Ashton, but I'd essentially have to merge the two timetables together (Eccles-St Peter's Square/Piccadilly to Ashton) to make a 'direct' journey, which could lead to complications.
Agreed. This means that if we use the tram times that are in bustimes.org we will be OK
The issue is, as I did try this exact movement you suggest, is that the 'original' timetables are nowhere to be seen. If I was to make a journey from Eccles to Ashton, I'd have to select a time from Eccles to St Peter's Square (the last stop before the temporary re-routing to Victoria), then 'guess' the journey time to Piccadilly and then pick a slot from Piccadilly to Ashton. I did try, and gave myself a headache in the process!The long standing tradition in this game is that we ignore any temporary engineering works timetables, and continue as if they weren’t happening. I’d be happy to pick up a conversation if there is advocacy specifically against this? Would it be possible to continue as normal? (e.g. will the reference materials for normal service still exist?)
I can't find this journey anywhere. There is a 602 journey at 2206 to Canterbury?We then get the 22:04 8 service bus to Whitefriars, Canterbury, arriving at 22:12 on Wednesday
That might be the one!The issue is, as I did try this exact movement you suggest, is that the 'original' timetables are nowhere to be seen. If I was to make a journey from Eccles to Ashton, I'd have to select a time from Eccles to St Peter's Square (the last stop before the temporary re-routing to Victoria), then 'guess' the journey time to Piccadilly and then pick a slot from Piccadilly to Ashton. I did try, and gave myself a headache in the process!
Lovely!That might be the one!
We'll go with this
There was an earlier service 600 at 21.36 arriving at Canterbury bus station at 21.42. Also Whitefriars has been pedestrianised since 2003.I can't find this journey anywhere. There is a 602 journey at 2206 to Canterbury?
From the adjacent bus station, we next board the 2245 Stagecoach South East Breeze service 8 Westgate-on-Sea (St Mildred's Road/Carlton Cinema), arriving there at 2323 on Wednesday.
Whitefriars does have a series of bus stops though.There was an earlier service 600 at 21.36 arriving at Canterbury bus station at 21.42. Also Whitefriars has been pedestrianised since 2003.
We take the seven minute walk to Victoria Coach Station where we board the 0630 National Express service 035 to Westbourne (County Gates), arriving there at 0935 on Thursday.Time for an overnight break. Following on from our tour of Kent we take the three minute (0.2 mile) walk to the railway station for the 04.40 Southeastern service 1P04 to Victoria arriving at 06.21 on Thursday.
Hey, I'm from North Yorkshire, sunny Kent is wayyyy beyond my jurisdiction!Whitefriars does have a series of bus stops though.
St. Georges Lane actually even if referred to as Whitefriars. Used by City route 649 (Regent Coaches) and the park & ride services (Stagecoach).Whitefriars does have a series of bus stops though.
We walk (3 mins) to the Talbot Manor stop on Talbot Ave where we board morebus service 36 at 1145. We alight at Turbary Common (Mandale Rd Top) at 1201 on Thursday.Leaving the station, we next board the 1045 morebus service U3 to Bournemouth University (Poole Gateway Building), arriving there at 1109 on Thursday.
