And indeed rewiring fuses.And when replacement of fuses was a more frequent preoccupation.
Admission: I still have them!
Or 2Amp round pin socket.It can still be the case today. Lighting circuits can still use 5A round-pin socket/plugs.
Yes. replace them with a quarter inch bolt if they persisted in blowingAnd when replacement of fuses was a more frequent preoccupation.
The 15A version isn't totally extinct either: apparently the lack of a fuse in the plug is advantageous for theatres, where it's convenient if all the fuses are in one place rather than having to check each plug in the lighting rig.
Thanks both. I've seen the 5A version used in recent construction, but haven't seen the 15A version for ages. I used to see them as you say in stage lighting back when I was dabbling in that field.And also the lesser seen 15A round pin plug (we had an immersion heater with one of these until relatively recently...)
A long time ago, but I don’t remember wearing trunks being an option. Perhaps if we’d complained to our mothers things might have changed, but we didn’t. For me, the worst thing was breaking my teeth in the bottom of the pool which has cost me £thousands since, but I doubt I’d be able to claim it back now.I've heard about this before, but was it mandatory or could you wear trunks?
For me, the worst thing was breaking my teeth in the bottom of the pool which has cost me £thousands since, but I doubt I’d be able to claimit back now.
No PJs, nothing at all, that was the point of the original post ….Were you wearing your PJs and attempting to retrieve the rubber brick from the bottom and return it to the pool edge? I remember having to do that at school in the late '80s / early '90s as part of a lifeguard training programme.
In fairness, swimming in PJs is still a very common swimming drill (as it trains you for falling in water clothed). Not sure about the picking up the brick when doing it!Were you wearing your PJs and attempting to retrieve the rubber brick from the bottom and return it to the pool edge? I remember having to do that at school in the late '80s / early '90s as part of a lifeguard training programme.
Dear god dont tell me you have a ye-olde fuse box/consumer unit at home? Some commercial properties still have wired fuses.And indeed rewiring fuses.
For me, you had to inflate said pyjamas as a buoyancy aid , think I did this for my gold ASA badge, plus picking up the brick from the floor of the deep end amongst other things, plus swimming for about three miles, took me about 30 minutes to walk afterwards.In fairness, swimming in PJs is still a very common swimming drill (as it trains you for falling in water clothed). Not sure about the picking up the brick when doing it!
In the '60s I did the survival and rescue bit of lifesaving. That involved jumping in with pyjamas on, then removing the trousers and tying knots at the bottom of the legs to make a pair of floats for a rescuee and hoding the collar tight against my neck to allow the back to be inflated.For me, you had to inflate said pyjamas as a buoyancy aid , think I did this for my gold ASA badge, plus picking up the brick from the floor of the deep end amongst other things, plus swimming for about three miles, took me about 30 minutes to walk afterwards.
I had two of those in the early 1970s, for running a hi-fi system in university accommodation. The hi-fi probably got more use than the desk lamp that the university provided. It was the only place I ever came across 2A sockets.I have a 4 gang conventional socket extension lead powered from a 2 amo round pin plug if anyone wants one…
Guilty as charged!Dear god dont tell me you have a ye-olde fuse box/consumer unit at home? Some commercial properties still have wired fuses.
Just adding to this, at the power station where I worked, every appliance or bit of equipment which came with an attached fitted moulded plug had the plug cut off and replaced with a conventional wired plug.Remember when you would buy an electrical item and it didn't come with a plug?
My fuse box, in a house built in something like 1982, still has wire fuses. I have myself replaced the low current fuses on the lighting circuits with plug-in circuit breakers, not least because these can blow when replacing a light bulb, but the ring mains, cooker and shower circuits remain with wire fuses, not least because they never blow.Dear god dont tell me you have a ye-olde fuse box/consumer unit at home? Some commercial properties still have wired fuses.
And ideally required to have a nodding acquaintance of the significance of differently coloured wiring therein.I can't remember when I last changed a fuse in a plug.
Further complicated, although less often in plugs on appliances, when the pre-2006 colours are used. My house wiring uses the older 1977-2004 colours, for example, and I had great fun when I needed to modify a two-way switch setup with all sorts of colours that I wasn’t expecting. What would we do without the Internet to look up these things?And ideally required to have a nodding acquaintance of the significance of differently coloured wiring therein.
A few years for me.I can't remember when I last changed a fuse in a plug. Something tripped the circuit breaker in the consumer until about 25 years ago. It wasn't a regular occurrence but I seem to remember that in my younger days you would need to change a fuse somewhere in the house every couple of years.
Description of Shape and Color:
- Shape:
- The main body is cylindrical and vertically oriented.
- The bottom tapers into a cone-like shape.
- There is a small spout or lever on the lower section used for dispensing.
- Color:
- The upper cylindrical reservoir is transparent red.
- The top cap and the lower section, including the spout, are cream or off-white.
- There is a small black and gold label on the cream section, which likely displays the brand name.
Or wrap the blown fuse in kitchen foil?Yes. replace them with a quarter inch bolt if they persisted in blowing
I found one of these when removing our kitchen - must have been from our house's previous owner. We'd only been using those outside lights for 6 yearsOr wrap the blown fuse in kitchen foil?
Yes my parents had one when I was a child back in the 1950’s or 60’s.
When folk made a great issue about "infusing" the tea, whatever that may have entailed....Yes my parents had one when I was a child back in the 1950’s or 60’s.
Seen worse, in the late 70s went to my Aunties, found out there was a nail in a 13A plug fuse holder. I'll never forgot that!Wrap the blown fuse in baco-foil?
What about an RCD?Guilty as charged!
I've installed a fair few rewirable consumer units in my time (but no more of course!) and haven't given it a thought.
It's a long time since I have actually needed to change one, but I know what to do!
I'm curious as to the reasoning for that?Just adding to this, at the power station where I worked, every appliance or bit of equipment which came with an attached fitted moulded plug had the plug cut off and replaced with a conventional wired plug.
Either they were refitted with Walsall plugs or it was done to ensure that they were correctly wired - following a case where a factory, I believe, turned out plugs with the Earth and Live wires reversed.I'm curious as to the reasoning for that?
I only ever saw one of these, it was in my great aunty's house.Have we had those loose tea dispensers on walls yet?
Yes, I had that in my bathroom when I was a kid in the 1970s, we had that weirdly shaped thing on the wall to attach the shower head as well!Anyone encountered the rubber bath tap attachments with a shower-head at the end? This facilitated the shampooing of hair whilst having a bath and the possibility of incurring third degree burns to the scalp if the cold tap attachment popped out from the tap spontaneously mid-hairwashing whilst the hot tap attachment remained resolutely in situ.
Simply because they wanted to ensure they were wired correctly and safe to use. Power Stations were a bit paranoid on that one.I'm curious as to the reasoning for that?
You are not alone... We had both of those in the 1970s and I hated the darned things.Yes, I had that in my bathroom when I was a kid in the 1970s, we had that weirdly shaped thing on the wall to attach the shower head as well!
