Things we don't see at stations these days
Trainlog
16 Aug 2022
Maidstone
Found a video of one of the coin operated locos. Its a shame that they cant reintroduce one at a mainline station as a bit of a novelty.
80sGuard
10 Sep 2018
LT tube, trains, up to and including the 1938 stock, had A and B ends and there was a small plate by the drivers window to say if an A or B end. After that each axle had a letter, so trains and an A or D end. Later they had trains that were double ended but that complicated the couplers.
I think the standard Southern Region trains could couple any way - there was no 'end' designation on EPB,s CIG,s VEPS and Cl 33 for example
I dont know if earlier stock with different jumpers could couple either way. Did 4-SUB's need to be coupled the right way round?
On stations I used to love watching trains being coupled. The brake hoses (Vacuum and air), steam heat, ETH, control jumpers, the RCH lighting jumpers.
SUB's were still in service when I went through the South-Western Divisions Training School at Eastleigh, so I've attached the coupling diagram for EMU groups A (4SUB), D (2/4EPB) and E (4VEP, 4CIG). SUB's didn't have different ends, the connectors at each end were idential. However, after the mechanical and air couplings were made, the remaining three - Power, Control and Lighting HAD to be made in that order. I forget why but possibly because everything was derived from the traction current? REP's were slightly different owing to the ETH supply so had separate instructions, as were SE loco hauled trains (especially different sub classes of Cromptons cl33). Before you ask, yes, it was distributed on pink foolscap paper, which is why the image is cropped using an A4 scanner. The annotations are mine
75A
31 Mar 2021
Ireland (ex Brighton 75A)
Ah memories.
