Ticket from Liverpool Lime Street to Clacton-On-Sea
Starmill
18 May 2012
Bolton
Thank you all, I plan to depart on the Friday so I have freedom on my tickets restrictions and knowing I can break my journey overnight is very helpful. If I get challenged what should I do? I’m not interested in rolling over and buying another ticket on board as I presume they’ll try make me and do worse case a penalty fare.
It's unlikely you will be challenged robustly on breaking the return portion. You can just point out when you left Clacton-on-Sea and where you stayed the night, that should be enough.
I don’t know why you are so sure you will have difficulties
Perhaps because of confusion arising from Peterblue's post above.
jfollows
26 Feb 2011
Wilmslow
Don't worry about it.
The paper ticket will clearly have the validity dates printed on it, which can sometimes be easier than trying to find the same information on an e-ticket. "Valid until" or something quite clear like that.
Explain that you stayed overnight in London on the way back.
Probably best to avoid the phrase ‘break of journey’.
Personally, I completely disagree with this.
Firstly, break of journey is a long-standing concept and is the rule rather than the exception. I never have any problem saying "I am breaking my journey" if it's valid for the ticket and place I am using.
Secondly, passengers should not feel intimidated into saying something different just in case the person they're talking to is poorly trained or making up the rules. If you're in the right, you should be happy to know your rights and not pretend otherwise.
tspaul26
9 Jun 2016
You may well disagree.
The point I was trying to make was that for a passenger who is less sure of his rights then in my experience simply saying “I stayed in London overnight” tends to be (a) simpler and (b) less likely to trigger certain members of rail staff.
Especially since I have witnessed numerous examples of passengers confidently stating “I’m breaking my journey” when they are not in fact entitled so to do.
sansyy
11 Dec 2023
Chester
Thank you for all the advice, I’m a frequent Northern passenger and the staff are clueless when it comes to BoJ and always challenge it like they know the rules when infact they’re clueless. I am not sure on Avanti staff with this matter but considering they host intercity services I’m hoping they’re trained more with this. I will assert myself if questioned based on knowing my ticket is valid and will be show them my ticket restriction if they think they’re so correct.
Hadders
27 Apr 2011
Some staff do seem to have a problem witht he phrase 'break of journey'. I tend not to use it instead saying something like 'I stayed overnight at...' or if wanting to go out for a few hours say 'can I pop out for some supplies' etc.
jfollows
26 Feb 2011
Wilmslow
Yes, you and tspaul26 both make a fair point, it's a good one, although not something I'd encountered myself.
mangyiscute
6 Mar 2021
Reading
I have often broken and resumed journeys overnight (or even weeks apart) and never had any issues. While there is the odd member of staff who doesn't know the rules properly and is overly strict, the vast majority of staff on the railway are helpful, customer-minded people who won't cause you any hassle.
There's a tendancy to overstate things on this forum, but from my own experience despite fairly often using tickets on routes which would be considered odd and potential to be challenged (things much "worse" than a BoJ overnight), I have never had an issue or had any staff member even consider the possibility of penalty faring me etc. My only advice would be have a copy of the Nrcot saved on your phone so that if necessary, you can show that overnight BoJ is allowed.
sansyy
11 Dec 2023
Chester
Thanks for the advice, I’m presuming when you specifically say you’re “breaking your journey” it could flag in a guards mind that you’re doing it on purpose purely to break journey rather than popping out or staying overnight which in my mind would probably set a red flag even though it’s fully allowed and shouldn’t be challenged.
jfollows
26 Feb 2011
Wilmslow
Well, two things occur to me:
Firstly, there's no need to have a reason for breaking a journey if the ticket allows it, if I happen to want to go and see the petunias in Tamworth on a London-Wilmslow ticket then that's fine. Whether or not I leave the station in the process.
More importantly, it appears that a lot of front-line staff who inspect tickets aren't trained very well, primarily those at stations, and there is a tendency for them to make up the rules to suit their way of thinking how the rules should be, as opposed to knowing what the rules actually are.
My main gripe is that the railways evolved a complex fare system to suit their needs, and there is historical baggage as well, but they're not prepared to reform and simplify the system (it's hard, I agree) or to train staff properly. Presumably many station staff don't do the job for long, and sometimes the job is contracted out to companies like Carlisle Security who have a bad reputation here. That said, the point has been made that they are the exception and the majority of staff want to do a good job and treat passengers well.
But, back to your question, I think you've got a good variety of responses and you're well placed now, if so then that's good. I don't think you'll have a problem but it does no harm to think about potential for a problem in advance.
PS Also, it's strange that the National Rail Conditions of Travel (https://www.nationalrail.co.uk/travel-information/your-rights-and-obligations-as-a-passenger/), which mangyiscute refers to above and which we're also supposed to have read and agreed to before travelling by train, explicitly refer to "break of journey" but some feel it wiser to use a euphemism instead for fear of confusing staff.
16. Break of Journey
INFORMATION: Most Tickets allow you to break your journey. This means that you do not have to make the whole of your journey at the same time or, where allowed, on the same day.
Please note that “advance” Tickets do not permit a break of journey. The special conditions for “advance” Tickets can be found at www.nationalrail.co.uk/advancetickets
Other national Ticket types normally allow break of journey with the exception of the outward portion of some longer distance “off-peak” returns. Where this is the case, it is made clear in the restrictions applying to those Tickets.
16.1 Where break of journey is allowed, there is no limit to the number of times that you can do so within a Ticket’s period of validity, until the journey is completed.
16.2 Generally, you may start, or break and resume, a journey (in either direction in the case of a return Ticket) at any intermediate station, as long as the Ticket you hold is valid for the trains you want to use. However, this may not be the case with some through services that take an indirect route. You may also end your journey (in either direction in the case of a return Ticket) before the destination shown on the Ticket.
16.3 If you start, break or resume your journey at an intermediate station where you are not entitled to do so, you will be liable to pay an excess fare. The price for this will be the difference between the amount paid for the Ticket you hold and the lowest price Ticket available for immediate travel that would have entitled you to start, break or resume your journey at the station concerned.
16.4 Tickets valid for travel across London using Transport for London services do not entitle you to break your journey on London Underground and/or the Docklands Light Railway, unless your Ticket is a Season Ticket or a travelcard covering the Zones in which you are travelling.
mangyiscute
6 Mar 2021
Reading
I guess its probably because staff will be told in their training "you must never let someone break their journey on an advance ticket" quite strongly, and then perhaps its just noted that you can break your journey on other tickets. Therefore, if only the first statement sticks with the member of staff, they will just think "oh break of journey is bad". Meanwhile if you say to someone at the barriers "oh i just want to pop to that cafe" they're like "oh that's okay"
kieron
22 Mar 2012
Connah's Quay
In theory can avoid the London termini by alighting at Watford Junction, changing to a train calling at Willesden Junction then taking Overground train to Stratford.
The Clacton trains generally call at Stratford
Not sure if that qualifies as not London, or gets around no e-tickets
That's perfectly fine on a "not via London" ticket, and is a good bit quicker than going via the East Midlands. According to Southern (link), it can be bought as an e-ticket, and the journey takes around 6 hours each way during the week.
London Overground to Wanstead Park would also be fine (you could walk to Forest Gate and catch a Shenfield train from there), and there could be other options.
I should add that, like the "via London" tickets, these let you break your journey.
trainJam
26 May 2023
West Midlands
Would it have any effect (better ... or worse!) to bring a printed copy of the National Rail Conditions of Travel to show?
Hadders
27 Apr 2011
I doubt it. A poorly trained member of staff won't budge, they'll continue to make up all kinds of nonsense like the NRCoT doesn't apply to us etc.
jfollows
26 Feb 2011
Wilmslow
Yes, just travel secure in the confidence that you know what's right, don't worry, and if you're unlucky to encounter this sort of person, ultimately go along with them and get any money back later, don't let it spoil your trip too much. As I said above, I've never had this kind of problem, and in many cases these people bluster and eventually "let you off" anyway. Clearly some people have had problems, and it's a shame, but it's impossible to adhere to the letter of the rules when the people enforcing the rules don't do so themselves. Plus this forum is probably a focus for this sort of poor behaviour, certainly these kind of tales have been reported more than once, but in the real light of day it's a smaller problem than might otherwise be implied. Doesn't make it right, of course!
