TOPS Codes
GNERman
8 Oct 2008
North Yorkshire
Morning all
Just a quick question, could anyone tell me what each of these stand for..
MSX
SX
SO
MO
FSX
FO
Thank you...
Ivo
8 Jan 2010
Bath (or Southend)
Are they not related to days of operation? As in M=Monday, F=Friday, S=Saturday, O=Only, X=Excepted?
...Oh, dang it. Too slow.
GNERman
8 Oct 2008
North Yorkshire
OK so can you explain this...
6D71 0327 Rylstone Quarry - Dairycoates MSX
6D72 1132 Dairycoates – Rylstone Quarry SX
6D03 0327 Rylstone Quarry - Dairycoates SO
6D04 1103 Dairycoates - Rylstone Quarry SO
6D74 0327 Rylstone Quarry - Neville Hill Up Sidings SO
6D71 0431 Neville Hill Up Sidings - Dairycoates MO
Returns as 6D72 to Rylstone
Especially this part...
12 Feb 2010
Taunton
6D71 0327 Rylstone Quarry - Dairycoates MSX - Runs Tues-Fri Only
6D72 1132 Dairycoates – Rylstone Quarry SX - Runs Mon-Fri Only
6D03 0327 Rylstone Quarry - Dairycoates SO - Runs Saturdays Only
6D04 1103 Dairycoates - Rylstone Quarry SO - Runs Saturdays Only
6D74 0327 Rylstone Quarry - Neville Hill Up Sidings SO - Runs Saturdays Only
6D71 0431 Neville Hill Up Sidings - Dairycoates MO - Runs Mondays Only.
87015
3 Mar 2006
GEML/WCML/SR
The trains with SO at the end run on Saturdays.
MSX ones Tuesday-Friday, SX Monday-Friday
All as stated above :idea:
EDIT: too slow!
jopsuk
13 May 2008
The man makes a good point- it is a single line.
However, perhaps they don't both run every week? I.E. the path is booked long term, but it goes to one or the other dependent upon demand?
12 Feb 2010
Taunton
Ah, but he didn't specify that the route was a single line.
Perhaps if you know someone who can access the Freightmaster times, you may find enlightenment.
It may be whats called a Q path which has be described earlier. One week it goes to one destination and the next week the other. Its a way of getting two paths out of one.
28 Feb 2009
This is probably quite a common situation with freight paths. This is pure speculation on my part, but I'm thinking maybe the loading terminal (Rylstone) might not be working over the weekend, the normal situation will be for the loaded train to lay over at Neville Hill on Sunday, working forward as 6D71 to ensure a delivery to the receiving terminal (Dairycoates) on a Monday morning. However, if a delivery on a Saturday is more important to the customer, the 6D03/6D04 paths will be called. Another possible reason for the paths is in case the stabling facilities at Neville Hill are unavailable for some reason. Just because a schedule exists doesn't mean a train will necessarily run!
Old Timer
24 Aug 2009
The only sevices I can find now are
6D72(Q) 11:32 Hull Dairycoates-Rylstone (SX)
6D73 18:12 Rylstone-Leeds Hunslet (SX)
6D83 22:38 Leeds Hunslet-Rylstone (SX)
6G75(Q) 09:15 Leeds Hunslet-Rylstone (SO)
91101
25 Oct 2007
Here is one I would like to know.
We talk about "CRS Codes" as in KGX/STP/NCL/LDS/YRK etc, the three letter codes for stations, but what does "CRS" stand for?
142094
7 Nov 2009
Newcastle
CRS is the NLC abbreviation code for Carstairs, and not the same as the CRS mentioned above.
91101
25 Oct 2007
Incorrect, CRS is the CRS Code for Carstairs the NLC code for Carstairs is 9704. CRScodes are the three letter codes, NLC codes are the numbers.
