Well I'm no mathematician, but I do have a conveniently close fag packet that I can scribble on the back of. I'm sure that if any of what follows is just "rose manure" then I'm sure that someone will come along later and correct me.
Lets set some assumptions. The gravity on Mars is 0.375 times that of gravity on Earth and the atmosphere more than 100 times less dense (source:
NASA Science Mars Facts). For simplicity we'll just take 100 as a nice round figure rather than guesstimating too much. Lets also assume that the astronauts are packing light, which means that they won't have enough space for an SRN4, so they've brought a little Hov Pod instead.
To achieve lift, a hovercraft has to overcome the action of gravity on it's mass. Using the figures you've provided, on Earth the Hov Pod has to exert a force of not less than 102 kgf/m2 to achieve lift (I presume the figures that you quote do not include the occupant, if so I think you'd need to allow a greater mass on Mars due to the need to wear a little more than shorts, T-shirt and flip-flops). On Mars, with it's weaker gravity, this becomes 38.25 kgf/m2 (102 x 0.375 = 38.25). Nice!!
The issue is that it's trying to exert that force using an atmosphere 100 times less dense than on Earth. Although the pressure might only be slightly higher inside the skirt than outside, it still needs to exert a force of not less than 38.25 kgf/m2 in order to achieve lift. That surely means that it has to suck in 37.5 times more air to exert that force than would be the case on Earth (1 / 102 x 38.25 x 100 = 37.5).
What I'm unsure about is the effect of lower atmospheric pressure on Mars on a craft's ability to exert this force (6-7 millibars compared to 1013 millibars on Earth - source:
Arizona State University), so the amount of air required may be less. It would certainly not require so much to inflate the skirt due to lower resistance, but I'm unsure how that helps it exert the force necessary to achieve lift.
So anyway, that's my science homework completed using the entirely non-scientific back-of-a-fag-packet-based-on-entirely-made-up-assumptions method. Hopefully someone with a more scientific bent will be along to correct where I've made an error.
