Trainz Locos HELP
11 Jan 2011
All around Sloane Square
(Please)
I'm having another crack at downloading locos to Trainz 2009. Right now I've got a loco and its dependancies downloaded - the files are 'local' - but when I boot up Trainz the loco isn't there, if I right-click and select View In Railyard it never appears there either.
Help would be great, as this has been an issue and indicator of my ****lessness for some time now.
TrainfanBen
30 Oct 2010
Coventry.
(Please)
Right click and check that all the dependencies have been downloaded, and that's it's a whole model, not just a reskin.
Which locomotive is it, a kuid number would also help.
60163
11 Jan 2011
I do check, and all the dependencies are indeed there. Where would it say, if it was just a reskin?
Thanks to you both, and sorrry for the late reply. TukayAway, it says - for pretty much every loco I've attempted to download - Trainz Classics 3. Did this come oout after T2009? thanks.
90019
29 May 2008
Featherstone, West Yorkshire
TC3 came out before TS09, but if it's content designed specifically for TC3, then it may not be compatable with TS09 as I believe TC3 has some built in assets that haven't been included and would require the S&C addon pack.
60163
11 Jan 2011
M'kay, here's a kuid number, and the page
<kuid2:138579:4765:1>
http://www.auran.com/TRS2004/DLS_downloadasset.php?DownloadID=171441
Here's an example then.
Set the search terms JUST for Trainz 2004/2006/2009, downloaded it, all dependencies there, opened it for editing so I could commit it, tried to view in railyard, then
Error: Failed to commit changes to asset <kuid:53926:541032> due to missing config file
Error: Failed to commit changes to asset <kuid2:30992:51000:3> due to missing config file
Error: Failed to commit changes to asset <kuid:283805:50000> due to missing config file
Error: Failed to commit changes to asset <kuid:283805:40339> due to missing config file
