Transdev Blazefield
M60lad
31 May 2011
Regarding double deckers, it might have been answered before but is there a reason why despite how busy some trips get why deckers aren't used on B3 Bronte Bus service to Hebden Bridge?
Considering how busy some trips get deckers would certainly be a good idea and also surely the route would be ideal for a double decker considering how scenic parts of it are.
Edvid
7 Feb 2008
SCH117X
27 Nov 2015
One of the demo E400EVs (AD24 BEV) is doing rounds on the 36. I presume Transdev's 19 are still some months out with ADL manufacturing the Oxford models first.
Post 3999 above "When the new Enviro 400EVs enter service at Harrogate in the summer..."
Aaron Ashton
15 Jan 2016
Lancashire
I think there are unrealistic expectations if you think buses from 2017 need replacing
You've got to remember, the 464 Versas are the only ones in Transdev which have the same Mercedes-Benz/Daimler engine you would find in a Solo...having been a driver on the route, the engine isn't up to standards for the loadings/demands it was specified for.
RustySpoons
5 Apr 2019
This is incorrect, Transdev haven’t forbidden any vehicle purchases and have actually ordered further vehicles for late 2024 delivery. The plan is very much to replace and reinvest.
Aside from the electrics for Keighley and Harrogate what else is due?
johntea
29 Dec 2010
It seems Harrogate bus station is having the infrastructure put in place for the electric fleet so will be closed daily after 7pm Sunday - Thursday evenings from 21/04 - 23/05
Transdev have also knocked together a pretty poor 'map' of the alternative stops!
Closure of Harrogate Bus StationSunday to Thursday evenings after 7pm, from 21 April - 23 May
Harrogate Bus Station will be closed daily each Sunday to Thursday after 7pm from 21 April to 23 May.
All buses will run at the usual times, but from our temporary stops. See your alternative stops below.
johntea
29 Dec 2010
It just doesn't seem to actually be of much use to someone who may not know the Harrogate area too well
The list below provided to the Subscription...err Stray Ferret is perhaps more logical and could have been included in the image
Services 1 and 7:
From Harrogate to Leeds: The Odeon, Harrogate
From Leeds to Harrogate: Asda, Harrogate
Services 2 and 3:
Asda, Harrogate & Cheltenham Crescent, near West Park
The 36:
From Harrogate to Leeds: Library Gardens, Harrogate
SCH117X
27 Nov 2015
Seems quite clear to me - 36 and A2 on road between the bus and rail stations where the MoD and few North Yorkshire Council operated service stop albeity these days unmarked, and the services down the road which the 1,7 and 36 approach the bus station on which was used back when the the original bus satiuon was used What is not clearly stated are the stops being missed out by 2 and 3 as the 2s route is shortened and hence will be missing out the stop by Asda while the 3, unless it does a time consuming turn round, will be missing out the Library and that near Bettys.
Services 1 and 7:
Services 2 and 3:
The 36:
That list is a load of rubbish, the 2 and 3 cannot serve Asda and it otherwise addresses what other stops are being used beyond the temporary ones shown on Transdevs map. As a map that is perfectly correct and should be able to followed.
RustySpoons
5 Apr 2019
Took me a while to work out the perspective, but even though i've not been to Harrogate for a number of years once I worked it out it was fairly easy to understand. I'm sure a local will have no issues.
Andyh82
19 May 2014
Considering the temporary stops are a few feet away from the bus station, I hardly think there will be mass confusion
Seems to be criticism for the sake of it, as per.
SCH117X
27 Nov 2015
I think more confusion will by passengers heading to the stop by Bettys for a 3 given the 36 to Ripon will be using it. Really should have the 3 terminating with the 36 and A2 so it keeps its normal route
RustySpoons
5 Apr 2019
There'll more than likely be notices up in the bus station and staff milling around to point people in the right direction, but considering it's only in the evenings I don't think it'll cause that much of an issue.
JD2168
11 Jul 2022
Sheffield
I am thinking with this that most of the late journeys each day will be Diesels with no opportunity charging available in the Bus Station for the electrics. The map is ok to use. It is better than a list of stops other operators use.
SCH117X
27 Nov 2015
Definately the 2 and 3 will be a B7RLE, quite common anyway given the seven currently available Volvo Electrics have a 100% availability requirement in the peaks so one duty at least is often a B7RLE, or a B9TL, which if its that which is the evening 2 and 3 it works despite Electrics becoming available. Realised that interworking is why the 2 and 3 are allocated the same temporary terminus. However, that could still be with the 36 so both services retain their normal route.
RustySpoons
5 Apr 2019
Apologies if this has already been discussed, are the existing Volvo electrics staying when the new Mercs arrive, or are the Mercs replacing them too?
SCH117X
27 Nov 2015
The Mercs are for the 1, 7 and 24. The Volvos remaining on the townn services. They do need an extra however to replace 805 unless it returns from Volvo in Poland. There have been previous rumours of the demostrator being bought by them.
Delenn
4 Aug 2019
Have Transdev stopped doing timetable leaflets? There is no new Coastliner timetable, and Malton and Harrogate Bus Stations have very few on offer at the moment.
Seehof
1 Sep 2019
Blossom Street York bus stop this morning. This listed a 22 York and Country service departure as well as the EYMS 82 service!
RustySpoons
5 Apr 2019
Thanks for the info.
It'd be a shame if they do, printed timetables were are of the things Transdev do very well, providing the information is correct...
158756
12 Aug 2014
On publicity the "Our network in Yorkshire" map is a bit missing with no mention of Huddersfielld, Denby Dale or Wakefield.
It's still better than the Lancashire map, which doesn't seem to be available anywhere any more. The maps showing the ticket zone boundaries also seen to have been lost in the transition to the new app.
In other news, it looks like they are going to abandon the photo requirement in the new app. From https://www.transdevbus.co.uk/news/get-started-with-the-new-transdev-go/
Why do I need to upload a photo? We are working with our supplier to turn this off, in the meantime, feel free to upload any photo to your account if you wish. Our drivers won't be checking these.
It is unpopular with passengers, I have heard a few people now say they are buying a ticket on the bus because of this.
Redmike
13 May 2018
The local maps have disappeared from the website as well eg Blackburn, Burnley and Rossendale networks. It’s a shame as this was something Transdev were really good at.
Regarding physical leaflets none were available at Blackburn bus station when I passed through the other week. The desk seemed to be closed and unstaffed as well.
Andyh82
19 May 2014
They never added Team Pennine to that map, besides the 502
Probably as Huddersfield to Derby Dale floating separately with no link to anything else would look a bit strange
The Lancashire one probably needs revising to remove the Rochdale and Bury services
Ashly_Jethro
12 May 2020
Lancashire
Thank god for that (in regards to the app photo) I imagine they even noticed a drop in app sales and rise of on-board ticketing for them to realise that this really did need removing. I can’t say I’ve really seen anyone use the new app to scan an m-ticket so perhaps this will change again and see a return back to m-tickets.
Someone else has mentioned the Lancs map will now need re-doing with the loss of rochdale’s operations.
In regards to the leaflets, it could be that they are due a large shipment from the printers, it’d be disappointing if this is the latest in cost cutting measures, they’ve always prided themselves on print media, and rightly so! We’ll have to see if they get re-stocked in the next few weeks
Delenn
4 Aug 2019
They haven't updated the Coastliner timetable cases, so they all have the wrong times in them. Very poor show. Hate to say it, but this MD is making the last one look like a genius.
