Transdev Blazefield
12 Aug 2014
Current 840 fare table
There are £2 £2.50 and £2.80 fares outside of West Yorkshire
I don't think the fare tables are accurate. Looking at the fare tables for Lancashire I can see journeys listed as £2.50 that I know are £3. It looks like they haven't been updated for the fare rises brought in to go with the £3 cap.
Has anyone actually been charged anything other than £3?
theblackwatch
15 Feb 2006
I spotted one of Harrogate's new eCitaros, 1005, on a low loader today, but was heading away from the depot, going up Knaresborough Road towards the Empress roundabout/Harrogate, so presumably being sent away to somewhere.
158756
12 Aug 2014
The V1 and V3 buses to the Boohoo warehouse in Burnley are to be withdrawn from 8th February due to funding coming to an end.
I don't know how many people used them, obviously not enough to make them commercially viable, but it is a very poor state of affairs that Boohoo are supposed to be the largest employer in Burnley now but will have no bus service.
Stan Drews
5 Jun 2013
When the Boohoo services started they were funded by BooHoo as part of planning conditions relating to their significant expansion. I don’t know if that was still the funding source, as that was around 7/8 years ago now.
Scotrail88
21 Jul 2014
It is poor but think these staff perk services will fast disappear due to increased NI and other contributions employers need to do.
Companies will cut contracts and benefits like this and bus operators will feel the effects.
Does Transdev still have many of these from the Vamooz days?
SCH117X
27 Nov 2015
Had to be towed to the depot on Saturday from Knaresborough. Gone for a warrenty repair.
Meanwhile the Volvo Electrics have been very poorly this week with yesterdays allocation of 6 quickly dropping to 2 and today of 4 in use one seems to have been very erratic and another packed in mid afternoon. Keeps a tow truck driver occupied.
Shaw S Hunter
21 Apr 2016
Over The Hill
Is the cold weather affecting their battery efficiency perhaps? Some nasty gaps in peak hours on local routes. Then again another eCitaro appears to have sat down during Thursday evening. It does mean the Starfleet is seeing a lot of all-day use. On the plus side it appears E400EV 2211 has now entered service.
Ken H
11 Nov 2018
N Yorks
Are they kept inside overnight? If they were out in -8 degrees will the batteries charge?
YorkRailFan
6 Sep 2023
York
Changes to the S1 and 727H have been announced from 20 January:
We'll be making some changes to the S1 and 727H school buses from 20 January.
To help ensure we've got room for everyone to travel, the 727H will extend to Ripley. The S1 will no longer serve Harrogate Grammar School.
Students travelling from Ripley, Killinghall and Jennyfield should catch the 727H to Harrogate Grammar School and the S1 to Rossett School.
2423 and 2422 have moved to Idle from Keighley for school contracts.
LucyP
17 Jul 2018
The new E-Citaro buses are the worst buses. 1002 was the bus. Ticket machine 90BYTGB. On the 7. It wasn't being charged at stand 8 where the 7 leaves from in Harrogate, it was further down the bus station at one of the higher number stands. Do they even have chargers? Do any chargers work? It was moved to stand 8 at the last minute for the service, and left late as a result. It was freezing cold yesterday and the bus hadn't been pre-conditioned and several people were commenting about the temperature. It was very cold. The heaters are very weak and the bus hardly heated up at all during the journey. The previous buses had strong heaters.
It was the gloomiest, most depressing bus that I have ever been on. The interior wall panels are black. The sloped panels between the ceiling and the walls are large and have huge dark red/maroon HBC advertising pictures on them.
The lighting is limited to 6 small panels on the ceiling of which only 3 were illuminated during the whole journey, except at bus stops were there was some more lighting around the driver's cab/passenger doors. These strips have some small circle designs in them. The strips are not bright and not very long, because the ceiling width is narrow,, because the sloped panels are so large. It was so dark on the bus that you struggled to read anything. The previous buses had lights running the length of the bus at each side above the windows and were much brighter.
The announcements are in the same shrill voice as the previous buses, but the speakers are of the worst quality. The audio on the previous buses was good. On the Citaro it sounds like it was recorded underwater.
There are not enough grab rails. A lot of the seats have just small handles attached. The USB charging points are fitted ridiculously low at the bottom of the seats in front, whereas they used to be at the top. Except at the forward facing seats over the rear wheels, where the USB point is attached to the wall, so if you are sitting in the aisle seat, you have to invade the space of the passenger in the window seat to plug into the charger. You also have to hope that one of you has a standard USB and the other has a USB-C as there is only one of each type in the single shared socket. There is no wireless charging in those seats either, although those are useless as they hardly fit any phone securely and they just fall out en-route. There is also a cover on the floor in those seats on the left, in the window seat. It looks like an up-turned plate or bowl. That is a tripping hazard and irritating under your feet. A very bad design.
The bus is noisy. At low speeds you hear all the squeaks and rattles, even though it is new. That was surprising. As the speed builds up after Sainsbury's/Showground, there is so much drivetrain noise, it is louder than the previous diesel buses. I even wondered if it was a hybrid as the noise sounded like a diesel engine operating when the speed was high, which went away when it slowed. Over a certain speed, every time, it was as if an engine was cutting in.
SCH117X
27 Nov 2015
Thought we were overdue a rant. When this was is typically not stated . Here is a Youtube video of 1006 for comparison filmed from the interior.
YorkRailFan
6 Sep 2023
York
The first few buses have transferred from Reliance to Transdev ahead of the handover tomorrow.
5 - "New Approach" Volvo Eclipse 3
17 - "Mirror Image" ADL 200MMC
16 - "Yorkshire Lass" ADL 200MMC
23 - "Gracie Anne" Volvo Gemini
18 - "Captain Tom" Volvo Gemini 2
9 ("Yorkshire Lad" ADL 200MMC) has been sent to Cummins for engine work and will then be sent to Rawcliffe once work is complete.
RustySpoons
5 Apr 2019
End of an era. I always admired Reliance and their way of doing things. Their smart, modern and well presented fleet always stood out amongst the rest.
SCH117X
27 Nov 2015
Interesting - so presumably one of those will be used tomorrow; I was thinking the vehicles woiuld all move tomorrow and probably a Transdev Go B7RLE be used.
RustySpoons
5 Apr 2019
Unlikely they'll be moved as they're still in Reliance livery. If they are going to be moved at any point I'm guessing it'll be if and when they get repainted.
SCH117X
27 Nov 2015
They will be used in Reliance colours until repainted but with York & Country fleetnames - Paul Turner has posted on Facebook a photo of a blue background York & Country vinyl applied to the front of Gemini BJ11 EAE with the comment of Welcome 2411.
YorkRailFan
6 Sep 2023
York
More vehicles have transferred from Reliance to Transdev:
22 - "Jack's Delight" Volvo Eclipse 2
4 - "The Spotholer" Volvo Eclipse 2
25 - "Evie-Rose" Volvo Evora
26 - Volvo Evora, on way to Transdev after arriving at Reliance depot from DalesBus 74
30 - Volvo Eclipse Urban
Agree, I'll certainly miss them. At least the green will stick around for a little bit longer.
4 Eclipses have now transferred to Transdev so I wouldn't be surprised if they're both used tomorrow.
citybus2500
12 May 2021
Volvo 4 seen just prior to operatong the 12:40 service 30X from York Station Avenue to Easingwold, whilst Volvo 25 is seen about to depart York Exchange Square on the 16:30 departure service 30.
A sad day.
theblackwatch
15 Feb 2006
Thanks for the update. It's a good job I managed to retrieve my hat from 26 today - I left it on the bus last Saturday on the 74, and after its 'holiday' in York, I duly collected it from the bus at Knaresborough this morning, with thanks to the driver!
I then went to York for a few pictures of the final day, and had a ride to Easingwold this afternoon, out on the 30X (with 30) and back on the 40 on ex Lothian 24, which isn't moving across to Transdev across to the resports.
Shaw S Hunter
21 Apr 2016
Over The Hill
Oh dear @LucyP, too long since your last anti-Transdev rant was it? I take it you have taken your concerns up with the company and will report to us what they have to say? In the meantime I'll give you something for free.
Not surprised you didn't see an eCitaro charging at the bus station, the vehicles aren't fitted with the necessary kit! Whatever charge they have when leaving the depot has to last until they return to depot. And that seems to be working out pretty well as they have run the evening services on the 2 & 3 since entering service in addition to taking over the 1s and are now covering virtually all 7s. People living and working along the routes will certainly have noticed the reduced exterior vehicle noise even if some interior motor whine is inevitable.
There are however problems with the bus station chargers affecting the Volvo ebuses but you probably won't have noticed as they rarely stray from town services.
Not sure why you find the interior so unpleasant, could it be you just don't like change? As for the announcements being "shrill" I suspect the only solution that would please you would be to stop them altogether. And that's not going to happen for a number of very good reasons. Personally I find them perfectly acceptable and also reassuring when I travel away from my usual patch. I would guess I am not alone.
YorkRailFan
6 Sep 2023
York
29 - Volvo Gemini won't transfer to Transdev and has been removed after not being used since November.
69600/001 - Volvo Evora has transferred back to York Pullman after being on short term lease.
Transdev's 1871 is out on the 40 this morning.
Transdev's 1867 is on the 30 this morning.
YorkRailFan
6 Sep 2023
York
By that you mean you’ve removed it from BusTimes, not necessarily it’s been removed from the depot?
Yes, although I didn't remove it, someone else did. I am aware of the usual caveats when it comes to Bustimes and vehicle data.
SCH117X
27 Nov 2015
There are charging facilities for the eCitaros at the bus station at ground level at some bays. I can only presume looking at the tracking it was last Wednesday which if the tracking is right 1002 was not used for 4 1/2 hours. Possibly something was left switched on in error which depleted the battery meaning it needed a top up before working the 1508 '7'; that left 8 minutes late.
RustySpoons
5 Apr 2019
Ahh, apologies, I completely misread and as such misunderstood your original post!
YorkRailFan
6 Sep 2023
York
Transdev has started renumbering ex-Reliance buses:
"Yorkshire Lass" formerly 16, now tracks as 582
"Mirror Image" formerly 17, now tracks as 583
"The Spotholer" formerly 4, now tracks as 1773
"New Approach" formerly 5, now tracks as 1774
"Evie Rose" formerly 25, now tracks as 1901
"Gracie Anne" formerly 23, now tracks as 2410
Quite a few delays on ex-Reliance routes today, teething issues, etc. The only thing noteworthy is the first 31X of the day, skipped Ampleforth College and Oswaldkirk, not great considering this service picks up kids going to Ryedale School! Although it did serve Ampleforth Fairfax Close. This was something I encountered on one of East Yorkshire's 31X services last July, so it's not just something at Transdev, although that wasn't a school service, but one passenger did wish to alight in Oswalkirk in that instance. Subsequent journeys on the 31X did operate via Oswaldkirk today though.
Tracking data here: https://bustimes.org/vehicles/hrgt-1871-fj58ltv#journeys/675458178
northernchris
24 Jul 2011
Keighley appeared to have a shortage of buses and/or drivers this morning, with 13 boards cancelled (out of a total of around 50) creating some lengthy gaps in the morning peak. Ilkley had no 62 departures between 0636 and 0842 and there were no 60 departures out of Leeds between 0645 and 0810.
theblackwatch
15 Feb 2006
I see that (according to bustimes), another Enviro400EV, 2206, entered service yesterday. Anyone able to confirm if this was actually the case?
