Transpennine Route Upgrade and Electrification updates
AndrewE
9 Nov 2015
I did read recently that the corrosion of the catenary in the Severn tunnel was due to salt water.
There's both present. At least one big fresh water spring (presumably groundwater in the bedrock strata flowing along one or more faults) and salt-water ingress either down a fault or because the tunnel is so close to the sediment at the bottom of the river bed. Far more water flows through the sandstone into the Mersey tunnel at high tide than at low tide when the estuary water level is so much lower!
I heard that BR used to regularly use a helicopter to drop lots of bags of cement into the river to seal off the downward flow into the Severn tunnel, and were quite concerned when the new bridge was built over or close to the line of the tunnel which would prevent that option being used.
I suspect it's not salt or brackish water dripping through the tunnel roof that is the problem but just the constant high humidity.
p.s. Wikipedia https://en.wikipedia.org/wiki/Severn_Tunnel confirms both:
In 1885 the bed of a pool, known as the "Salmon Pool", on the English side of the tunnel broke through [8] the tunnel's continuous brickwork lining... The Second Severn Crossing, built in the 1990s, crosses the tunnel on a "ground level bridge" on the English side, near the Salmon Pool. The bridge is supported so that no load is imposed on the tunnel. During that bridge's construction, the concrete cap above the tunnel in the Salmon Pool was renewed"
and
Network Rail has observed that the corrosive atmosphere inside the tunnel, produced by moisture and diesel fumes requires replacing the steel rails every six years.[3]
https://en.wikipedia.org/wiki/Severn_Tunnel#cite_note-eng_time-3
Killingworth
30 May 2018
Sheffield
The problem in Totley and Cowburn tunnels in winter is icicles. The line has been closed for days because of them, although why that should be so when the snow plough gets through intrigues me. Fast forming ice in very wet tunnels, presumably.
I suspect modern tunnels are designed to channel water away from the sides to prevent spears of ice forming and likely to take out cab windows and drivers. Steam trains just crashed through them!
furnessvale
14 Jul 2015
The answer is frequent train movements.
A couple of winters ago NR lost a number of lines to snow. I do remember one announcement at 8pm one evening that they had cleared one line of snow and it was their intention to start running trains the following day. No prizes for guessing that the following morning drifting had put paid to that idea!
and
Thanks for some interesting information. One would assume that such a level of humidity would be fairly unique.
I understand that the Southern Region used to run electric trains all night during such temperatures to keep the third rail ice free. Perhaps a Northern equivalent for the Hope valley ?
hwl
5 Feb 2012
They still do on many (but not all) routes
driver_m
8 Nov 2011
It wouldn’t stop it. We had some ridiculous icicles in Kilsby Tunnel on the WCML a couple of years ago and that’s used intensely. That didn’t stop icicles forming.
furnessvale
14 Jul 2015
I have several DVDs from the USA which show the local track supervisor shooting icicles down with a 12 bore!
59CosG95
18 Aug 2013
Between Peterborough & Bedlington
Of course, the increased current in the 750V DC 3rd Rail heats the metal up a lot more than the lessened current in the 25kV AC OLE would...and the problem isn't icicles as much as water solidifying on top of the 3rd rail, insulating trains from the supply.
But yes, shotcrete-lined tunnels aren't immune to ice, as it can indeed still form on the OLE.
18 Oct 2017
AIUI - London Underground do similar, some of their trains carry de-icer for the third rail also.
ajdunlop
25 Jan 2009
Only for Huddersfield to Dewsbury, I assume improvement between Huddersfield and Manchester will occur at the same time?
Spartacus
25 Aug 2009
At best I couldn’t see that happening as it could leave Huddersfield cut off, even the work on this I expect to be staggered to keep disruption to a minimum.
Depending on how the work is phased, it's possible Huddersfield could keep a link to Leeds throughout, although it could be via Halifax for some of the time.
CdBrux
4 Mar 2014
Munich
second phase of consultation targeted at the changes made as part of phase one will take place in Spring 2020 before the submission is made to the Secretary of State in Autumn 2020. A decision is expected in 2022 and if approved, work covered as part of the proposal is expected to begin immediately
How long have NR had to get just to this stage? How long does government need to take a decision? So nothing to actually start work for close to another 3 years!
61653 HTAFC
18 Dec 2012
Another planet...
According to the Examiner, Network Rail plan to 'double the width of the tracks'. Brunel would be delighted!
Like most Mirror Group local newspapers the "Unexamined" is a pale imitation of its' former self, and no longer worth the paper it's printed on nor the web space it's hosted on.
matacaster
19 Jan 2013
I'm a bit confused!
Press release says Huddersfield to Dewsbury will be electrified. Now forgive me, but doesn't that mean the plans don't include electrifying the awkward Leeds to Dewsbury bit with Morley tunnel, nor the other awkward bit from Huddersfield to Stalybridge which includes Standedge Tunnel. Does this mean that these sections will be on diesel? Have NR got tunnel phobia these days on electrification projects?
Press release also says tracks doubled from 2 to 4 between Huddersfield and Dewsbury - I seem to recall that there are 3 tracks already from Ravensthorpe to Heaton Lodge junction, does this mean we'll get 6 tracks here????
CrickUK
23 Aug 2017
Is the key issue here that NR propose to build outside the demise of the existing railway boundary and hence need to undertake a public consultation?
"A TWAO is a legal power required for new railway infrastructure to be built outside of the existing operational railway boundary, which is part of the proposal between Huddersfield and Westtown (Dewsbury).
Landowners directly affected by the proposals were written to in the Summer, while every residential property and business within 1km (just over half a mile) either side of the railway will receive an invitation to the public consultation events in the post in August."
I suspect that works between Dewsbury and Leeds will remain within the boundary and therefore consultation is not needed, it does not necessarily mean that no work is taking place between Dewsbury and Leeds
hwl
5 Feb 2012
I'm a bit confused!
The consultation appears to relate just to one local council area?
I'd take it as bit of simplification that they are going from effectively a 2 track with an extra track in places to 4 track.
It may be that there are different teams doing different sections of the route and the whatever they are doing north and south of here isn't ready to go to consultation yet.
59CosG95
18 Aug 2013
I'm a bit confused!
This might help explain more of the project - certainly the electrification side of it. https://www.networkrail.co.uk/runni...te-upgrade/huddersfield-to-westtown-dewsbury/
Spartacus
25 Aug 2009
I believe the main thing is the need to use additional land around Raventhorpe, to provide for a new station and dive under there. Suspect this will be Newlay Concrete and possibly Wrigglesworth Storage.
We’ve got our consultation invites today so tempting to pop along to one.
daikilo
2 Feb 2010
Bantamzen
4 Dec 2013
Baildon, West Yorkshire
I'm intrigued as to why NR state "electrification from Huddersfield to Ravensthorpe and right through to Leeds". Are they leaving open the choice of route from Ravensthorpe to Leeds despite the considerable added distance via Normanton?
The North Trans Pennine project has been broken up into different stages, so Stalybridge to Huddersfield, Huddersfield to Ravensthorpe, Ravensthorpe to Leeds. There is some further info on this further up this thread.
But basically the plan is to wire from Huddersfield to Leeds, the Huddersfield to Ravensthorpe section will be four tracked, with the slow lines to the north & fast lines to the south of the track alignment. Then at Ravensthorpe the slow lines with dive under the fast, with the (wired) fast lines continuing to Leeds via Dewsbury. I believe this will then allow both Wakefield - Huddersfield & Leeds - Brighouse stopper services to pass through this section without snarling up the fast TransPennine services.
