Transpennine Route Upgrade and Electrification updates
paul1609
28 Jan 2006
K
I think he was referring to the two disused single bores, where OHLE would be a tight fit.
Nevertheless, the enlargement of a tunnel less than 100 yards in length (IIRC) won't hold too many lessons for tunnels which are 3 miles long through very different geology.
Wasn't it reported that electrifying the Severn Tunnel wasn't a problem? But reality is now beginning to be revealed?
Class 170101
1 Mar 2014
Guide Bridge Jn - Stalybridge as an infill scheme is only 6.7 stkm of electrification so small easy add on later.
Definitely an infill and worth having. I guess the question might also be an environmental one though. As I recall the government lost a case in court concerning emmissions (at source) in urban areas and were instructed that they had to publish a strategy that was either being kept under wraps or create one? Surely electrification will help this in respect of Greater Manchester?
furnessvale
14 Jul 2015
AIUI the actual electrification wasn't too difficult. Problems are now occuring with SALT water ingress into a sub sea level tunnell affecting the equipment. Hopefully a problem not to be found at ca. 600ft ABOVE sea level!
hwl
5 Feb 2012
If I'd have an educated guess I'd say they are going for a strategy by Christmas 2020;)
Suggested case study locations gratefully received by PM:lol:
61653 HTAFC
18 Dec 2012
Again, an environmental case for wiring Stalybridge to Guide Bridge can only be made from the point of view of shifting folk out of their cars and onto a new Electric service. An infill which only sees use for empty stock movements (and the occasional diverted bi-mode being able to stay on electric power) simply won't cut the mustard.
Clearly they need to do the whole thing from Guide bridge to Huddersfield.
IanXC
Emeritus Moderator
18 Dec 2009
To the more electrically minded... Would Guide Bridge to Stalybridge have a positive effect in terms of the resilience of the wider electrified railway around Manchester?
hwl
5 Feb 2012
Very very positive
61653 HTAFC
18 Dec 2012
Absolutely. Doing so would actually allow services to run on electric. Spending however many £m per mile wiring something that won't actually reduce DMU use will just make Central government less likely to fund electrification in the future.
Very very positive
Resilience and diversion can't be the main motivating factor behind wiring. If it was, BR would have wired Preston-Hellifield-Carlisle at the same time as the Northern WCML.
I'm not opposed to electrification at all, I'd rather see all cross-Pennine routes wired than none... but Stalybridge to Guide Bridge is turning into the "Bradford Crossrail" of electrification: people want it because it'll look neat on a map, not because it will actually improve anything.
Wire the whole route as far as at least York, then doing this short infill does make sense, but without it you'd just be giving more credence to those who think the railway can't be trusted with investment.
td97
26 Jul 2017
Could shift inner city stops (Ashburys, Guide Bridge etc.) from the Rose Hill service (DMU) onto the proposed EMU Stalybridge stopper. Which would be a better use of capacity etc.
paul1609
28 Jan 2006
K
Are the Stalybridge tunnels dry? Most of the tunnels here in the South have water pouring in to them. Sevenoaks is so bad Im surprised Southeastern haven't installed brushes for a free wash as you pass through.
61653 HTAFC
18 Dec 2012
Though TfGM still want to look at tram-trains for Rose Hill don't they? A better choice than Glossop and Hadfield at least.
furnessvale
14 Jul 2015
Precisely why I highlighted "SALT water" and the height above sea level.
Fresh water can be channelled away in good cess drainage and being on top of a hill gives the water somewhere to go without expensive pumping like the Severn tunnel.
gimmea50anyday
8 Jan 2013
Back Cab
So all that money and (wo)man hours it cost to lay that extension cable has effectively been wasted now the wires are going up. For the cost of that cable they might as well have done the job anyway...
Ploughman
15 Jan 2010
Near where the 3 ridings meet
If I recall right from working in there.
Standedge tunnel was slightly damp at the ends and dry in the middle.
Which created the problem of ballast dust rising in the air when digging. Big fans usually sorted that though.
NorthernSpirit
21 Jun 2013
Tampers and other track plant are permitted to cross the viaduct, just not allowed to actually tamp! AIUI all ballast repacking on the structure is done the old fashioned way, by a human with a shovel!
I'll stand corrected on the fact that Tampers can cross.
What's the chance that Huddersfield Viaduct is also a listed structure? The rate its looking for this Transpennine Route Upgrade there seems to be more work required than just rebuilding stations, sewing the knitting up and dealing with tunnels taking in consideration of what was mentioned earlier about the viaduct.
gimmea50anyday
8 Jan 2013
Back Cab
Standedge tunnel is certainly a bit wet at the Marsden end as you have the aqueduct feeding the canal ajacent to the tunnel portal, apart from that it has always seemed pretty dry whenever I have hammered through it at 85mph!
You are only likely to get wet if you miss your footing in the cross passages and fall in to the canal underneath!
Elecman
31 Dec 2013
Lancashire
No it is now an Independent Feeder so it can remain energised when the rest of the OLE is isolated, just as the Western Region version will as well
plarailfan
6 Feb 2013
56D
When I started working on Huddersfield station back in 1979, I remember around the time, that some work was done on the viaduct because an in depth inspection, revealed some of the stone uprights and arches consisted of hollow areas, that were found to have been filled with mud during the original construction !
I presume some of it must have been removed and replaced with concrete, but to what extent this was done, I have no idea !
61653 HTAFC
18 Dec 2012
The viaduct situation may not necessarily so severe as to require complete replacement. As I said my source for that is not linked to NR or any infrastructure contractors. It definitely needs some work to carry wires and four tracks again, the extent and cost of that work is yet to be determined.
My understanding of the tamper thing (which might not be correct) is that it applies to all on track plant. Basically said machine can cross the viaduct under its own power but not perform its actual function, be that tamping, rail-grinding, ballast cleaning or whatever else.
AndyHudds
17 Jun 2012
I can confirm it is listed and has been since 1978.
61653 HTAFC
18 Dec 2012
Some listings seem to be of dubious merit, this one included. Pretty much every town in the North has a stone railway viaduct somewhere, is there something particularly unique about the Huddersfield one other than it being the location of the first write-off of a Pacer*?
Corners being cut during construction (as alluded to a few posts back) certainly isn't unique, given the number of tales I'd suggest that Victorian building contractors were pretty much expected to commit these acts of fraud!
*=on second thoughts, for that it shouldn't just be listed, it should be canonized! :lol:
AndyHudds
17 Jun 2012
I mean yeah, there is nothing architecturally merit worthy and as you state every town in the north of England has one. Other than York, Bath and London Huddersfield has more listed buildings than any other place in Britain, ranging from beauties as the railway station itself to the red phone boxes on Northumberland Street and the rather ugly Queensgate Market hall so maybe the listing mania must have gripped the listers who listed everything in sight, including the rather none descript viaduct!!!!
Wasn't a pacer written off at Lime Street too? Which was first?
61653 HTAFC
18 Dec 2012
142059 written off at Lime Street in 1991.
141104 written off just outside Huddersfield in November 1989.
Greybeard33
18 Feb 2012
Greater Manchester
Very very positive
Which undermines the resilience argument for wiring Guide Bridge to Stalybridge. The Heyrod to Ordsall Independent Feeder (a.k.a. the Great Extension Lead) will enable the Heyrod grid feeder to continue to supply the wider Manchester network, via the Ordsall Lane ATF station, in spite of any problems with the OLE between Victoria and Stalybridge.
Bevan Price
22 Apr 2010
The Royal Border Bridge at Berwick is listed -- and electrified..
61653 HTAFC
18 Dec 2012
The concern wasn't really over listed building consent to put the wires up, more about the condition of the viaduct and the possible costs of any repairs to the structure.
If (and I stress IF) the viaduct is in very poor condition, replacement could potentially be cheaper than repair (though disruption would be huge) but as a listed structure that would need to be justified.
Fitting OHLE equipment to listed structures is permitted, there are many examples besides Berwick... but it also pushes up costs as the design has to be signed off by Historic England (IIRC).
61653 HTAFC
18 Dec 2012
NOTE: the above post was originally in the thread discussing the consultation process for the Huddersfield to Ravensthorpe section of route.
I’m sure the planned station is actually closed to the Arlington Business Park, than the White Rose anyway, so would be good for commuters who work there.
Which further calls into question the wisdom behind putting a station there: if it isn't going to be that convenient for the WRC, don't call the station White Rose Centre. If it's primarily for commuter use outside of the retail sector, the peak demand will be in the traditional rush-hours- right when overcrowding is already at its worst.
Leeds City Council seem to want to have their cake and eat it too. Today they've been awarded (among many other towns/cities) funding intended to revive "historic high-streets", despite having had millions invested in the city centre over the last decade. Notably Sheffield, which suffers far more due to a nearby mega-mall, is absent from this list.
Grumpy
8 Nov 2010
Which further calls into question the wisdom behind the putting a station there: if it isn't going to be that convenient for the WRC, don't call the station White Rose Centre. If it's primarily for commuter use outside of the retail sector, the peak demand will be in the traditional rush-hours- right when overcrowding is already at its worst.
Don't worry about it. The display boards at the public consultation showed the new station to be sited almost next to the A643. Possibly the worst location commercially. So not only wont it be attractive for shoppers it will be less appealing for office workers. I am guessing the proposed unsatisfactory location meets the ORR's fetish with not building platforms on curves (due to the hundreds of accidents every year at the likes of Newcastle, York and Shipley). I agree it shouldn't be called White Rose-White Elephant would be more appropriate
