But as has repeatedly been said on here, the blockers are DfT not TPE.TPE have had ample time to sort this and should be stripped of the mgt contract they are utterly failing the communities they purport to serve
First at least shouldn't be permitted to profit from this debacle.
Yes that happened in late 2000. Most areas where the at risk rail was used was reduced to 20mph. Caused chaos at a time when thousands where still visiting the Millenium Dome which is how I recall the year.Thanks. I couldn't decide if it was late 90s or early 2000s, but I do know it was while I was at university.
As it stands tonight although regular users know they have to constantly check timetables and apps to see which trains are likely to complete their full runs on the day.
Try working out quickly which trains you may find running between a pair of stations from this list for tomorrow. It's a hit and miss service, book at your peril. Some now showing as running probably won't.
Cancellations;
Manchester – Cleethorpes
0345 Sheffield – Manchester Airport
0521 Sheffield – Cleethorpes
0556 Manchester Airport – Cleethorpes
1624 Cleethorpes – Manchester Piccadilly
1918 Manchester Piccadilly – Cleethorpes
1924 Cleethorpes – Manchester Piccadilly
2024 Cleethorpes – Manchester Airport
2124 Cleethorpes – Sheffield
2220 Manchester Piccadilly – Doncaster
2330 Manchester Airport – Sheffield
The following services are being amended;
0536 Doncaster – Manchester Piccadilly – Starts Sheffield
1618 Manchester Piccadilly – Cleethorpes –Terminates Sheffield
1718 Manchester Piccadilly – Cleethorpes – Terminates Sheffield
1724 Cleethorpes – Manchester Piccadilly – Starts Sheffield
1824 Cleethorpes – Manchester Piccadilly – Terminates Sheffield
2052 Manchester Airport – Cleethorpes – Terminates Manchester Piccadilly
*Further short-notice cancellations and amendments to services are likely throughout the day
Why not? What bit of their contract with the DfT have they not complied with?
It's both. The DFT aren't helping matters to put it mildly, but TPE is also mismanaged and has been for a long time.Why not? What bit of their contract with the DfT have they not complied with?
What would change if it was OLR? Answer: Nothing.It's both. The DFT aren't helping matters to put it mildly, but TPE is also mismanaged and has been for a long time.
Not neccesarily. LNER isn't mismanaged, or at least if it is then not to anywhere near the extent that TPE is. Not all issues are down to the DFT.What would change if it was OLR? Answer: Nothing.
Doesn't their contract with the DfT require them to operate something approximating to the timetabled train service?
Seemingly not they are worse than Northern before they were taken over. OLR didn't need to takeover SE that was done for political reasons and the resources would have been deployed to where "last resort" is true reflection of the state of the service ie TPEDoesn't their contract with the DfT require them to operate something approximating to the timetabled train service?
Read back through this thread and you’ll see multiple reports of services being cancelled at TPE’s discretion despite the crews all being available.Where is the current mismanagement with TPE? We know of the historical issues but what has the current top management got wrong, given the current IR and DfT issues?
And who put the over optimised diagrams there in the first place? (pardon the pun!)I’ve read it and, as stated earlier, the problem here is that crews are not available for the whole of that units diagram day. If they are not available that unit diagram gets binned.
What NR and the DfT don’t want is stranded units clogging up the network or stranded passengers having to be shifted at short notice. So the “modern” way of dealing with this on todays railway is binning off services early if the job is likely to be uncovered. This doesn’t only apply to TPE. So the result here is you get train crew sitting in mess rooms and units sitting on depot because of staff shortages elsewhere.
If you have over optimised your diagram structure (i.e. frequently changing crew), the more likely you are going to cancel if you are short. It may only take one driver or conductor being short to cause this to happen. The way out of this is to employ more staff to unpick the idiotically optimised diagrams. Now who authorises this?
Which is also historic. You're taking anecdotes as gospel truth without understanding what happens further down the line. Simply put, the wider industry doesn't want units dumped in platforms in stations blocking paths.And who put the over optimised diagrams there in the first place? (pardon the pun!)
TPE aren’t innocent in this.
LNER are now cancelling services the night before.Not neccesarily. LNER isn't mismanaged, or at least if it is then not to anywhere near the extent that TPE is. Not all issues are down to the DFT.
So you think TPE employees are making up sitting in mess rooms whilst trains are cancelled then? As that's what you seem to be implying.You're taking anecdotes as gospel truth without understanding what happens further down the line.
Yes, but not when there's crew available to run them. LNER don't have crew sat in mess rooms whilst services are cancelled - TPE do. LNER make an active effort to rework diagrams around crew availability on a daily basis to avoid having to cancel entire diagrams - TPE don't. That's the difference.LNER are now cancelling services the night before.
And yes: the issues do lie with the DfT, as the service worked swimmingly until rest day working agreements ended.
So again, what would change? Nothing.
Well, yes. I think we're all agreed that the current way of doing things is terrible.The franchises were terminated, the Government took over and money changed hands to do so. So it became the Governments problem at no future cost or liability to the Owning Groups.
Did you read my reply? Or have you chosen to completely ignore it?So you think TPE employees are making up sitting in mess rooms whilst trains are cancelled then? As that's what you seem to be implying.
Bold claim, any evidence to support it?LNER don't have crew sat in mess rooms whilst services are cancelled.
But they are. If RDW was in place, would there be the issues being seen currently? No.I didn't say the DFT were blameless far from it. But they're not the sole problem.
Crew diagrams yes but stock diagrams if anything are actually more restrictive on LNER, as they have more sub fleets than TPE do (5 on LNER all interwork to some extent vs 4 on TPE of which one is almost entirely self contained). LNER can (and do) still end up with stock taking up valuable platform space for hours on end as a result of the cancellations.Totally different diagram structure - that’s the difference. Much easier to recover on LNER.
Which is why over optimistic diagramming is a mugs game because if you are short or it goes wrong, you are up that certain creek without a paddle in next to no time. Add in an IR dispute which makes some staff understandably less willing to change their diagrams on the day and it quickly becomes a total mess.
Which is why it is thought preferable to bin off, even it means some crews sit in the cabin when they could be out working part of a diagram.
Yes I read it, and I've just reread it to ensure I hadn't missed anything (which I hadn't). What you are saying does not change the fact that some operators are much more willing to work around these restrictions than TPE are. LNER have been dumping stock in platforms for hours on end with nobody to move them, but somehow when it's LNER doing it it's suddenly not considered a problem.Did you read my reply? Or have you chosen to completely ignore it?
Just because, say Newcastle depot, has the staff to begin a service doesn't mean the staff at a change over point are available. And signallers and the wider industry do not want trains being dumped in platforms with nobody able to move them. One anecdote from one person at one depot does not give the overall picture.
Any evidence to suggest otherwise?Bold claim, any evidence to support it?
Not to the same extent but there would still be issues yes. We have seen time and time again that TPE are incapable of running their promised timetable, with or without RDW.But they are. If RDW was in place, would there be the issues being seen currently? No.
So the poor management decisions that others are saying are historical are in fact still being made then!Just lost all 185 work so potentially losing traction knowledge too. Another managerial decision Merely exacerbating the very problem we keep highlighting and this is down to the decisions of the company’s current, not historical management!
TPE's timetable is already significantly reduced from what it was pre covid. An emergency timetable for TPE would basically be bin the entire lot.Or you operate a reduced emergency timetable with those simplified diagrams and the staff you have.
The core issue of the of the excessively-optimised problem, as already described in this thread, is that those "random" trains can have staff available at the time the observation is made, but be missing cover later in the diagram - so cancelling them at the beginning is seen as less disruptive to the network overall.To quote a driver on York platform yesterday “the problem is they keep cancelling random trains that we have staff for”. Platform full to bursting after 6 car train cancelled and what comes in a 3 car! Went and got on a slow via Harrogate train to Leeds to avoid being crushed.
Which in turn is down to decisions made on route knowledge and operations which are surely TPE decisions. The cynic in me would say TPE have maximised profit over network resiliance, and being even more cynical TPE thinking is 'We know we will get the boot sooner or later, lets bleed it for everything we can'The core issue of the of the excessively-optimised problem, as already described in this thread, is that those "random" trains can have staff available at the time the observation is made, but be missing cover later in the diagram - so cancelling them at the beginning is seen as less disruptive to the network overall.
Yes....using hired-in 158s.It had also at one point I believe been briefly run by Virgin West Coast.
