Trivia: Rail journeys between stations where the shortest route is not the quickest
PTR 444
22 Aug 2019
Wimborne
The completion of HS2 will open up new routes between stations which will be much faster than before, but also cover more rail mileage. An example is London to York, which will become much faster via Birmingham even though that route will be longer distance wise than the ECML. It has got me wondering whether there are that many instances at present where a pair of stations has two or more different rail routes between them, but the shortest of these routes is not the quickest in terms of journey time.
Llandudno
25 Dec 2014
Chester to Manchester Piccadilly is quicker via Warrington BQ than Via Northwich, which I would assume is a shorter route.
AndyNLondon
20 Jan 2014
Cambridge to London is one: the route to Liverpool Street is shorter, but Kings Cross is faster.
FenMan
13 Oct 2011
There are numerous examples from my local station, Blackwater on the North Downs Line, albeit with changes.
A few off the top of my head with the shortest route / quickest route:-
Croydon Stations - meandering through various Surrey shacks NE of Guildford / via Redhill.
Hastings - via Tonbridge / via Gatwick Airport
Dover Priory - via Tonbridge / via London Stations (via Paddington and St Pancras is quickest)
Leatherhead - via Effingham Junction / via Dorking Stations
Hereford - via Evesham / via Newport (Gwent).
MontyP
18 Nov 2015
Hull to Doncaster - shortest route is via Goole but the quickest trains are the London trains via Selby.
York to Sheffield is not quicker via Pontefract Baghill, at least not by taking scheduled timetable services, which I assume is what you meant?
(If a train was diverted via PFR, it would be a close-run thing whether this is quicker than going via Doncaster. Given a perfect run, York-Doncaster can be done in ~19 min and Doncaster-Sheffield in ~18min, giving ~37min. It may be possible to go via PFR faster than this, but probably not; others may be able to comment on this with more accuracy than I can)
PTR 444
22 Aug 2019
Wimborne
Yes.
Interesting observation. I suppose another point to consider is whether the diverted XC service is slowed down by the local stopper on that line?
Yes.
You'd have to be unlucky!
Do your examples have to be possible by a direct through train? You may want to edit your opening post to make this clear. If not, the examples are almost infinite!
A few more examples which are possible by through trains:
Glasgow to Edinburgh - via Falkirk faster than via Shotts or via Bathgate
London to Birmingham - Euston to New St via Rugby faster than Marylebone to Moor St via High Wycombe
London to Horsham - faster via Gatwick on GTR but SWR is more direct
Wakefield to Sheffield - faster via Moorthorpe but via Barnsley is more direct
London to Exeter - faster from Paddington but the distance is longer than from Waterloo via Salisbury
Wigan to Manchester - fast trains go via Eccles but the Hag Fold route is shorter
Sunderland to York - LNER's daily through train is faster than Grand Central despite taking a longer route via Newcastle
PTR 444
22 Aug 2019
Wimborne
All of the above examples are valid. I am looking for any legitimate A to B journeys that the general public would consider making, so these do not have to be through trains between the two stations and can even include separate stations in the same town/city centre (eg. Marylebone - Snow Hill vs Euston - New Street).
24 Sep 2017
Craven Arms to Llanelli via Heart of Wales or Newport. There's actually not as much difference time-wise as I had expected.
PTR 444
22 Aug 2019
Wimborne
I was wondering whether this was the case when I created this thread but wasn’t entirely sure. The HoWL route is 90 miles whereas going via Newport is 140mi in total. All Manchester - Swansea trains take the latter route with fewer stops, so I presume this would be the quickest when compared with the HoWL stopper which is constrained by single track sections.
berneyarms
26 Nov 2013
Dublin
Except that the distance is shorter via Warrington BQ, mainly as the trains via Northwich have to divert via Stockport
Via Warrington is 40.2 miles while via Northwich and Stockport is 45 miles.
backontrack
2 Feb 2014
The UK
Margate to London is probably quicker on HS2 into St Pancras but more direct via Herne Bay into London Victoria.
aliceh
11 Oct 2019
Bournemouth
I've only done a quick distance calculation, but Bournemouth to Bristol is quicker via Southampton and Salisbury than the (just slightly shorter) Dorchester and Yeovil route.
It's also quicker by the definitely longer Cross-country to Reading and GWR fast to Bristol route.
Master Cutler
23 Jan 2021
Mansfield
I've done Euston Chester via Warrington BQ (Avanti - TFW) quicker than Euston Crewe Chester on the late night service.
The risk is making the change at BQ with only 4 minutes to spare.
Llandudno
25 Dec 2014
I stand corrected, both routes seem a bit convoluted and whichever route you take it feels like an eternity to get from Chester to Manchester!
Sometimes it almost ‘ feels’ quicker to travel between Chester and Piccadilly by changing at Crewe!
Mag_seven
1 Sep 2014
here to eternity
Swindon to Cheltenham can often be quicker via a swift change at Bristol Parkway rather than via the more direct and shorter route via Kemble. This is generally due to the via Kemble trains reversing at Gloucester whereas the Cross Country trains via Bristol Parkway don't.
FenMan
13 Oct 2011
I think on that one, the shorter route via Tonbridge is still quicker.
Yes, it is at the moment. Going via Gatwick was quicker for years, but nudges to the timetables have knocked the Gatwick connections out of sync when returning from Hastings.
Ah, thanks. I was always of the impression that the BML service was run more for the benefit of Eastbourne.
SuspectUsual
11 Jul 2018
Peterborough to Manchester is quicker changing at Doncaster then going direct with EMR
-Colly405-
25 May 2018
Stoke Gifford
Not quite answering your question, but the traditional (and even now, principal) route from London to Bristol is neither the quickest nor the shortest.
PAD-BPW-BRI is both quicker and shorter than PAD-CPM-BRI.
LSWR Cavalier
23 Aug 2020
Leafy Suburbia
@PTR 444
York to London, faster via Birmingham? Seems a bit crazy, unnecessary, a much longer route but less time for the journey because trains would go much much faster. Direct trains via Grantham are fast enough already, I think
I should rather see better connections to Little Snoring, instead of even 'better' services to places that already have very fast and frequent services
341o2
17 Oct 2011
When I first visited the Isle of Wight after moving to the New Forest, the route was given as change at Southampton and again at Fratton, stopping train took ages, on return was advised Portsmouth to Eastliegh, Eastliegh to Brockenhurst far quicker.
So, to be clear, the two stations are Southampton Central and Portsmouth Harbour
There is less than two thirds of a mile in it - and at the moment there's just one direct train a day via Parkway. However, the connections currently work well at Parkway in both directions, so it's still quicker to go that way if you've just missed a train via Bath.
There are lots of journeys where it's quicker to double back between Didcot and Reading, although the reduced frequency of fast GWR & XC services to Oxford and beyond has changed this in some instances.
Old Yard Dog
21 Aug 2011
Actually its 40¼ miles via Warrington BQ and 44¾ miles via Northwich, the diversion via Stockport adding considerably to the latter route.
norbitonflyer
24 Mar 2020
SW London
Lincoln to Peterborough
- via Sleaford, 56.75 miles, 80 minutes
- via Newark, 60.25 miles, 60 minutes
The time advantage via Newark used to be smaller when a change at Newark was required, (and often evaporated as the connections were notoriously unreliable) but the direct Lincoln to London services via Newark introduced in late 2019 (eight years late) have changed all that.
