Trivia: Stations that can be seen from the train that are not on that route
SWTCommuter
17 Oct 2009
Canary Wharf tube station is visible from the DLR between Heron Quays and Canary Wharf DLR
Spaceflower
13 Jul 2007
Most stations on the Tyne and Wear Metro between Pelaw and Gateshead Stadium.
Darlington if on the train that doesn't stop.
Knottingley on a GC train.
Ravensthorpe.
Buttsy
20 May 2011
Hanborough
Barnhill from a Cumbernauld train?
Cathcart from a Newton via Maxwell Park train?
Aylesbury Vale Parkway on a Quainton Road train.
Oulton Broad North from a Lowestoft train
Ash Bridge
17 Mar 2014
Stockport
A few hundred yards to the east, Wigan North Western station can be seen from Manchester - Wigan Wallgate trains (admittedly there are connections between the LNWR and L&Y routes just south of Wigan NW)
It's a while since I travelled this way, but I think you can see New Mills Central (on the Chinley line) whilst travelling east of New Mills Newtown (on the Buxton line). These are definitely different routes, running either side of the Goyt valley.
On a similar theme, I think you can see Furness Vale Station on the LNW route to Buxton from a train travelling on the former Midland route.
D6975
26 Nov 2009
Bristol
Quite a long distance one - from Barry Island on a clear day you can see the plumes of smoke from the kettles on the West Somerset as they go along the coast from Blue Anchor to Watchet.
adamt958
20 Jun 2013
You can see Wildmill from the SWML on the approach to Bridgend from the swansea direction
Taunton
1 Aug 2013
Brockley, on the London Bridge to East Croydon line, actually has its platforms bridged by the Victoria/Peckham to Lewisham line, but it takes two changes and the best part of an hour to get from one level to the other.
Aldgate, on the London Underground Ciccle and Met, must be the nearest "miss", the Hammersmith & City Line junction is right at the north end of the platforms, so much that you could actually step from a westbound H&C train down onto the end of the platform ramp.
Having been up on the roof of the station building at West Kirby we discussed when up there whether you could see, on a clear night, the lights of trains on the North Wales main line at Talacre, although that's not a station. You can certainly see them, and occasionally faintly hear them, from the West Kirby seafront a couple of roads away.
I wonder if, with good binoculars, you can see any part of the Sangatte station structure in France from the line between Folkestone and Dover.
61653 HTAFC
18 Dec 2012
I'd have thought places like Dunbar wouldn't qualify for this topic, as while the platform is on a loop off the mains it is immediately adjacent so is essentially part of the same alignment. Likewise I wouldn't include Levenshulme/Heaton Chapel from fast Manchester-Stockport services. The DC-lines are tricky, though I'd say stations from Euston heading North to Watford High Street would qualify (providing they can be seen from the AC lines!) with the exception of Wembley Central; Harrow & Wealdstone; and Bushey which all are essentially part of the same station and would provide interchange for any services that called on the 'mainline'.
dcsprior
28 Aug 2012
Edinburgh (Fri-Mon) & London (Tue-Thu)
Perhaps stretching the definition slightly, but: Bruntsane from the Edinburgh South Suburban Railway. The reason I say its stretching it is:
  • I believe there is only one scheduled passenger service a day on the South Sub - the 2105 Glasgow Central -> Edinburgh Waverley
  • The line goes right past/through Bruntsane Station, but there is no way for the train to get to the line alongside the platform without going past the station and reversing
infobleep
27 Feb 2011
Not fully mentioned is Wilsden Junction. Even if ignoring the low level part of the station, the higher level can be seen from mainline services and DC/underground services.
If including avoiding stations then there is Didcot but I don't think they should count, given the junction is classed as part of the station for routing and ticketing purposes.
Sent from my Nexus 5 using Tapatalk
PaulLothian
27 Sep 2010
Linlithgow
There are examples just south of Glasgow Central where all the lines intertwine and pass each other. You can see Pollokshields East from the line to Kilmarnock, and the line the "other way" round the Cathcart circle. It's a weird case where the train drives right by a station it'll stop at 20 minutes later, on the same run!
I like the trip from Glasgow Central to Newton via the west side of the Cathcart Circle - you go straight past the end of the platform of Cathcart Station, crossing the outer circle at the tip of the platform.
dannypye9999
28 Jun 2013
On approaching Euston station on a virgin a few years back I remember seeing a 'hole' in the ground with a tube line or something running under it like a tunnel with an opening in the roof to let in light. It was like a big diamond shaped hole with railings around it. Just wondered what this line is that runs though it?
Cherry_Picker
18 Apr 2011
You can just about see Hatton on a Dorridge - Stratford train
I've been around all three sides of the triangle at Hatton this week, you can't see the station from the North/West curve which the Stratford via Dorridge trains take. Too many trees in the way.
contrex
19 May 2009
St Werburghs, Bristol
I can think of a couple in the south east...
A few I remember... I don't know if vegetation has changed the first two:
Between North Dulwich and Tulse Hill you can see Herne Hill
Between West Norwood and Streatham Hill you can see Tulse Hill
On the way into Victoria (Eastern) you can see Queenstown Road (or Queens Road Battersea as I still think of it)
FQ
Quizmaster
4 Oct 2013
I don't know if this would count but what about Bethnal Green from a London Liverpool Street-Norwich train?
moogal
18 Oct 2012
Milton Keynes
Another Overground one: Dalston Kingsland from the ELL just as you veer off towards Dalston Junction.
You can also see Shadwell Overground from Shadwell DLR (no physical connection between them, just an OSI)
