Trivia: Stations with surviving run-around loops?
Romsey
30 Nov 2019
Near bridge 200
Weymouth has RR facilities between platforms 1 & 2.
Lots of crossovers at Bournemouth, but it isn't signalled for RR movements unless there are no other movements in the area.
The RR was removed from Portsmouth Hbr in the 1960's resignalling, so all trains needed a turnover loco.
Eastbourne has a GF and RR line alongside platform 1. Any charters or engineering trains are top and tailed because it's easier.
d9009alycidon
22 Jun 2011
Eaglesham
Looking at on-line photos it would appear that Wick and Thurso still have ground frame operated release crossovers, unless they have been removed in the last two years.
lyndhurst25
26 Nov 2010
AFAIK locos can still run round at Cleethorpes.
One station where you thought that it may be possible, but isn't, is Hellifield. DMUs can't even reverse there and have to travel to Settle Junction to do the manoeuvre. A loco hauled train would have to go all the way north to Blea Moor for the engine to swap ends.
30907
Isn't that to do with the signalling/lack of point locks rather than lack of loops?
3 Mar 2020
Furness
As used by the Harwich Boat Train, which used to bring a class 37 to Manchester when I were a lad.
Didn't the Cardiff services pre sprinterisation, alternate between Liverpool and Manchester ?Thus bringing a 37 to the North , which had to go back towards Wales straight away. I.e. not involve this shunt release and sit in a siding till later movement , mentioned earlier in the discussion.
Trackman
28 Feb 2013
Lewisham
Those ground frames at Piccadilly were controlled from a small wooden box at the front of the platforms.
Once the shunt signal was set, the PB would release the ground frame and you would rotate a switch to move the points.
alistairlees
29 Dec 2016
Unless things have changed I believe there is a loop on the bus station side but just a siding on the retaining wall side.
The second crossover was (is?) between the middle two platforms (platforms two and three I assume).
alistairlees
29 Dec 2016
Manchester Piccadilly, and Liverpool Lime Street for loco-hauled Cross Country services up until the early 2000s.
Which platforms at Lime Street? I don’t remember that. All north and south Pennines, and trains to / from Preston and beyond, were shunt released in the 1980s. As were electric services from Euston. I can’t remember about cross country, but would have thought they were too.
Ashley Hill
8 Dec 2019
The West Country
Barnstaple has a loop just off the platform accessed by a 3 lever GF. It was used for Exeters famous scratch sets. I'm surprised it still survives. It replaced the old run round loop via the disused down platform.
tomsy47
23 Jun 2017
The Bunk
Cholsey platform 5 has one for the Cholsey and Wallingford Railway. while the line is completely separate to the main line, the station is National Rail, so might count!
Dave W
27 Sep 2019
North London
Enfield Town still has a ground frame between two of the lines. If I remember rightly, that may have outlived the actual crossover... Can’t recall accurately.
EDIT: Nope, it’s still there.
High Dyke
1 Jan 2013
Yellabelly Country
Manchester Piccadilly still has a ground frame between Platforms 5 and 6.
Oddly enough I recently saw a picture of a Class 60 on the blocks at Man Picc, running round a freight. For some reason the normal route for the freight was blocked and the signaller convinced control to allow it to run into Man Picc.
