Trivia: Unusual train services
agbrs_Jack
28 Apr 2017
Congleton / Milton Keynes
That is an oddity alright, and misses cheadle Hulme out too, despite slowing for the junction anyway, but I guess it stops people changing for Stockport! I don't know why you can't go to Stockport then, but they really have made sure you can't.
Similarly the 1258 SOT-MAN Monday to Friday calls at all from Stoke (except Longport) then non-stop Cheadle Hulme to Manchester Piccadilly
Flange Squeal
17 Jul 2012
07:34 Waterloo to Guildford
There are three regular routes between these stations, taking around...
via Guildford: 34 mins
via Cobham: 59 mins
via Epsom: 71 mins
This train runs an even more ‘scenic route’ via Richmond (where it used to start having run empties from Waterloo!), Ascot and Aldershot, which takes a whopping 111 minutes and includes a reversal enroute. It also runs non-stop between Egham and Ascot, skipping Virginia Water and Sunningdale, unlike any other services on the Reading line.
Esker-pades
23 Jul 2015
Beds, Bucks, or somewhere else
via Cobham: 59 mins
via Epsom: 71 mins
Guildford via Guildford? You might need to edit something slightly.
The service you talk about is effectively a Waterloo to Reading and an Ascot to Guildford service shoved together.
FS-2-11
13 Nov 2015
The section of track between Cowlairs North and East Junctions were once frequently used by the Fort William portion of the sleeper train. Since this has been re-routed via Glasgow Queen Street low level, the Summer Sundays Only Edinburgh Waverley - Oban still maintains a passenger service along that particular stretch of track, and also avoids having to go through a formal closure process.
I remember in Class 27 days being on an Edinburgh-Glasgow train which was full of returning football fans, and some signalling issue at Cowlairs required it to run via the triangle; a few intrepid locals decided to detrain via the slam doors and make their way home up the embankment while the driver was changing ends :o
Flange Squeal
17 Jul 2012
Yes, my apologies - I meant via Woking! It runs on one reporting number throughout so is surely still worthy of a mention, as well as the fact I don’t think any other trains skip Sunningdale (with only one weekday up train skipping Virginia Water).
A Challenge
24 Sep 2016
There are a few (I think it's four) trains out of Waterloo in the evening peek that are advertised as first stop Winchester, whereas off peak they are Woking then Winchester. Nothing of about missing out stops in the peaks, except one of these does have the stop at Woking, as pick up only. Why have both stops skipped and pick up only at the same station in the peak when on different trains running what is ultimatly the same service?
DavidGrain
29 Dec 2017
The 'pick up' only in the peak is the same reason that Virgin trains from Euston never show Watford Junction even if they stop there. It is to stop people for the 'inner' station crowding onto the train at the expense of the longer distance passengers who might be unable to board.
delticdave
14 Apr 2017
Cars from the Car Sheds. Or Empty Coaching Stock from Ilford Electric Multiple Unit Depot if you don’t speak Great Eastern!
Thanks, I thought Ilford was the most likely option, but I couldn't find any evidence in the Shenfield - Norwich Working Timetable.
As for speaking G.E. I'm from Walthamstow, used to live near Wood St. shed carriage sidings + when listening to an even older loco driver (Stratford) friend he always uses "cars" rather than ECS.
mr williams
19 Sep 2010
In the late 80s for a couple of years there was an early morning Cwmbran - Paddington HST which ran via Hereford. The evening return ran on to Newport (and strangely it called at Pontypool both ways as well as Abergavenny!).
Off-peak tickets were valid, making it was the earliest possible arrival at Paddington on a cheaper ticket, which is is possibly why it didn't start from Newport on the way up.
PHILIPE
14 Nov 2011
Caerphilly
It would have run ECS from the Marsh via the Maindee Curve. In any case, who would want to travel from Newport to London via Hereford and the Cotswolds.
Dai Corner
20 Jul 2015
Doesn't it still run, though as an ECS these days?
