Trivia: Which stations have numbered platforms which are unserved?
fairysdad
27 Dec 2010
London, Surrey... bit of a blur round here...
Do the bay platforms at Exeters St Davids and Central have anything? (Think they're platforms 2 at both, but could be wrong!)
(That said, I understand that Exeter Central's bay platform was used by SWR during recent industrial action, but it's not in regular use)
Kite159
27 Jan 2014
West of Andover
Is Platform 3 at Perth ever used for passenger services? Answered that myself by checking RTT - yes it is used for a few early/late services.
Although they might be booked to use platform 3 doesn't mean the train will use platform 3 (and because Perth is "old school" signalling it won't update on RTT.
Exeter Central P1 sees use on Sundays with some Exmouth departures, there was one Okehampton service which used P2 at St Davids during the summer. I think there might be a XC service which uses P2 at St Davids?
83G/84D
28 Oct 2011
Cornwall
T
he cross country service that uses Platform 2 at Exeter St David's is the 1005 Manchester Piccadilly - Exeter St David's and 1555 Exeter St David's to Manchester Piccadilly (weekdays only).
Red Onion
4 Apr 2012
Aberdeen
Aberdeen 1 & 2 are only used for ECS moves, and 7S is only used as a passing loop these days.
1 & 2 at Aberdeen aren’t numbered. You’re right about 7S though, can’t recall the last time I saw a service using it as a stop.
krus_aragon
10 Jun 2009
North Wales
Temple Meads platform 14. Yes, I know it's cheating as 'platform 14' is the name given to some office space in the old terminus building so it's not an actual platform but is called a platform. :)
By that token, Platform 5 (the bus stop) at Llandudno Junction is in the running too.
roadierway77
23 Jun 2019
Edinburgh
I'm surprised nobody's said Teesside Airport platform 2 yet. IBM platform 1 also counts.
If we're going for light rail, then I don't believe Mudchute platform 3 on the DLR sees any scheduled services, though I know it is used for reversing.
Are platforms 5 and 6 at Moorgate used any more?
31 Aug 2019
IW
Hooton station platform 1.
It sees some services now and again.
The parliamentary trains used to use P1 but regular bookings that actually run is practically zero
14 Apr 2014
I was thinking of Teesside Airport but didn’t know which platform was out of use.
Newhaven Marine platform 3? (Though I don’t know if it’s officially still numbered)
Ianigsy
12 May 2015
Birkenhead North Platform 1 (the far side of the island) is only booked to be used by ECS moves from the depot. That said, I've known it used for set swaps and also for special events in New Brighton- a six car set only just fits and at the start of the year one end was blocked off following the clearance work for the new units.
Sprinter107
26 Mar 2019
Ditto Northfield! (and, until very recently, Barnt Green for 1 & 2)
Platforms 1 & 2 at Barnt Green have never been out of use. Before the Cross City trains started calling, platform 2 had 2 morning trains towards Worcester call and platform 1 had 2 afternoon trains from Hereford call.
lewisf
21 Feb 2009
Kingston/Surbiton
Platforms 2 & 3 at New Malden, the fast line platforms. They’re numbered and have PIS screens, but also a rough gravel surface and uneven cable trunking.
dgl
5 Oct 2014
Yeovil Pen Mill platform 2 is not used by passengers, but uses the same track as platform 1, so whilst trains to Bristol do technically stop there you can't alight onto the platform from the train.
AndyCK
25 Apr 2019
No, I don’t think so.
It is used for the SuO Darlington services.
Incidentally, does anyone know why RTT gets the platform numbers wrong at Hartlepool? All the through trains show 1 till they are there when it shows a red 2. The terminating trains show 2.
https://www.realtimetrains.co.uk/se...9/10/20/0200-0159?stp=WVSC&show=all&order=wtt
Apologies, I may have the platform numbers wrong - I was referring to the old platform originally used for southbound services that has had the footbridge removed, not the bay platform.
LowLevel
26 Oct 2013
Platforms 2 & 7 at Skegness. (5 & 6 are not used much either!)
Platform 2 is available for emergency use but has no booked traffic.
Platform 3 is available but has some infrastructure issues so after a number of years of being the preferred platform it's generally not used.
Platform 4 is the regular departure platform.
Platform 5 is used in the summer when two trains occupy the station - it was reinstated after a few years out of use a couple of years ago.
Platforms 6 and 7 are formally disused having been removed from the network, 6 is missing it's signal arms and both have the signal lamps disconnected. They don't have any TPWS equipment either.
6026KingJohn
8 May 2019
Thank you for that. It has been a few months since I have been and I always seemed to be on 3 or 4 (I think once on 5)
83G/84D
28 Oct 2011
Cornwall
The cross country service that uses Platform 2 at Exeter St David's is the 1005 Manchester Piccadilly - Exeter St David's and 1555 Exeter St David's to Manchester Piccadilly (weekdays only).
Adding to this only a 4 car Voyager will fit in Platform 2. This week the service was a 5 car and ran into Platform 4 then ran empty to Dawlish Warren and back into Platform 5 at Exeter St David's for the return working.
