Two trains on single track
What would be the best type of signalling for a single line with reasonably spaced loops along the way - especially for a route such as Highland Main Line?
On another note, Some single lines such as the Lea Valley 3rd track from Lea Bridge to Meridian Water are almost like a long siding, where I am assuming that modern interlocking prevents another train being routed onto it until the occupying train has exited. And I'm assuming special procedures are in place if another train has to enter the section to rescue it. Would I be right in thinking that Watford to St Albans, Witham to Braintree and Marks Tey to Sudbury are similar examples?
The signalling would depend on the traffic, but single lines with loops usually don't have trains following closely enough for there to be more than one train between a loop and the next loop. Otherwise a train going the other way would have to hang around in the loop until both trains have passed. So the best arrangement with conventional signalling is probably pretty much what it has now - which I think is a distant on the approach to each loop then a signal protecting the loop entry and another protecting both the loop exit and the section to the next loop.
The examples you mention will be "one engine in steam" sections I posted about upthread, so the signal controlling entry to the section will not clear unless the section is proved not occupied all the way to the buffer stops. In axle counter areas one axle counter will do that, counting the wheels as it goes in and again as it comes out. In track circuit areas the usual arrangement is a series of track circuits near the entry, which have to be occupied and cleared in sequence to prove the train has left and it isn't just a track circuit failure.
Tomnick
10 Jun 2005
Can/Do you get Permissive working in AB areas ?
Yes.
Shrewsbury and Stockport are probably the best remaining examples – permissive platforms in the block section between two boxes.
Trying to think of a through station with permissive platforms that falls wholly within "station limits" (in the signalling sense) of one box working AB – any offers? The principle there is similar to permissive working on a TCB line.
Skegness is the best example of such a terminus that I can think of. You even get signalled into an occupied platform from the (semaphore) inner home signal using the main arm – there is no subsidiary signal. You don't get any route indication either, with six possible routes (although I think two of those are now formally out of use).
Finally, we have "no block" lines, adjacent to AB running lines between two boxes, which were covered extensively recently if I'm not mistaken?
Deepgreen
12 Jun 2013
Betchworth, Surrey
Unless I’m missing something - and I’m not a signaller, so I might be(!) - the diagram just shows two trains being separated by signalling section, which is the same thing that happens routinely on all TCB lines?
Two trains in one signalling section, rather than one single line section, is the big no no (other than under permissive working, assistance etc.) AIUI under TCB single line sections have a direction of flow device that interlocks signals to allow working in each direction, but other than that it’s operation as usual.
The tunnels on the Hastings Line are a good example of this “in the wild”, as is the line from Crystal Palace to Beckenham Junction.
Exactly.
To get back to the OP - perhaps the simple answer is that, with any conventional signalling system under normal conditions, it's one train per signal with no maximum limit. Now, obviously, in reality there will usually be a small number of signals/sections before the next double track/passing loop, and the continuous passing of consecutive trains in the same direction wouldn't happen for long. It comes down to the difference between a signal section and a singe line section (which may be divided into any number of signal sections in theory).
ComUtoR
13 Dec 2013
No, emergency permissive is TCB only isn't it?
Err.... No idea. I would think the principle is the same. Pass the signal at Danger, drop into the platform, hero landing, pop the doors and then Robert's your Brother's Uncle. I don't think the rulebook makes the distinction but thinking about it, I don't see any real reason why not.
Annetts key
13 Feb 2021
West is best
Modern track circuit block (or using axle counters for train detection) systems can divide any line, be it a single line, or multiple running lines that are provided with signalling for both directions (bi-directional / reversible) with multiple signal block sections. So, the answer to the op's original question is yes.
As others have said, it was possible with some earlier signalling systems as well. But was not very common, as it was not needed.
I'm jumping in to ask something a bit different, but more or less consistent with the thread title. With conventional semaphore signalling, absolute block (or permissive block for slow freight trains) was normal for two-track lines but not for single-track, hence the need for token/tablet/staff. The West Highlind line now has RETB, which is a modern equivalent. But trains on modern bi-directional tracks are controlled by the same systems as on unidirectional tracks. Why do those lines not need anything additional?
For unidirectional lines, there is no signalled route (except maybe for shunting purposes, and hence a limit of shunt signal) for a train to enter in the wrong direction. Hence the system does not need directional interlocking and direction controls.
For single lines, bi-directional or reversibly signalled lines, the interlocking must prevent any collision including a head on. All modern interlocking systems include this. But for practical reasons, it is also wise to try to prevent two trains getting into a Mexican standoff. Hence often a direction control (also sometimes called a 'slot' or 'acceptance') is included so that signallers (if split across different control areas) have to agree on which direction the line will be used for. Indicators for this are often provided and/or direction arrows that show on the signallers panel/VDU.
Where the relevant length is all under the control of a single signaller, direction circuitry is still normally provided, but activated by the first signal routed on to the line. This normally automatically locks out the relevant junction signal at the other end. Modern systems have this indicated by direction arrows on the signallers panel/VDU. Note that some existing systems do not have this, hence a signaller or more likely an automatic route setting system may set up a Mexican standoff...
There are now many examples of bi-directional or reversibly signalled lines where there are multiple signal sections between the junctions.
The Puddock
10 Jan 2023
Frog
It’s TCB or ERTMS only. Described in clause 3.4 in modules TS2 and TS10 respectively. Module TW1 contains the balancing instruction for drivers:
(above image shows a screenshot of module TW1 clause 20.6)
Tim_UK
9 Jan 2019
Here’s a map where it looks like what you describe is possible.
between Stocksmoor and Huddersfield.
somebody could maybe confirm if a second train can leave Stocksmoor to Huddersfield, once the first one has cleared Lockwood.
From
Lucy1501
9 Nov 2021
Cumbria
To the best of my knowledge:
In terms of terminus stations I'm aware that the following are permissively worked on AB lines:
  • All Holyhead platforms
  • All Llandudno platforms
  • All Penzance platforms
  • All Scarborough platforms (technically Seamer works AB to Weaverthorpe)
  • All Saltburn platforms
  • The bay at Whitehaven Bransty
  • The bay at St Erth
  • The bay at Whitby (though NST-R)
  • The bay at Barrow-in-Furness
  • The bay at Llandudno Junction
  • The bay at Bridlington.
And for through platforms:
  • All lines at Llandudno Junction
  • All lines at Worcester Shrub Hill (including from one of the famous banjo signals)
  • All lines at Harrogate
  • All through lines at Stirling (albeit two are also under the juristiction of Stirling North)
  • The two through lines at Barrow-in-Furness
  • The through platform at Whitehaven Bransty
  • The platform lines at Bangor
  • Some of the lines at Hereford
  • Potentially one of the through lines at Bridlington but I'm not entirely sure.
Llandudno
25 Dec 2014
Not really the same thing, as these are always used in the same direction so just like one track of a double track really.
But Wirral Line trains can exit the loop and terminate in the emergency platform at James Street?
Sheridan
11 Jan 2012
The sectional appendix shows Llandudno Junction as being TCB these days.
Railsigns
15 Feb 2010
It seems like quite a few of the stations listed are in TCB territory, even though the controlling signal box may work AB to the next box.
noddingdonkey
2 Nov 2012
Presumably there are exceptions to all this for situations where trains couple up or assisting a failed train?
Doesn't change the fact the loop itself is uni-directional.
For coupling up there is normally a subsidiary aspect indicating to the driver that they can proceed but must stop short of any obstruction, in this case the train they are coupling to. In semaphore areas this is typically a small arm or disc, and in colour light areas it is two small white lights at an angle, in both cases underneath a main signal that remains at danger.
The driver of a train assisting a failed train, somewhere other than where trains normally couple up, will be authorised to pass a signal at danger, and similarly proceed with caution.
12LDA28C
14 Oct 2022
The back of beyond
I have to say that, as a former signalman, every time I see the thread title I give a little start of horror. It is the signalman’s worst nightmare.
Why? It's perfectly normal. I can think of at least one location on the network where a long single line section of around 7 miles was split in half by the installation of a new signal in each direction around halfway along, effectively splitting the section in two which instantly doubled the capacity of the line (for trains travelling in the same direction).
Lucy1501
9 Nov 2021
Cumbria
Llandudno Junction works TCB to Wales ROC Rhyl Workstation, ETB to Llanrwst, and AB to Deganwy and Penmaenmawr. It has three home signals and three section signals, and through routes are possible between them, so technically speaking the platforms could be said to be inside station limits as Tomnick was asking for.
Bristol
ERTMS L2/3, from a purely operational POV. There's various talks about making RETB smoother though with things like returning tokens on the move and 'collapsible' tokens, not sure how far they got.
Presumably this is dealt in a similar way to how fully-signalled Bi-Di is controlled as well.
I wouldn't have thought the procedures would need to be particularly different from any other procedure to enter an occupied signal section to rescue a failed train. Signaller talks past signal at Danger, driver proceeds at caution etc.
Oxfordblues
22 Dec 2013
Fifty years ago in 1974 I was travelling on SNCF's couchette/sleeping-car Train 400 from Calais Maritime to Ventimiglia/Vintimille. After a crew-change stop in the north of Paris we joined the Grande Ceinture peripheral railway to circumnavigate the banlieues anti-clockwise and access Gare de Lyon from the south where we would reverse, add the Paris portion and change engine.
Peering out from my compartment in the dark on the Grande Ceinture I was astonished to see that we were closely following the rear flashing lights of another train just 200 metres ahead. The speed of both trains was no more than 30 km/h, so plenty of time to react if the first train suddenly stopped. Very much a case of "permissive working" and a flexible approach in increasing line capacity. But Heaven knows how they'd manage in fog and falling-snow!
Bristol
I think the french signalling system is permissive by default (open to correction and all the specific exemptions of course), and their operating rulebook presumably covers situations of reduced visibility.
Tester
5 Jul 2020
Watford
Surely you went clockwise!
Crossover
4 Jun 2009
The line between Princes Risborough and Aylesbury is a good example of this, with the line divided into sections to allow "flighting" of trains in the same direction. In this case I believe it may be related to getting the trains through in the peaks
cool110
12 Dec 2014
Preston
Every signal has a plate showing if it's permissive or not (F or Nf). Same applies to TVM block markers, with the ones over here on CTRL translated to P and N.
12LDA28C
14 Oct 2022
The back of beyond
Not related to getting trains through in the peaks but more allowing an increase in line capacity due to the amount of freight that uses the single line which used to cause many delays to Chiltern trains when there was only one long section.
muz379
23 Jan 2014
I think it is more that it alludes to two trains in a single section , which outside of occassions permitted in the rulebook is an operating irregularity that is taken quite seriously .
duffield
31 Jul 2013
East Midlands
I travelled this line for the first time a few days ago, and saw that the HS2 bridge works appeared to form part of a recent provision for a passing loop between Aylesbury and Little Kimble, although as far as I can find out there are no current plans to actually build this loop (maybe someone has some better info on this?).
