Understanding Trust Line-Ups
TicketMan
20 Nov 2005
Every now and then, both here and elsewhere, someone posts a timetable from Trust, giving a detailed listing of freight and or passenger workings for that particular location. However, unless you know what your looking at, it's just a load of codes...
So here I will attempt to explain it, using the following example taken from the line-up at Barnetby.
Code:
PASS  17:18 6H59 IMM NCBP1 16:55 MILFORDWS 19:18 WTT SX    121205 090606
17:25 17:26 1B82 MANINTAPT 14:57 CLEETHPES 17:55 WTT SX    270306 090606
The first two columns are the arrival and departure times for the location in question (in this case Barnetby). If the first column says PASS, then the service is not scheduled to stop at this location.
Next comes the four digit headcode - 6H59 (an EWS freight service) will pass straight through Barnetby, whilst 1B82 is scheduled to stop.
The next column is the origin of the service, together with the time it is scheduled to start it's journey - the lower example is a service that should have departed Manchester Airport at 14.57.
Then comes the train's destination, and arrival time, in the same format.
The next column indicates whether it is a timetabled service, a one off 'special', a temporary variation or whatever - WTT indicates that the service is a regular timetabled train, STP is used for specials, VAR for variations (i.e. diversions).
The next columns shows what days the train runs - MO is Monday only, SX is Saturdays Excepted (Mon-Fri), EWD is Every Week Day (Mon-Sat) etc.
The final two columns show what dates the timetable runs from - in the above example, 6H59 is scheduled to run Mon-Fri from 12/12/05 to 09/06/06
Easy isn't it?
TM
TicketMan
20 Nov 2005
Every reporting location (i.e. station, loop, junction etc) has a 9 digit 'STANME' code - Most of them are obvious with a bit of thought. Unfortunately some just appear to be random letters. BMWT&RSMD, for example is Bournemouth Traction & Rolling Stock Maintenance Depot...
If, after looking at it, you can't work out a location code, feel free to drop me a PM, or email ctticketman@yahoo.co.uk (Sorry I can't always answer right away)
TM
TicketMan
20 Nov 2005
Actually that doesn't show STANME (9 digit codes) - it shows TIPLOC (which are even shorter versions) and STANOX (5 digit numbers).
For reference, STANOXs are the codes shown next to the location names in the lists of timings which I post - see this example:
Code:
[B]52219[/B] [I]CHANLSEJN[/I] 14:35 14:44
[B]86901[/B] [I]BROCKNHST[/I] 18:00 18:10
[B]86921[/B] [I]BOURNEMTH[/I] 18:34 18:34
Bold - STANOX
Italic - STANME
The Snap
10 Jun 2005
Code:
   PASS  17:08 2F81 HUDDFIELD 16:32 WIGAN WAL 18:04 WTT SO
   PASS  17:35 2E72 LVPOOL LS 16:18 HUDDFIELD 18:09 WTT SO
   PASS  17:46 2F37 STALYBDGE 17:41 LVPOOL LS 19:05 WTT SO
   PASS  17:59 2J26 LVPOOL LS 16:48 STALYBDGE 18:05 WTT SO
   PASS  18:08 2M79 HUDDFIELD 17:32 MANCR VIC 18:18 WTT EWD
   PASS  18:35 2E76 MANCR VIC 18:27 HUDDFIELD 19:09 WTT EWD
   PASS  18:46 2F23 STALYBDGE 18:41 LVPOOL LS 20:03 WTT SO
   PASS  18:52 1Z62 NCASTLCEN 16:35 GLOUCESTR 23:00 STP SO
   PASS  19:10 2M83 HUDDFIELD 18:34 MANCR VIC 19:23 WTT SO
   PASS  19:30 6E72 STALY BDG 18:55 IMMHM REC 22:40 WTT SO
   PASS  19:35 2E78 MANCR VIC 19:27 HUDDFIELD 20:09 WTT EWD
   PASS  20:09 2M85 HUDDFIELD 19:33 MANCR VIC 20:21 WTT SO
   PASS  20:35 2E80 MANCR VIC 20:27 HUDDFIELD 21:09 WTT SO
   PASS  20:42 6M28 MOSSUPREC 09:52 BASFDHALL 22:22 CAN SO
   PASS  20:57 1Z51 CARLISLE  16:16 LVPOOL LS 22:10 STP SO
Just received these from TM - can someone explain what the CAN pit means in the second to last timing?
Also, can someone please tell me which of those services are freight?
Craig
15 Jun 2005
Newcastle
6E72 and 6M28. 1Z62 and 1Z51 are railtours, 62 is the Cotswold HST and 51 is 37417+406.
ikar
20 Oct 2005
Europe (Rijeka, Croatia)
I assume CAN would be 'runs when required' but I ask TM to confirm.
-Class 0 is a light loco
-Class 1 is a express passenger or postal or a train going to clear the line (1Z99)
-Class 2 is a regular passenger or a train not going to clear the line (2Z99)
-Class 3 is a Parcles train or a ECS train forming a peak service (London area)
-Class 4 is a 75mph freight
-Class 5 is a ECS
-Class 6 is a 60mph freight
-Class 7 is a 45mph freight
-Class 8 is a 35mph freight
-Class 9 is a International train (Eurostar)
The Snap
10 Jun 2005
Rioght cheers, I saw the HST - pics coming soon! I will try yo phot the 37s as they pass from my house too!
EDIT: Just seen your pics of it Craig, bloody shame it will be going dark at that time! Should I go out and phot it?
rmt
28 May 2006
Doncaster, South Yorkshire.
Rich said:
Code:
While it may show the freight, what you have to remember is that these are the Booked paths. It doesn't mean that there will be a train running in that slot, as it may have been cancelled, or may not be running yet.
