Thanks, Much Appreciated!That’s 221114 on real headcode 5L50.
It was 158839.
66434Please can someone assist with the below. Thanks in advance
4L48 13:51 Daventry-Ripple Lane/Purfleet
Thanks Rhys66434
not all the posts loaded in sorryHi dose anyone know which unit is working this today?
Cheers
37423 + 37407 + 37402 0Z89Realtime Trains - 017Z 1810 York Thrall Europa to Toton T.M.D.
Realtime Trains provides live realtime running information for the Great British railway network using open data.www.realtimetrains.co.uk
Any idea?
Many thanks. What’s 37419 likely to do next?37423 + 37407 + 37402 0Z89
Only 3 allocated on Railcam although all 5 37's were lined up together all with wheel flats so it may go with themMany thanks. What’s 37419 likely to do next?
Reported on WNXX that HNRC 20311 & 20314 worked todays 1545 0Z21 Worksop Up Rec to York Thrall Europa to take up RHTT duties
What locos are on this please?
Realtime Trains - 076A 0935 Wembley Lmd to Crewe Gresty Bridge (Drs)
Many thanks.![]()
That’s an autumn MPV circuit (3S82). Would normally run out of Totton Yard but starting from Eastleigh Works due to engineering work between Southampton and Redbridge.Does anyone know what is operating the 398B Eastleigh Arlington (Zg) to Eastleigh Arlington (Zg) today?
Thanks!
Realtime Trains - 398B 0835 Eastleigh Arlington (Zg) to Eastleigh Arlington (Zg)
If you still need them...Good morning
Can anyone tell me the allocations for 321314 and 321306 today please?
Thank you
Kemal Ali
It is 66592/591/502/563/525.Can anyone please provide today's numbers for 0S68, Leeds to Millerhill convoy ?
Many thanks as always.
Realtime Trains - 075A 1118 Leeds Balm Rd Loco (Fhh) to Millerhill S.S.
That’s 70007 and 70006.Any allocations for 0K98 Earles to Basford Hall yet? Thanks in advance.
Realtime Trains - 343C 1437 York Thrall Europa to Gilberdyke
Realtime Trains - 014B 1255 South Bank Tees Dock (Fhh) to Leeds Balm Rd Loco (Fhh)
Any ideas?
Thanks, glad I gave it a miss then with just the two locos on it today.That’s 70007 and 70006.
Thanks a lot014B is 70003 on 0G34.
343C is 66108 and 66122 on 3J16.
Looks like someone mistyped it when they input it!
Belated thanks to ls2270 for the 0S68 gen.
May I respectfully point out that the lead engine in the convoy was 952, not 592 as quoted. I observed the convoy passing through Newcastle and you can also clearly see 952 passing York Railcam early this afternoon.
Sadly, one of those occasions when TOPS is not quite right, as it was showing 952 at Hoo Junction at 0830 this morning !!
Anyway, thanks again for the gen.
Can anyone confirm 37175 as being on 3Z37 1017 Derby RTC to Inverness Millburn please? Also, any idea of whether the 37 is leading?
Thanks
Also, could someone clear up 1Q20 1000 Derby RTC to Heaton please? Railcam data is reporting 43013/14 and 67023/27 so I'm guessing its one or the other
Thanks
