Wigan Wanderer
I would be grateful to know if either of 777035 or 047 are out today please.
6N61 showing 60095 on RTT.314 went up to Jarrow last night from Doncaster then did 6H44 to Drax where it is now so presumably will work 6N61 back to Jarrow.
657 is on 6M68 Hither Green to St Pancras Churchyard and 4O62 back
658 is at Toton North Yard
Yep, still at Drax 314 or was a while ago.6N61 showing 60095 on RTT.
91 111 is in theory working the 18.45 with set NL03; the down working that forms this is currently 17 late at Grantham - so it is at least on the way north to Leeds.Would be grateful to know of any Class 91 workings from Leeds to Kings Cross today. The 1645 / 1A41 I was scheduled to take is cancelled and in general the timetable is stuffed so the 225 group list not useful
66656Hello.
Could anyone please let me know what has worked/is working today’s 6Z55 / 6Z53 Margam-Portbury and return steel working?
Thank you.
19.00 from York is showing 801 219.I have about 10 minutes to decide to risk that before I backtrack to York and take 1900 to KGX... toughie.
Do you have an option to use an alternative train as far as Doncaster and then see if the 18.45 produces? 800 208 has left Harrogate on time which forms the 18.15 from Leeds.
Understood - I'm going offline now, but RTT shows 91 111 to be 16 late at Newark and OTT isn't showing any blocks so hopefully the disruption has been cleared.No. I'm at Leeds currently with an advance on the 1645. Which I took specifically (on a journey from Durham) to ride on the Mk4s
I've decided I will stay at Leeds for the moment and see what happens.
66656 according to TOPS:Hello.
Thank you.
66656 WBHT MARGAM TC 796Z551517 1 * PORTBY AT N 6Z53
Fingers crossed for you.
Thank you. Return working was cancelled anyway, the inbound took four hours to get down the gorge for some reason (I suspect the storm brought a few trees down, heavily wooded along that route, first working down the line since).66656 according to TOPS:
MARK
67029 + HD05 12224 12326 10321 11320 12477 82200Can anybody advise of what is working 1W13 0646 Cardiff Central to Manchester Piccadilly please?
RTT has the image of a 67/Mk4 set but no sticky digits showing![]()
Thanks a lot, Rhys!67029 + HD05 12224 12326 10321 11320 12477 82200
Yes, 67010 + HD06 12222 12323 10330 11321 12461 82227Thanks a lot, Rhys!
Would you also be kind enough to confirm that RTT is correct that 67010 is working the diagram that begins with 1V31 and finishes with 1W63 1653 ex Cardiff please?
Thanks for the info mate and I will absolutely be monitoring RTT for set swaps - I've had too much good luck with them so far so I am due something changing thatYes, 67010 + HD06 12222 12323 10330 11321 12461 82227
Others out today are:
67017 + HD07 12210 12316 10301 11322 12452 82230
1W11 04:21 Cardiff Central to Manchester Piccadilly
1V37 08:30 Manchester Piccadilly to Cardiff Central
1W59 12:53 Cardiff Central to Manchester Piccadilly
1V50 16:30 Manchester Piccadilly to Cardiff Central
67013 + HD04 12211 12310 10318 11319 12434 82201
1V33 06:27 Manchester Picadilly to Cardiff Central
1W61 14:50 Cardiff Central to Manchester Piccadilly
1V62 18:30 Manchester Piccadilly to Cardiff Central
67020 + HD03 12217 12324 10312 11325 12446 82216
1V91 05:27 Holyhead to Cardiff Central
1W57 10:53 Cardiff Central to Manchester Piccadilly
1V46 14:30 Manchester Piccadilly to Cardiff Central
1W65 18:55 Cardiff Central to Manchester Piccadilly
1K73 22:32 Manchester Piccadilly to Crewe
Usual caveats apply though, they might get swapped out later on in the day![]()
91127 failed this morning at Knebworth on 1A09, so thunderbird 47815 rescued itWas 5G09 Welwyn to Neville Hill an 801/47 drag?
67013 on 1W13Can anybody kindly assist with which loco is working the TfW diagram that starts with 1W13 Cardiff to Manchester and finishes with 1W96 1722 Cardiff to Holyhead please?
Perfect, thanks a lot67013 on 1W13
For completeness 67013 is with set HD04 12211 12310 10318 11319 12434 82201Perfect, thanks a lot![]()
Thanks a lot for this Rhys. I don't want to speak too soon as I'm only at the halfway point of my trip, but so far I have timed this well for a full return of the 67sFor completeness 67013 is with set HD04 12211 12310 10318 11319 12434 82201
And because I'm feeling nice here are the rest out today:
1V31 05:13 Crewe to Cardiff Central
1W55 08:53 Cardiff Central to Manchester Piccadilly
1V42 12:30 Manchester Piccadilly to Cardiff Central
1W63 16:53 Cardiff Central to Manchester Piccadilly
