Oh, in that case you're probably right. Hopefully we'll be able to tell in the coming days.Hospitalisations is new entrants to hospitals, not the number of people in hospitals.
I went and looked it up, number of patients in hospital is falling about the rate as last time.Oh, in that case you're probably right. Hopefully we'll be able to tell in the coming days.
But not necessarily as encouraging as all that, given that part of the problem with Covid is that it is overburdening hospitals. I'd be a lot more comfortable given the focus on high priority groups if hospitalisations were falling faster than deathsOverall UK deaths seem to be falling faster than the peak, but hospitalisations seem to be falling slower.
Which I think is some evidence that the vaccinations are starting to have some impact.
Indeed, I do feel like it is a mistake to not have a more equal focus amongst groups 1-9, as groups 5-9 are those who cause the most strain on ICU, and hence a requirement for longer restrictions.But not necessarily as encouraging as all that, given that part of the problem with Covid is that it is overburdening hospitals. I'd be a lot more comfortable given the focus on high priority groups if hospitalisations were falling faster than deaths
Jonathan van Tam squashed this today in the press conference - again said that the SA vaccine has no transmissibility advantage over the Kent variant and zero evidence that it will become dominantIt actually turned out that Vallance hadn't been in one of the briefings and had missed the discussion on some South Africa work (done by close contacts of PHE experts) that was about to be published several days later. With the additional E484K mutation it is fundamentally harder for specific antibodies to stick to that bit of the spike, the practical impact of which is "patients" having high viral loads for longer giving the new strain a transmission advantage. Hence why Hancock is still very worried byt he SA strain.
It is still encouraging because it shows that the vaccines do work as advertised.But not necessarily as encouraging as all that, given that part of the problem with Covid is that it is overburdening hospitals. I'd be a lot more comfortable given the focus on high priority groups if hospitalisations were falling faster than deaths
It doesn't a the moment, but if the AZ vaccine only reduces the effectiveness of one variant, a transmissibility advantage will appear over time as vaccination progresses.Jonathan van Tam squashed this today in the press conference - again said that the SA vaccine has no transmissibility advantage over the Kent variant and zero evidence that it will become dominant
Is it? Given the lags between infection, hospitalisation and death, that profile suggests to me that the fall is if anything due to lockdown, not vaccination. Given the timing of the vaccination campaign, I'd be expecting to see rising immunity beginning to affect case numbers rather than hospitalisations or deaths at this stage. Deaths, on the other hand, suggest the surge over Christmas beginning to work it's way through the system; what concerns me from your post is that we're not seeing the same degree of impact on hospitalisations where I'd have expected a combination of lockdown and vaccination to be leading the death rate down.It is still encouraging because it shows that the vaccines do work as advertised.
But the average age of cases, hospitalisations and deaths are all different. (Hospitalisation median is ~63, death median is 80+)
Death rates should fall first, then hospitalisation, then case numbers.
The fact that hospital admissions are falling slower than last time but deaths are falling faster indicates a decoupling of hospitalisation and deaths, which is exactly what'd you expect given our oldest-first strategy.
I think that's right - don't forget that a lot of deaths occur outside hospital, especially amongst the very old who would often rather die at home. I saw some figures for that the other day but I can't find them just now.But the average age of cases, hospitalisations and deaths are all different. (Hospitalisation median is ~63, death median is 80+)
I think that was kind of what van Tam was getting at...by the time the Kent variant is suppressed by the vaccine and the SA variant is a significantly higher proportion, we will already be rolling out the boosters.It is still encouraging because it shows that the vaccines do work as advertised.
Whether it will be significant early enough to matter is another question.
Yes I noted that slip out and was slightly concerned.Van Tam already stated that people should not expect inter-household mixing this summer.
To me not being able to see friends and family indoors from June onwards crosses a line. If by then, at a minimum gatherings of six indoors are not permitted, then I will seriously consider temporarily locating to a country with fewer restrictions.So what I was saying on another thread (and was shut down quite quickly about) regarding not seeing family for a very long time (likely not until next Christmas) is rather more likely than some on here would like to think! Yes he's only an advisor, but this tells us that keeping families apart for even longer is certainly something the government are looking at doing.
We need to stop this Britishness at some point because it's going to be our downfall.To me not being able to see friends and family indoors from June onwards crosses a line. If by then, at a minimum gatherings of six indoors are not permitted, then I will seriously consider temporarily locating to a country with fewer restrictions.
Perhaps we should wait to see what effect the vaccines do have, and then consider how the risks look, rather than impose arbitrary timelines on what we do or do not consider acceptable. That's not about what you or I want (I have my own list of events and encounters in mind), but about raw, hard, numbers. And, unlike some, I don't assume that those implementing measures I personally dislike are doing so in bad faith, or with some kind of desire to control us - but in a serious attempt to manage the risks and consequences of a pandemic.Van Tam is only a government advisor, and the government doesn't have to do as he says.
Also do you remember just before Christmas when Johnson and his cabinet and maybe some government advisors like Van Tam were saying "Unfortunately big get togethers won't be possible this Christmas. Have your big get togethers at Easter instead."?. Well we're only several weeks away from Easter now! And it will be ridiculous if they now say something like "Unfortunately big get togethers this Easter(that you should have had last Christmas) will not be possible. Have your big get togethers at Christmas instead."!!!
They can't keep kicking the can down with silly excuses. Though I'm not expecting life to be back to normal by Easter now. If however life is not back to normal by mid summer at the latest and there's still these silly laws/rules of social distancing, face mask wearing, "the rule of six", etc, then this will just be beyond ridiculous and insanity, and will be completely unacceptable. By early July it would then be 7 months since the vaccinations started and a very large chunk of the UK population would have been vaccinated, and those in hospital and those dieing of Coronavirus by then would be absolutely miniscule. So there is no reason atall why by then the country should not be back to normal again.
Sure.Perhaps we should wait to see what effect the vaccines do have, and then consider how the risks look, rather than impose arbitrary timelines on what we do or do not consider acceptable. That's not about what you or I want (I have my own list of events and encounters in mind), but about raw, hard, numbers. And, unlike some, I don't assume that those implementing measures I personally dislike are doing so in bad faith, or with some kind of desire to control us - but in a serious attempt to manage the risks and consequences of a pandemic.
Any serious cost benefit analysis would find that restrictions on healthy people cause disproportionate harm. Even if the the vaccines not work as well as hoped, it's time to abandon these experimental measures and return to conventional pandemic protocols.Perhaps we should wait to see what effect the vaccines do have, and then consider how the risks look, rather than impose arbitrary timelines on what we do or do not consider acceptable. That's not about what you or I want (I have my own list of events and encounters in mind), but about raw, hard, numbers. And, unlike some, I don't assume that those implementing measures I personally dislike are doing so in bad faith, or with some kind of desire to control us - but in a serious attempt to manage the risks and consequences of a pandemic.
0.2%, from Ioannis et al.Sure.
If the vaccines work - excellent, we can go back to normal.
If the vaccines don't work - some people may wish to be careful and isolate, the rest of us can go back to normal.
"Distance indefinitely" is not a viable solution. The average IFR is around 1%. I've given up 2% of my life (more, if we assume that the mental health effects of lockdown have some level of permanence).
It's EV negative. In a few months I shall be doing as I please, I have enough funds to pay fines indefinitely. Not everyone is that fortunate hence the need for mass action.
Well while we are on with raw, hard numbers, how many jobs can we afford to lose, how much tax revenue (that is needed for services like the NHS) can we afford to miss out on, how much more money can we borrow to pay people not to work or go to school?Perhaps we should wait to see what effect the vaccines do have, and then consider how the risks look, rather than impose arbitrary timelines on what we do or do not consider acceptable. That's not about what you or I want (I have my own list of events and encounters in mind), but about raw, hard, numbers. And, unlike some, I don't assume that those implementing measures I personally dislike are doing so in bad faith, or with some kind of desire to control us - but in a serious attempt to manage the risks and consequences of a pandemic.
He can stuff it.Van Tam already stated that people should not expect inter-household mixing this summer.
Just to be clear are you proposing looking at Covid figures only, with no consideration for other factors?Perhaps we should wait to see what effect the vaccines do have, and then consider how the risks look, rather than impose arbitrary timelines on what we do or do not consider acceptable. That's not about what you or I want (I have my own list of events and encounters in mind), but about raw, hard, numbers. And, unlike some, I don't assume that those implementing measures I personally dislike are doing so in bad faith, or with some kind of desire to control us - but in a serious attempt to manage the risks and consequences of a pandemic.
Probably through inflation at some point, though that's arguably a topic for a whole new thread. The pro-lockdown brigade don't generally care about any long term effects. It's all about Covid for them with nothing else considered."How the hell are we going to pay for all this?"
