Voltage rating of cables in used in stations?
aspire_13
7 Apr 2021
Cardiff
Hello everyone, this is a bit of a weird question but I am wondering if someone knows what rated voltage cables does a train station uses?
pdeaves
14 Sep 2014
Gateway to the South West
For what use? 'Domestic' supplies (lights, heating, etc.) are standard 230V. Signalling cables passing through could be one of various voltages.
Even in stations, given the age of the UK railway system, there are likely to be oddities.
Don't some London Underground stations still have 600V supplies for escalators etc?
dosxuk
2 Jan 2011
How long is a piece of string?
The voltage rating of the cables will be based on what voltage they're intended to carry. I bet there's plenty of 1000V rated stuff and plenty of 50V rated stuff, along with loads in the middle, above and below. It's impossible to answer your question as posed.
Annetts key
13 Feb 2021
West is best
You do need to specify which cables you are asking about.
There are public address system cables, telephone and computer network cables, 230V cables, 400V three phase cables, (in some stations maybe 11kV distribution electrical supply cables), various signalling cables carriying various functions, from low voltage data link cables, to 650V signalling power distribution cables.
Also the voltages found in the cable may be considerably lower than the rated voltage of the cable...
plugwash
29 May 2015
Not really, at least not if railway practice is like everywhere else.
Most cables, at least for LV work, have a pair of voltage ratings, one for the maximum voltage between a conductor and ground and one for the maximum voltage between two conductors. Some cable types are available in variants with different voltage ratings.
However not all types of cable are available in all voltage ratings. In my experiance SWA is always 600V/1000V. T&E seems to be 300/500V. Even with cable types like flex where multiple voltage ratings are available, robustness concerns may drive the choice of a higher rated variant.
So the voltage ratings of cables often far exceeds the operating voltage of the circuits those cables are used for.
dosxuk
2 Jan 2011
The key word in my message was based. The OP made no mention of what sort of thing was being carried on the cables, 400V supplies will use different rated cables to Ethernet. 100V speaker systems will use different ones to CCTV systems. And so on.
Nowhere does that imply that the voltage carried on a cable is exactly the same as that cable is rated to.
Mcr Warrior
8 Jan 2009
Had to check the OP's previous posts on the forum, don't think they are looking to liberate "unwanted" trackside cabling during the middle of the night! :rolleyes:
