Karl
Never used that but class 50s were D400ers to us.
Yes I was going to mention the very same as a young Preston spotter when they were first introduced in the late 60's.
"Original" diesel numbering was actually in the steam loco series - 1xxxx was diesels and 2xxxx was electrics. It was given up as the first pilot scheme main line diesels came in but there were a lot of diesel shunters by then, some of which then were not repainted/renumbered for years afterwards. The regular "Class 08" at the goods depot at the east end of Bristol TM, still painted black, was something like 13137 well into the 1960s I recall.
I think you will probably smile when I say that for some of us the reverse is true - what do I know this "Class 29" as?
It was actually pretty random. The small shunters, of which a good proportion of the total were built quite early on and had these original numbers, were completely renumbered and the sequence changed. Some of the older larger shunters were never renumbered until withdrawal and ran right into the early 1970s as such.Many years ago someone told me the reason why the big locos (type 4) came first with numbers D1-D1999 then shunters, then the mid sized locos was a hangover from the steam numbering scheme. They simply replaced original 1 with D so if had a shunter numbered 12345 It became D2345 etc. The mainline diesels started at 10000, the diesel shunters at 12000, bigger shunters at 13000
The one part I have never understood is what happened to the low 2xxxx numbers, we know the new electric locos ended up 26xxx and 27xxx (years before the ac locos started with E prefix), but why 26xxx and not say 21xxx onwards (Southern railway had built 3 electric locos in 1940s which became 20001-3)
Most interesting thing I find is that The SR Electrics were class 70 (never carried) , however the classification was reused later for the current class 70's
Slightly off topic, but class 100 has always puzzled me. The DMU numbering is otherwise quite neat and explicable but no other MU numbering sequence started at x00. Did the just forget the Gloucest
Class 80 was allocated to the prototype AC loco converted from Gas Turbine prototype 18100.Most interesting thing I find is that The SR Electrics were class 70 (never carried) , however the classification was reused later for the current class 70's
Well the Class 80 mentioned above was withdrawn in 1968.I was wondering if we could work out when the list of classes was first created as that might help us work out which odd locos were still around to explain the odd number gaps?
I’d say the clues are: Firstly, the re-engining of Classes 21 and 30 was underway but not completed (hence a need for both 30 and 31). Secondly, some - but not all - of the various EE shunter designs were still in service, hence Classes 10, 11 and 12 but with some of the variants of the 08 having already gone, along with the GW and LNER ordered shunters? And thirdly (assuming DMUs we’re classified at the same time) the Derby and Metro Cammell lightweights didn’t get class numbers.
If we can date the list then we might be able to better explain the gaps, which as well as affecting the Type 3s also seem to affect the Type 1s (which seems even harder to explain)?
