Weather related disruption Leeds/York/Doncaster (27/07)
Iskra
11 Jun 2014
West Riding
I'm a bit surprised that the TOC's or National Rail (whoever organise these things) haven't put buses on he busiest routes. It says hat the scale of the accident is too big for buses but surely they can spare some from somewhere?
There might not be hundreds of buses sat around doing nothing ready to go on a Friday afternoon.
Loads of people complaining about this on the trains I’m on, but there is no magic wand for these situations.
johntea
29 Dec 2010
Arriva accepting Northern rail tickets for buses, which is useful in some affected areas at least.
noddingdonkey
2 Nov 2012
Metro have said that regular buses are being diverted away from the front of Leeds station to make way for RRBs
Being realistic there simply aren’t large fleets of buses or coaches sitting around complete with drivers, ready to spring into action. Sure there’s no school work at this time of year, however this is balanced by more annual leave.
No easy answer - it’s a case of unrealistic expectations.
ajdunlop
25 Jan 2009
At the very least every public bus service in the effected area should be accepting rail tickets. Not of use to everyone but would help for shorter journeys.
But then that would require not having a completely fragmented bus system.
18 Mar 2008
The York Rail Operations Centre (ROC) - the big new building next to platform 11 - has workstations that cover not only York itself but the ECML north and south, the Leeds line, Leeds station and fringes with other signal boxes on all routes out of Leeds and all of the Aire Valley lines to north of Skipton. This requires a whole load of repeating kit and safeguards to 'prove' within the signalling that points, signals and track circuits are working as expected. If the link between the detection on these items and the ROC goes down, then everything is designed to fail safe - signals to red and level crossings down for road users. It follows that if you want to manually and exceptionally override the signalling safeguards to allow a train to detrain in a platform, there are a very comprehensive set of procedures to go through to ensure that there are no conflicting movements authourised and every movement of a passenger train over facing points is made guaranteeing that these points are locked so they can't inadvertantly move under the wheels of a train, even potentially if some damaged signal component from the lighting strike allowed a stray current to the point motor. So each point has to be manually cranked to the desired position and then 'scotched and clipped' - i.e. mechnical devices applied to the point blades to physically guarantee no movement. This might be a pain and will take some time, but please don't have a go at the poor staff on the ground charged with these responsibilities. By their nature, these incidents are all unique and staff need the time and thinking space to operate safely without being hassled to hit a certain time deadline. Otherwise, to compound the already bad problems, you then have the potential for a derailment as well. This actually occurred on the District Line at Ealing Broadway not too long ago - derailment due to full route not being secured for an exceptional movement in a signalling outage.
The advice not to travel should be heeded - by now this incident will have created a national knock on in terms of late running and rolling stock out of position. By far the biggest challenge will be in deployment of train crew, who will all by now be stuck in the wrong places running out of duty hours. So it will not recover for the rest of today and any trains that do start running have the potential to be short formed. So don't travel today - which is the advice that has already been given. Even if it all came back now, many signalling areas run in Auto Route Setting - ARS - mode. For this to work, each train has to be correctly described with a headcode in the system. In times of high disruption, ARS will have to be switched off while the service recovers, which will put more work on the human signallers normally overseeing it and this in itself will cause further disruption.
In terms of the ROC going forward, it will be interesting to see how Network Rail provides greater resilience, disaster recovery and remote mirroring/duplication of critical systems.
Iskra
11 Jun 2014
West Riding
Exactly, ticket acceptance is in place on other routes and there are some buses in place so the TOC’s are doing what they can. Yes, it’s cosy and slower but at least you can move in the right direction and claim a full refund. Or travel tomorrow.
chrisdmadd
10 May 2010
ECML
Thankfully I’m off today as an operational member of staff on the ground I know it will be truly horrible working today.
However it is a bit pathetic that we can’t cope with bad weather on this network.
Look over Germany at any given time in the summer and you will be very likely to see a severe lightening storm.
If a building gets hit with lightening it can cope with it due to lightening conductors. Now if we are going forward and putting all of out regional signalling in one place, surely we have to make that place safe and secure!
I’m sure this won’t have just been a simple lightening strike on the ROC but if it is, this would be very embarrassing.
TUC
11 Nov 2010
Information is woefully lacking on both the Northern and National Rail sites. Both basically just refer to most services not being able to operate out of Leeds or York but, for example, make no reference to whether a limited form of some services are operating on unaffected sections of route. I also see from the posts above that a small number of services are now starting to operate. Again, no mention of these on the websites.
AM9
13 May 2014
St Albans
Bit knee-jerk? Only last year everyone was moaning about how we no longer get decent summers or snow in winter in this country!
Well the weather records say otherwise. A couple of decades ago the Met Office (and other similar authoritive bodies) abroad warned that weather patterns might tend to be more extreme as an effect of the onset of global warning. I think it was following the 1987 and 1991 gales across the south. (Other gales were available but it was questions arising from those two that spawned the comments). Since then, there have been several extreme weather events that in part support their warnings.
Still, as some say, concern about climate change (and actually doing something about it is definitely 'knee jerk') so we should all sit and wait until they are proven right or not.
p.s. "moaning about how we no longer get decent summers or snow in winter in this country!" is a pastime of the uninformed so hardly connected with any fundamental changes in our climate.
AM9
13 May 2014
St Albans
EMC compliance including lightning protection is not rocket science but it does need competence to achieve. To fail to embody sufficient measures in a critical asset such as a ROC isn't far short of criminal. Given the rise in electrical storm activity as Climate change takes grip, somebody has to answer for such an omission.
Carlisle
26 Aug 2012
Simple answer, - yes!
Slightly longer answer yes, - until the railway's (and the rest of the country's) infrastructure is adjusted to cope with the climate changes now beginning to show their teeth.
Id fully support funding on improved drainage and coastal defences such as Dawlish but is there an immediate necessity to spend many millions preparing for a heatwave that may not be repeated for another 20+ years, and isn’t the chance of being able to prevent damage from future electrical storms pretty limited anyway.
23 Feb 2006
LNER currently have 42 Coaches working to get passengers moving at the following stations: Darlington, York, Doncaster, Wakefield, Newcastle, Leeds.
I do find the 'this doesn't happen in other countries' argument so tedious. Each country will have their own problems and challenges. None are perfect. - Shall we build infrastructure in this country to withstand typhoons? earthquakes? No..because the odds of it happened are remote. Same as today.
gavin
25 Dec 2006
Singnalling has returned to parts of Leeds station so a limited number of trains are running in this area
York and Doncaster still seem to be having major issues
Whilst I don’t necessarily disagree with the general theme, it’s noticeable that your post hinges around things which *might* happen.
So far we’ve seen a string of hot days, mainly in the south-east, perhaps bordering on touching records but nothing earth shattering. It’s also worth noting that this most recent “heatwave” has mainly affected the south-east. I’ve just come back from a 2-week holiday in Wales and the weather wasn’t really much to write home about for summer - rained on a couple of days, a couple of good sunny days only one of which I would describe as “hot”, and the rest cloudy ranging from cool to warm. Storms are hardly unusual in summer, especially as August comes.
No doubt at some point in the next year or two there will be periods of rainfall resulting in some rivers flooding, and the environment agency being blamed for not doing enough to protect people who have chosen to live in flood-prone areas.
As I say, I don’t really know enough to say whether climate change is or isn’t likely - even experts aren’t really sure let alone able to agree - however I certainly wouldn’t be wanting to spend large amounts of money based on the recent weather - during which generally the transport system seems to have coped well, perhaps excepting Eurotunnel’s air conditioning issues which I think we can both agree is not really an indicator of systemic unpreparedness in the industry! The industry coped pretty well with the snow in March too as I recall.
What’s the odds next year the jet stream will be further south and we’ll see a summer of Atlantic weather systems - especially outside the south-east?!
cuccir
18 Nov 2009
LNER are terminating all southbound Scotland/Newcastle services at Darlington and all northbound Scotland/Newcastle services at Doncaster (among other cancellations). The coaches are doing the rest!
gavin
25 Dec 2006
LNER are going to try and run 1 service per hour between Kings Cross and Edinburgh from 2pm to 6pm
Calling points
Doncaster (pick up only)
York
Northallerton
Darlington
Durham
Newcastle
Alnmouth
Berwick
Edinburgh
Tio Terry
2 May 2014
Spain
That rather depends on the design of the installation at York (and other ROC's). If it follows the Networkrail design of old then, yes, there is quite a lot that can be done to minimise future damage and for a relatively low cost (what is today's cost likely to be in terms of delay attribution?)
Spartacus
25 Aug 2009
Someone else on here was talking about 3+hr delays travelling through Germany and an enforced overnight stay.
bengley
18 May 2008
York ROC doesn't control Leeds Station, that's still under York IECC.
(to clarify, the areas affected by the signalling problems are all under the control of York IECC)
beeza1
4 Oct 2012
When I half heard on the radio "Rail services in Yorkshire are affected by a lightning strike", I immediately thought "The RMT must be at it again".
Quite justified IMO in respect of keeping the guards on the train.
Moonshot
10 Nov 2013
Some of the responses on this thread are laughable, just what planet do people live on. The railway is not immune from significant weather events, just like the aviation industry and road. I note several homes have been struck by lightning as well in Yorkshire
bengley
18 May 2008
Nothing like a good bit of railway bashing!
SSp
26 Oct 2016
Pretty sure when that happened in multiple instances recently it was also blamed on climate change :rolleyes:
Nick66
19 Jan 2018
Anyone know if Super Off Peak tickets will be valid on trains planned to leave KGX before 18:00 if they are delayed and the train I wanted to take (the 18:18 or 18:30) is cancelled?
