Crossrail will be an all stations service from Reading to Langley, whereas the proposed western rail link service will only stop at Slough and possibly Maidenhead.
The estimated journey time set out in the official project, is given as approx. 26 mins.
I think your maths went wrong there?
The total of the times you've quoted is 48 mins.
Almost double the time of a direct Reading - T5 service.
This is the most important "missing link" on the entire rail network.
It is impossible to get from the northwest or northeast to Heathrow Airport by train without multiple changes. .
Stopping GWML trains at OOC provides opportunities for connections with HS2, which would make some journeys between points west and points north quicker than going on the classic network via Birmingham.
Of course they will. Just it will be set down only towards Paddington and pick up only away from it - it will save passengers from cluttering up Paddington needlessly.
Because the track from Stockley Flyover to T4/T5 is owned by Heathrow Airport Holdings and are non-franchised operators which do not have to follow National Rail pricing and until it ends up under NR infrastructure it will continue to be that way so it's LUL services for you still!
HAH want's to charge the DfT 40m a year for Crossrail to use the tracks, and even if HEx don't get granted more track access after 2023, they will be making money from access charges...
Not sure how capacity improvements between Didcot and Oxford will speed up the journey to Brum myself and dont expect anything Bristol Birmingham in CP6 either. In terms of all the GW trains stopping at OOC, that is a given and is a 4 minute penalty at worst. Surely you need to change at New St now for other stations in the West Mids anyway?
4 minutes, 5 minutes - what's the difference? After spending billions on GWML electrification and more money than necessary on IEP, the Reading - Paddington time won't effectively be any quicker than it was in 1976. Not everybody will use Crossrail - many will continue to use the bus, the Underground serving Paddington or walk. And as I have written before - there is no advantage in changing to Crossrail at OOC over Paddington as neither connection is cross-platform. In fact, from the published plans, changing at Paddington looks easier.
And will the new, much vaunted Paddington Bristol non-stop IEPs also stop at OOC? If not, why not?
Capacity improvements between Didcot and Oxford should reduce the allowances for pathing. And if all this money is being spent without increasing the line speed than one despairs. Or rather (one for the conspiracy theorists) one can see an intent to make HS2 more attractive than it otherwise would be.
Regarding Birmingham - at the moment one changes within the same station. When HS2 arrives many will have to change between stations. How is that an improvement?
Yup! But as it is no longer proposed to re-align either routes to bring their stations closer to the OOC HS2 or GW stations there will be a walk of a couple of hundred yards to the new stations on each line.Old Oak Common should also have London Overground services via Willesden Junction and to Richmond and Clapham Junction.
This is lesson 1 in how to encourage people to use the interchanges...![]()
Non stop until HS2 opens.
Don't get sucked in by the line speed saving you loads of time, its 90mph down there now and Didcot to Oxford is 9 miles, you need it all 110mph to save a minute.
I was thinking that with electrification the line speed north of Oxford should be increased - or what's electrification for if it can't supply more horses?
OOC isn't just going to be a station: it's going to be a major interchange hub for all sorts of transport modes, as well as being a new business centre for London on a not-incomparable scale to Canary Wharf. It will have superior onward connections than Paddington. Not only that, but as London gets more and more economically powerful more activity ends up spilling out beyond Zone 1. OOC is in a better position to provide onward connections to these areas than Paddington could ever be, so there are probably going to be a lot of people coming all the way from the far reaches of the GWR network who will want to go to OOC rather than Paddington. The benefits of slowing down every service by a few minutes to call there will more than outweigh the costs.
Acceleration - more horses.Acceleration, saving money and the environment.
Saving money - you're joking. Remind me by how much the costs have risen. You can buy several super tankers of oil with the cost increases. Enough to run the railway for years.
Environment - save me the sermon.
There is a full description of the proposals and background here.
If you wish to describe the favoured disposition of new stations on the Clapham and Richmond lines as 'superior onward connections' then that is your prerogative. One station will be 350 metres from the HS2 station and the other 650 metres away; the distances will be even greater if starting from the GW station. Such an arrangement cannot be classified as a 'interchange' - they are more like route marches. I would hope some form of shuttle will be provided - or at least a selection of Boris Bikes.
Paddington will also have Crossrail, so Crossrail cannot be included as a 'superior onward connection' as it is common to both stations. No new rail lines are planned for the area, so the only distribution will be by the existing lines - at best the bus network might be intensified.
If the redevelopment of OOC as an office centre is successful, then it will be because Heathrow will be only a quarter of an hour away - why do you think that the likes of Microsoft, Apple, Oracle, Verizon, Vodafone and O2 have placed their UK offices in the Thames Valley - not because people at the far end of the GWR network want to get there. And if it is successful then there will be even more pressure for a third runway.
Be careful what you wish for!
How many years worth of diesel could you buy?
Plus diesels have greater maintenance costs.
Also, oil is a limited resource and will eventually be virtually used up.
Brent Crude oil costs at the moment about $35 per barrel - this converts to about £27 per barrel.
The GW main line electrification costs have tripled since approval. To keep the arithmetic simple, let us say the cost increase is £2 billion. For this money you could buy some 725,000,000 barrels of Brent crude which is 29,000,000,000 US gallons or 24,000,000,000 Imperial gallons.
After refining one could get, say, 20% as gas-oil (diesel) making a total of 5 billion Imperial gallons and the rest (petrol, kerosene and so on) you can sell on the open market.
The total timetabled passenger train kilometres for 2012-13 was 522 million (ORR figures), that is some 326 million miles. Assuming the trains consume 1 gallon per mile (roughly what a Class 52 on 10 coaches managed) this equates to 326 million gallons.
So, if all the trains in the country were diesel-powered they could run for some 150 years on the quantity of oil that could have been purchased by the increase in the cost of the GW electrification.
Now tell me that electrification is cheaper.
I did not say that electrification was cheaper, just that it is meant to be cheaper.
Oil will run out, so an alternative will be required, and oil should become more expensive as it becomes more difficult to find (plus the effects of inflation).
You don't seem to have considered the cost of refining and transporting the oil, or the cost of buying or maintaining diesels trains rather than electric.
If you want to have this argument I suggest a new thread might be in order.
Whatever happened to Airtrack? I think that was a much better idea than the western link (but then I do live on the Portsmouth Direct).
Heathrow withdrew its funding, and people were worried about level crossings being too busy.
If we had a Department for Transport which did integrated thinking we could have had a couple of tracks alongside the M25 when that was being widened and got round the level crossings.
Even if the costs of electrifying the GWML were known back then, it would still have gone ahead. All that would have changed would have been Network Rail's willingness to also commit to other schemes in the same time frame.
That wouldn't have addressed the level crossing issue.
The level crossings in question are situated elsewhere, between Staines and SW London.
It would if they had linked it to the Byfleet to Virginia Water line where it crosses the M25. And it would have had a nice grade separated junction into the SWML. Dreams!!
