What are *EO* and **** on Open Train Times?
TransportHub
20 May 2015
I have been using Open Train Times and have noticed the line blocks/possessions at night.
There are
*LB*
*T3*
*EO*
The LB and T3 are straight forward but what are the EO and ****?
Dhassell
22 Mar 2015
*LB* : Line Block
-T3-: Engineering Possession
I believe **** is a train but its lost its headcode somewhere along the route :p
Nippy
13 Aug 2013
In simplistic terms, **** is where a track circuit has become occupied and the Train Describer doesn't know what's there. You won't always get **** in the TD though. It can also be because a train has lost its head code as Dhassel says above.
I have never seen *EO* but would hazard a guess that it is Engineers Occupation.
EO is sometimes used to denote Emergency Outage, which means that while the line is open, the power is off.
**** is most often when a track circuit or axle counter section thinks it is occupied, but with no train described in section. Often during a failure.
alxndr
3 Apr 2015
On a related note, can anyone offer any insight into "*WFT"? My best guess is Wheels Free Track, but seemed a bit of an odd time of day and location for someone to need wheels free so I might be way off the mark.
Sunset route
27 Oct 2015
Correct but in our area our train describers will display a "non discript alarm" NDA as *X** instead of ****
We will often use an -EO- or *EO* for T3 when we have multiple T3s back to back and -T3- and or *T3* have already been used. Some of my colleagues that came from London Bridge ASC still use TIII for T3. Basically as there are no set rules and there will as many variations to what's put into the TD berths as there are ROCs, SSCs, IECCs, ASCs, PSBs and Signalboxes. Even though it's not a rulebook or local requirement our shift managers like us putting the limits of the various possessions in our TD berths so they get better over view of what work is taking place within our area of control.
GB
16 Nov 2008
Somewhere
BRGE BUMP was used the other day for a bridge strike at Needham Market.
You will often see for example IT23 which refers to item 23 in the weekly operating notice. Obviously other numbers will apply.
oversteer
26 Jan 2011
I'm surprised there isn't a standardised list of 'reasons'.
It would seem sensible to have an approved list rather than describing it in a random way which may be misunderstood..?
GB
16 Nov 2008
Somewhere
Seen VERB OTEN used a few times. Took a while to figure out as I dont speakk german :)
Verboten - forbidden, especially by an authority.
trainmania100
8 Nov 2015
Newhaven
Does anyone know why some signals show as *X** ?
Even when a train is running through them sometimes they shown that then suddenly its back to normal again
AndyPJG
29 Jun 2012
I believe it was a Southern (Railway) thing, "*x**"rather than "****" for an invalid TD (Train Description) stepping.
20 Jan 2013
Thing is that before Opentraintimes only rail staff with access used it.
Also, some signallers use the berths as personal reminders. If a train is due to recess in a loop a time might appear in the berth in rear...
Nippy
13 Aug 2013
On our area, we use it to denote a line is Waiting First Train after a T3.
It's only there as a signallers aid. No other reason for it, so, so long as they know what it's for then that's fine.
Freightmaster
7 Jul 2009
H2O- was spotted as a block at Cowley Bridge a few days ago. :lol:
I've also seen [STUK] when a train has failed!
On our area, we use (WFT) to denote a line is Waiting First Train after a T3.
That reminds me - in the Preston PSB area, I have often seen [1TRN] indications,
which looks like they may also be referring to "1st TRaiN" like WFT?
MARK
alxndr
3 Apr 2015
Ah, that makes much more sense, I was way off the mark! Suspect that's probably it, as it was a TVSC controlled area I was looking at, albeit Didcot desk.
wensley
29 Jun 2008
On a train...somewhere!
I had a chuckle last night at work, Tyneside had one Bay Platform showing 'NAKA' for a failed unit and the Thunderbird in Provincial Sdgs was shown as 'FAB*'.
Crossover
4 Jun 2009
I was watching part of the Glasgow area a few weeks ago and Wemyss Bay Pl 2 had the berth labelled as "USE1"
Nippy
13 Aug 2013
Yes then, they do that on the Didcot desk.
MARK
Could be or it depends where it is. I often put '1-IN' or '2-IN' at Acton when I've put an engine or two in the headshunt at the East end of the yard.
Indeed, I also do that as well!
CyrusWuff
20 May 2013
It's been known for "NFG." to appear on my patch on occasion, and it depends who's on as to whether units that sit around for a few hours have the headcode or time of departure for their next working put in, while spare units tend to appear as "SPAR", "SPRE" or "xCAR" as a reminder.
gimmea50anyday
8 Jan 2013
Back Cab
Like this? Wondered what it was on P9!
LAX54
15 Jan 2008
Rail Staff would know what the entry would means on the TD's, there is no reason that any MOP would need to know, it is purely for internal use.
we also use 'STOP' / 'POTS' / S--T / SANT / -LB- / OOPS / ........
83G/84D
28 Oct 2011
Cornwall
Lots of these and other codes are used in TOPS as well, SHNT, AXAM, VSOE, RHTT, IPAX, 4SCO, KYBX, BROK, TBRD are some used recently
IanXC
Emeritus Moderator
18 Dec 2009
I'll raise you *DMIC*
Interesting how much regional variation there is!
Sunset route
27 Oct 2015
There is no reason to, as i put a label to remind myself of something thats different is happening to the norm so as well as using magnetic labels on the control desk I will use the train describer berths. If i need to do a panel handover with such labels in the berths that my colleague doesn't understand then that will also be included in the panel handover, if i see something written when i takeover then i would ask at handover.
83G/84D
28 Oct 2011
Cornwall
Slightly off topic but the two letter TRUST delay code for ill passengers makes me laugh. No I am not saying what it is!
D1009
22 Feb 2012
Stoke Gifford
I think it's brilliant that a bit of the hitherto secret world of the signallers is available to anyone going on line who is interested.
