Xenophon PCDGS
Was the Australian train called "The Ghan" anything to do with Afghans working on the railway there?
Common for organisations with initials H&C. The Hutchings & Cornelius buses in Somerset were the same, aided by being just written H&C on their sides.When I worked in Shepherds Bush, the Hammersmith and City -- H & C -- Line was known as the Hot and Cold Line.
I have already mentioned this line in post 37, but it was never run by the Midland & Great Western Railway.Come to think of it, the ex-Midland & Great Western line from Claremorris to Collooney in the North West of Ireland was also known as the 'Burma Road'.
You are correct in that the term the "Burma Road" generally referred to the section of the line north of Claremorris, now mothballed. The line between Athenry and Claremorris via Tuam might eventually re-open, possibly partly to carry freight from County Mayo to a re-opened freight facility at Foynes, but there is talk of turning the line north of Claremorris into a "greenway".The Slow & Dirty, alias the Somerset & Dorset Joint Railway.
The Knotty, alias the North Staffordshire Railway.
The Burma Road, alias the Waterford Limerick & Western Railway line from Limerick to Collooney Junction, later part of the Great Southern & Western Railway - so called apparently because of the large number of level crossings.
The Premier line (for good reason), alias the London & North Western Railway.
Sorry....seem to have missed that post. Meant to say "Great Southern & Western Railway"....should have checked with my 1916 copy of the Railway Clearing House map of Ireland.I have already mentioned this line in post 37, but it was never run by the Midland & Great Western Railway.
Don't think it's been mentioned yet, might have missed it... but an old nickname for a line that has always intrigued me is (if I'm recalling it correctly) "Castleman's Corkscrew" which was somewhere around the south coast, New Forest area.
Your post is the fourth time it's been mentioned in this thread.Surprised ‘The Drain‘..hasn’t got a mention..
(Waterloo and City Line )
nothing to do with hump shunting thenAccording to Wikipedia, that infallible source, it is most likely drawn from the Afghan camel drivers who immigrated to Australia in the late nineteenth and early twentieth century to help open up the country. I have heard variations on this, such as the name comes directly from the camel drivers who supported the construction of the various bits of the line at the extremities.
Until the coming of DMUs towards the end of the 50s through trains were rarely scheduled, and indeed the timetables were presented separately (Bletchley-Oxford, and Bletchley-Cambridge). Through passengers would have changed trains at Bletchley (never Bedford), and the connections were hit and miss anyway. Even in DMU days the through trains were limited to about 4 each way. I suspect the 'Varsity Line' moniker has only gained traction after closure.Surprised noone has mentioned the "Varsity Line" Never officially called that as it is in fact seperate lines, and if I am correct direct services between oxford and Cambridge itself was quite rare (most required a change at either bletchley or bedford).
I have a reprint of the April 1910 Bradshaw guide. While the 2 timetables are shown separately on adjacent pages, 3 through trains per day each way (Mon-Sat) between Oxford and Cambridge are clearly shown in both tables. They generally ran as fast trains between Bedford and Oxford, but stopped at all stations east of Bedford (the service east of there was very sparse).Until the coming of DMUs towards the end of the 50s through trains were rarely scheduled, and indeed the timetables were presented separately (Bletchley-Oxford, and Bletchley-Cambridge). Through passengers would have changed trains at Bletchley (never Bedford), and the connections were hit and miss anyway. Even in DMU days the through trains were limited to about 4 each way. I suspect the 'Varsity Line' moniker has only gained traction after closure.
That would be more appropriate for the Portsmouth Direct, what with the user group's demand for 2+2 seating...Also, probably not very common, but a few fellow commuters on my local line (the Reading/Windsor via Richmond line out of Waterloo) often refer it to the "Snobbery line(s)" due to the high number of affluent areas it passes through.
Perhaps less so given the anti-social behaviour around Godalming, but then even the Windsor lines have a bit of that with Staines and Feltham.
I refer to Crossrail as the Elizabethan Line
I've never heard it called that, and I've lived in this area for much my 67 years.Also, probably not very common, but a few fellow commuters on my local line (the Reading/Windsor via Richmond line out of Waterloo) often refer it to the "Snobbery line(s)" due to the high number of affluent areas it passes through.
Godalming as a centre for yobbish behaviour seems so incongruous; can anyone explain it?Perhaps less so given the anti-social behaviour around Godalming, but then even the Windsor lines have a bit of that with Staines and Feltham.
Having Staines described as being in Surrey rather than in Middlesex is bad enough (same thing with Ashford), but this Staines-on-Thames nonsense is just ridiculous. Noting the frequency of flooding, Staines-in-Thames might be a better name.As for Staines, it is not that bad either these days, though I do have to admit Spelthorne Counciles attempt to rename it "Royal Staines" in 2010 did have the inevitable giggles and allegations of snobbery. (It was instead renamed Staines-upon-Thames in 2011, with almost similar giggles!)
Overspill from Farncombe perhaps?Godalming as a centre for yobbish behaviour seems so incongruous; can anyone explain it?
My cousin attended a sixth-form there two decades ago, and even then she'd report on some of the "antics" that would go on on the trains (seat cushions and light bulbs being thrown out of windows for example). I've no idea why Godalming seems to get this worse than say Camberley, but it would seem to be a long-standing issue.Godalming as a centre for yobbish behaviour seems so incongruous; can anyone explain it?
I used to travel down to Havant back in the dying days of the 4-COR/4-RES trains on the Portsmouth Direct, and it was interesting to see the contrast between Farncombe and Godalming, particularly when the dwellings on the hillside were in view (is that Frith Hill?).Overspill from Farncombe perhaps?
