What is this for? (NB not another datum plate question)
PaxVobiscum
4 Feb 2012
See attached photo (sorry about the quality - crop from a phone pic.). The object of curiosity is a large shaft or circular manhole (stop sniggering at the back there) with rungs built in which has appeared at the end of the rebuilt platforms 3 and 4 at Glasgow Queen Street. It seems to go down a fair depth. Is it for drainage or cable duct inspection perhaps? I've been lurking around there quite a lot and didn't notice the early stages of this happening.
Definitely for access to a subterranean chamber, my guess would be drainage as I can't see why cable ducts would need to be that deep.
TheEdge
29 Nov 2012
Norwich
Its a datum plate showing the distance from Newhaven Marine.
I'll show myself out...
Ridiculous suggestion.
It's an access point to the tunnel below, where 442s are being hooked up to Class 68s.
DarloRich
Fenny Stratford
is it a new high capacity flange greaser?
hang on! I've got it it is the budget access to the low level station! The escalators got cut due to cost savings
PaxVobiscum
4 Feb 2012
If you compare the original EGIP proposals with what's actually happening that suggestion seems less far fetched than at first might appear. :(
Carntyne
8 Jul 2015
It's not access to Low Level, too far north, think it's for drainage though.
tsr
15 Nov 2011
Between the parallel lines
It's the last-resort facility for delay attribution. All minutes are dropped to the bottom, swirled around and then allocated by a magic octopus.
HMS Ark Royal
2 Sep 2015
Hull
Could it actually *be* something to do with the tunnels under it?
What orientation is the above image with regards to the orientation of the tunnel system?
Carntyne
8 Jul 2015
There are no railway tunnels underneath it. There is a post office tunnel east of the cutting, but it's fairly deep (beyond Low Level and the subway) but it's not for that. Has it's own lift shaft & access on Cathedral Street
PaxVobiscum
4 Feb 2012
[shameless plug] You can also see it for a few seconds from another angle at about 01:25 in the latest video update. [/shameless plug]
Didn't notice it at the time of filming, it was only when I was looking straight down at it from the Buchanan Galleries carpark link later on that I became aware of it.
It was probably the white rabbit that gave it away, though I didn't actually hear it saying `Oh dear! Oh dear! I shall be late!’ :)
Domh245
6 Apr 2013
nowhere
Are you sure it's not for the Strategic Steam Reserve?
Don't be daft - the SSR is located in Box Hill. That said, it is feasible that in the run up to the Scottish Independence referendum, Sturgeon ordered a Scottish SSR (SSSR) to be assembled.
EDIT: I do of course mean Box Tunnel, not Box Hill!
Wouldn't that be the Underground Strategic Steam Reserve (USSR), comrade?
