What settings do you shoot with?
starrymarkb
4 Aug 2009
Exeter
What settings do you usually use for photography? Do you put it on Auto, or prefer to set your exposure and shutter manually.
At the moment I'm mostly using Auto, but now I have a camera with manual control I'm starting to experiment with manual setting
EltonRoad
2 Jun 2009
Kendal
Mostly I fix either the aperture or the shutter speed. On my last trip I fixed most shots at 1/1000, using shutter priority, as I'd travelled a long way and didn't want to come home with a selection of blurred train shots.
Sometimes, when set up on a tripod, the camera won't lock on to any of the focal points, for example if there's a lot of water in the scene. In those instances I'll use the camera's recommended settings in M mode and, once focused, change the focusing to manual as well.
Peter Mugridge
8 Apr 2010
Epsom
I do everything manually - apperture, shutter speed, focus... The only automatic bit is the camera reading the DX code off the film cartridges!
What settings I use obviously depends on the lighting conditions, but as I use ASA200 film then in the current spell of good weather I would be likely to use f5.6 ( partly cloudy ) or f8 ( full Sun ) and 1/500th, assuming a standard ¾ view with the Sun at 90°. With the Sun behind me, if the scene is particularly bright, then I'll either go up to f11 ot 1/1000th depending on the speed of the subject.
My primary setting is the shutter speed, once I have determined what shutter speed to use then I chose the apperture to match it.
And I have managed to get quite reasonable pictures in the tubes ( with the correct photo permit in place and when signed in as a visitor, I hasten to add!:) ) with f1.8 at 1/30th, hand held, believe it or not.:)
curly42
23 May 2008
Manual - everything - all of the time.
( can't trust this devil machinery,you know,work of the devil !!)
:lol:
rail-britain
12 Aug 2007
I chose a digital camera with manual overrides, but I now rarely use them as I have tried them all under different conditions
Most of my photos are taken in "sport" mode
I also have a manual setting (program mode) with shutter speed of 1/1000s
TGV
25 Nov 2005
320km/h Voie Libre
I have my camera (Canon 7D) set to Av (aperture priority) by default and that works for 90% of my general photographic needs, including railway shots that don't involve fast moving trains when I'll set it to Tv (shutter priority). If I'm doing something trick or awkward exposures, I'll set it to full manual.
Focusing I have set to One Shot for most things, but again, with moving trains I'll set it to Servo to track the motion. I see no reason to switch to manual focus unless the conditions are tricky (shooting through a mesh fence or in bad light) because the 7D picks the focus right every time. In fact I trust it's focusing better than my own.
If I'm doing panning shots - Tv, Servo focus and high speed continuous drive. 8fps baby! Awesome.
Bill EWS
10 Feb 2006
Didcot
I always use my camera in Tv (Shutter prority) mode for general photography but use 'P' (programme) mode with strong against the light situations. 'P' mode always gets me a better overall exposure in this situation. Tv mode handles the exposure while I can adjust the speed as required. However for fast moving shots I use 'Sports' mode as shutter speed is kept to the optimum setting and Servo focusing is switched on and allows me to follow a moving object and take multi-exposures if necessary. This is even more necessary when using the longer zoom lens.
mumrar
26 Sep 2008
Redditch
With my Sony A230 I use the Shutter Priority Setting, Usually set between 400 - 800
Is that your shutter speed or ISO equivalent?
I shoot in full manual with exception of focussing, although I've been known to do that also if using a prime.
TGVDUDE
1 Jan 2009
Cheltenham
Shutter Speed Murmar, My Auto-ISO is usually set to ISO100, however the heaviest I've known it to get is ISO400 in the dark evenings, If photographing stationary objects I use the program Auto setting.
